Question about Garden
Oil not feeding oil to bar - Garden
    Problem Solver:
  • 19 Answers
There are a couple of things to check. Remove the bar and check that the small hole where the oil is fed into the bar is not plugged. The bar can be installed "up side down" so be sure the hole is clear on both sides of the bar. If you have an old hacksaw blade try cleaning the groove in the bar. Most of the time this will eliminate the problem.
Posted on Dec 07, 2014
  • 4088 Answers
SOURCE: The chain oil is not
Release the chain brake and remove the bar and chain. Clean the engine area where the bar fits up to, and start the engine--oil should ooze out of the side port there. If nothing, then the oil pump, oil line, or oil filter in the tank may have failed. If it oozes ok, then clean the drive end of the bar--especially the two small passages that run from the large holes out to the chain groove on each edge of the bar. Re-assemble everything, then run the saw bar-tip near some cardboard for several moments--it should throw off a thin line of oil. There should be an oil volume adjustment screw head under the case near the chain return area--turn CCW to increase flow. Hope this helps!
Posted on Dec 22, 2010
  • 62 Answers
SOURCE: Remington 12" electric chain saw, no owners manual
Here are a couple of websites for you to check out, for the oil cap and owners manual.
http://www.masterparts.net/remingtonelectricchainsaw.html
http://www.desatech.com/product.cgi?products=Chainsaws
Posted on Apr 18, 2009
dontbother10
  • 2220 Answers
SOURCE: Bar Oil no longer feeds automatically. Suspect a
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
  • Notes and digital pictures recommended
Oil System Plugged.
Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
M & D Mower
http://www.m-and-d.com/parts.html?id=ij3MJ2uj
Best source I found for old Mac Parts. I've found parts here I could find no where else (complete Mac 110 oil pump and associated hoses, reasonably priced). It is a little tricky, their on line help is good too. HTH
Posted on Oct 28, 2009
Testimonial: "Thanks for the great information. It is hard to find repair info. I have 4 old chain saws that needed repairs. I will get them out and get them going"
dontbother10
  • 2220 Answers
SOURCE: Problems with the 350 husqvarna bar.
If all you say is true and when revved up the saw oozes oil with the bar removed, then I suspect the bar is incompatible with the saw. Has the bar been replaced? The oiler holes in the bar must align with the channel in the saw. Oiler hole placement is part of the reason there are so many different part numbers for bars. The mount is only part of the requirement.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 03, 2010
yosemyt
  • 322 Answers
SOURCE: Oil feed to cutting bar
check that the part that turns the oil pump is in good condition, the oil pump gear isn't sticking and that the line from the pump to the bar isn't blocked cracked or broken
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Posted on Feb 19, 2013
My Stihl MS 231 is not feeding oil to the chain how do I locate the problem and repair.
The chain and bar oil should feed from the reservoir to a small hole in the bar that feeds the oil to the bottom of the chain. If that little hole gets dirt in it, the oil won't feed to the chain. To clear the problem, remove the bar, remove the chain from the bar, and clear the hole in the bar and track for the chain in the bar. I've done this while out in the woods by just using a stiff dry piece of grass to push the dirt out. Once clear, replace the chain, teeth facing the correct way, and the replace the bar, and tighten.
Nov 13, 2016 | Stihl Garden
Why does my stihl chain saw stall when I tilt it. Also it has a problem pushing the chain oil out to the bar
You never stated what model you're referring to. The running issue when tilted could be a fuel tank vent problem. Replace if necessary.
The oiling problem could be a number of things, check the bar groove is clean, check the oil pick up body inside the oil tank, check the oil pump/ oil worm if it has one (don't know what model yours is) check the feed line between the oil pump and where it exits to feed the bar.
Apr 07, 2016 | Stihl Garden
How do oil feed the chain bar
oil feeds to the bar and chain via the oil pump, generally driven by the crank shaft and drum, depending on the make and model of saw.
Mar 15, 2015 | Garden
Poulan chainsaw oil leak
sounds like the small oil feed pipe inside oil tank as come away from the end. just push it back on you may need a pair of long snout pillers.. good luck
Nov 30, 2013 | Poulan Garden
Feb 19, 2013 | Garden
No oil to bar
Drain the oil tank, now will witha suitable cleaning fluid, rinse the tank out several times, this will help to remove any dirt in the oil filter screen, remove the bar and chain, clean out the bar rail and oil feed, now try again.
Mar 05, 2011 | Poulan 14" Chainsaw
Chain oil tank full, feed channel behind guide plate clear, but no oil going to chain when running. This is a homelite 16.
There should be a oil adjusting screw on the bottom of your saw next to the bar beside the oil tank. Some models actually has the screw inside the tank. Drain the tank to make sure there isn't any debris clogging the hole where the oil feeds to the bar.
One way to check to see if the bar is oiling is:
1. Start the saw
2. Put a board, piece of cardboard or an uncolored old shirt in front of the bar
3. Press the trigger on the saw to allow the chain to circulate around the bar.
4. While keeping constant pressure on the trigger, look to see if there is a vertical line of oil on the piece of material you have placed on front of the bar. If the saw is oiling you will have a vertical line. If not adjust the oil set screw accordingly.
Nov 15, 2010 | Homelite ZR10926 16 Chain Saw
2150 2.1 cu super clean The chain and bar oil will not come out?
There are several things you can do. First, are you running standard bar oil in very low temperatures? If so, switch to winter formula or motor oil. Next, take the bar off and see if the hole that feeds the oil to the bar is obstructed. Other possibilities are sawdust getting in the reservoir while filling it and blocking off the tube, or it not being adjusted to feed enough oil. There is usually a screw on the bottom of the saw near the bar to adjust how fast the oil flows to the bar. When it's got enough oil, you should be able to spray a mist of oil onto a piece of wood while revving the saw.
Dec 31, 2009 | Poulan Garden
No bar oil coming out since new !!!!!!!!! is there a setting screw somewhere??????
I would remove chain and bar reinstall cover (For safety). start and run. oil should feed out into bar area, If nothing at all, return it for a new one, If you have oil check to make sure the bar has a matching hole where the oil feeds out. Newer saws dont oil much at all due to EPA standards it would be nice to have an old manual pump on some but I just carry a squirt bottle for the very large cuts I do and when I run into water.
Most have removed the adjustment screw that used to be on the bottom or clutch side of saw.
look for a trace amount on a smooth surface not alot like 10 years ago.
Good luck.
Jan 16, 2009 | Poulan PP4218AV 18" Chain Saw
Husqvarnar model no 345 oil feed problem
First thing check the feed hole through which the oil is delivered to the bar itself for debris,secondly the worm gear turning the pump shafft need only be slightly damaged to hamper full oil flow , next take the oil filler cap off, (with the bar ,chain ,bar plates, and oiler removed ) look where the oil pick up is in the case half and remove it and check for clogging and / or tears in the rubber hose,
if the cap is equipped with a breathing filler cap check make sure the cap breathes this will also hamper maximun oil flow capacity,
I stand by this , as I have dealt with product for close to 2 decades and know it intimately
W.O.T. Technologies
Oct 27, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
