Question about Sewing Machines
My machine will not sew. New not used but a few years old. once thread goes down to bobbin it locks and you can hear the clutch disengage. without thread you can run the needle at full speed then it
I opened casing of machine to see if anything was broken or not moving. nothing looked wrong or loose.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
There may be a small bit of thread or lint caught somewhere in the bobbin case or bobbin holder. Brush lint away from the feed dog area, being careful not to brush lint into the workings of your machine. If you have the manual, look up how to clean lint from the bobbin. If you don't have the manual, try just taking the hook out, if possible. Run a clean toothpick around the housing and then use a clean small brush to brush out any lint or thread pieces. Put one drop of sewing machine oil on the hook of the bobbin housing. Then use a thread to "floss" your bobbin case. Run a thread through the slot and wiggle back and forth to loosen any caught thread bits. Good luck. ps If this doesn't work, repeat. Sometimes after you turn the hand wheel a bit, another piece of thread or lint will work loose and can be cleaned.
Posted on Dec 16, 2014
Janome mini heavy duty sewing machine
when you sew keep a eye on the thread take up lever & see if the thread comes off while your sewing, I've had this happen to me & I've been sewing for over 30 years. if this does happen, take a pair of pliers & very gently close the take up lever just alittle but not enough to damage it.
also check the needle to see if it's damaged--if your not sure change the needle--flat side goes to the back of the machine
always make sure the fabric & needle & thread are compatable--the thread must be able to pull thru the needle with out any problem
also check to make sure there are not any burrs on the needle plate or bobbin or bobbin case
Feb 26, 2012 | Janome SEW MINI Mechanical Sewing Machine
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
I have a kenmore sewing machine model #385.1249180. I cannot disengage the clutch knob from the hand wheel when I spin my bobbins, therefore the needle moves up and down as the bobbins spins thread. Do You...
Usually when you pull the clutch knob out it disengages the sewing machine needle shaft. At least, that is how my 2 Kenmore's work. You can always take your machine into Sears sewing department and ask the sewing machine salespeople for help, they are really helpful in my area and more than happy to help you for free. Good luck
Dec 23, 2010 | Sewing Machines
I have a singer touch tronic 2001sewing machine. I put the material to be sewed down, put down the foot and when I tried to sew, after a few stiches, it pulled the materal down and locked up. I pulled...
What type of material are your trying to sew? If it is stretchy, or thin put some gift wrap tissue paper under it to stabilize it. Also, adjust your tension to about 2 or 3. Now check your needle, put a fresh one in, maybe a 9 or 11. Do not use old thread, either because it breaks easy. Try this, I hope that it works for you. You can buy stabilizer, pellon but tissue paper is what we used years ago, sometimes even computer paper. Good luck.
Nov 10, 2010 | Singer Sewing Machines
I was using a Singer 9018 sewing machine, I rethreaded the bobbin, loaded it up and threaded the machine fine, but when I power up and start trying to sew, I can hear the machine motor going, but the...
Did you remember to tip the clutch on the end to being flat when you were done with the bobbin winding?
The disk tips to disengage the works while winding bobbins.
Dec 30, 2009 | Yamata FY101-1A
Kenmore by sears model 1581457180 need a manual or a how to thread the bobbin
hi there,
on my manual 1581 kenmore show figure on how you thread your bobbins and upper thread.
to thread bobbin insert the thread on one hole of winder holding thread and rotate thread on counter clockwise rotation several times, loop the thread on tension thread and insert bobbins winder on winder shaftat top of your sewing machine push the latch to lock bobbin winder
pull the handwheel to disengage the clutch and to move the winder free rotation.
press the foot pedal to run your winder and thread your bobbins be sure on counterclock wise rotation.
if winder is full of thread this will automatically disengage the shafting winder from clutch.
4843169.jpginsert winder as in fig. check the thread direction
5d74924.jpg 153629c.jpg on figure hold and insert bobbins on shuttle race assymble.
on figure show upper threading.
3cba620.jpg follow the red thread on figure.
you can also check your manual on internet
search box type www.kenmore 1581
have a nice day,rate my fix,thank's a lot
Jun 12, 2009 | Sewing Machines
Old Kenmore 158. bobbin issues, thread clumping and such
problem is always on the opposite side of the fabric, in your case the machine is not threaded properly.
Apr 24, 2009 | Kenmore 16622 Mechanical Sewing Machine
Have an old white rotary machine # 151 or possibly #247
I have a few of the old White machines and it is never obvious as to how they are threaded. I found a YouTube video demo of a White and the fellow does a pretty fair job of showing how to thread the machine. I will include the link. https://www.youtube.com/watch?v=j9eiKXCjv80 Threading White Rotary model 43 sewing machine
Jul 09, 2017 | White Sewing Sewing Machines
Bobbin clutch just spins
Clutch is disengaged only for winding thread onto the bobbin.
When done, re-engage (tighten) clutch and with bobbin in bobbin case, hold needle thread, rotate handwheel until needle is top centre of it's motion then pull threads thru allowing approx 100mm (4") slack .....you are ready to sew.
If this isn't what you were asking, then I'm not sure why you have disengaged the clutch, so more detail please.
Feb 14, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
