Question about Nextbook NEXT2 Touch Screen Android Tablet
Why does my tablet keep saying USB disconnected?
  • Nextbook Master
  • 3,368 Answers
A quick hint, the USB has to be connected to an active device that is powered on, if not this is the message you would get.
Posted on Dec 06, 2014
  • 68 Answers
More info please. What make and model of tablet? What are you trying to do when this happens? Ant other pertinent data.
How do I repair the USB PORT on a ACER ICONIA B1.
Step 1 - Back Case
  • To start, gently separate one corner of the case using the black spudger.
Step 2
  • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
Step 3 - Battery
  • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
Step 4
  • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
Step 5 - USB Port
  • After setting aside the battery, remove the two 5mm screws holding the metal plate over the USB port.
Step 6
  • Find and remove the silver 5mm screw holding down the metal cover opposite the USB port.
Step 7
  • Disconnect the blue cable by gently lifting the flap.
  • Remove the indicated 2mm screw holding the speaker in place.
Step 8
  • Pull up the metal panel just enough to allow access, then remove the USB port.
Oct 29, 2014 | Acer Iconia B1 7-Inch Tablet Black Dual...
How can I delete my data from an iPad 2 whose display is black & unreadable?
Hi David,
I think this will help you please refer to below steps:
  1. Make sure the iPad battery is charged above 20% ( we would recommend at least 40 - 50 %). If you are not sure charge you tablet for at least 30 -40 minutes.
  2. Make sure iTunes is not running on your computer but is ready to be run.
  3. Temporally disable firewalls and other security software to prevent interference with iTunes.
  4. Make sure your tablet is disconnected from the dock or USB data cable that equips the gadget . Nevertheless USB cable must be plugged into your PC or MAC.
  5. Make sure your PC or MAC is awake and its screen saver is turned off.
  6. Simultaneously press and hold down the Wake/Sleep button and the Home button and wait until "slide to power off" screen appears. Don't do anything after its appearing, just keep holding Wake/Sleep and Home buttons until Apple tablet will power off.
  7. Release the Wake/Sleep button once Apple tablet is off , but continue to hold the Home button
  8. Holding the home button, connect the USB data cable to iPad. When you reconnect the USB cable, tablet should power on and you should see a message on your PC/MAC display saying that iTunes has detected an iPad in Recovery Mode
  9. After you detected this message, release the home button and press OK on iTunes pop-up to confirm the restore option.
  10. Do not touch iconic tablet and you computer while iTunes downloads and installs the fresh copy of firmware on your iPad. You will be notified by iTunes when iPad is successfully restored, but... in a while, you will get an message saying that the iPad isn't recognized. Don't panic. This is because all user content on iPad including activation status was erased during restoration.
  11. Disconnect iPad from iTunes ,unplug from computer and turn off.
  12. Turn iPad on and using iTunes activate it on any computer you have. Apple currently allows up to 5 computers to be authorized for each iPad.
Aug 12, 2014 | Apple iPad Tablet (32GB, Wi-Fi)
How to reset apple ipad
Hi Anonymous,
I think this may help you,
Aug 11, 2014 | Apple iPad Tablets & eReaders
How do I reset my ipad
Hi Anonymous please follow these steps:
Aug 08, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My proscan tablet keeps crashing. It says google play has stoping working. I've reset the tablet twice. what can I do?
Keeps crashing because can't handle too many tasks at one time. I have the same problem. I have the same problem. Try the pin hole reset next to the HDMI input . Press in gently with a paper clip and hold for thirty seconds.
Google play? Try uninstalling updates. Disconnect from internet when not in use.
These tablets have lots of problems not easily solved because there are no firmware updates for this model.
May 25, 2014 | Proscan 10.1-Inch Internet Tablet,...
My 8" nextbook tablet keeps saying hdmi connected and I haven't connected one. It won't let me watch my music videos or listen to music outloud. How do I fix this?
Hi Ethan Douglas,
maybe your netbook still thinks its connected, so it redirects all media to HDMI.
Try connecting it to a TV via HDMI, check your media if its playing like it should (on TV let's say), and then disconnect it. That might do the trick.
Mar 02, 2014 | Nextbook Tablets & eReaders
My mp3 player will not charge
Sometimes it helps when you keep the cord connected to the computer and use the function to disconnect it from windows. The screen will turn from "USB connect" to "charging". This worked for 2 or my 3 players....not sure about that third one.
Sep 18, 2012 | Ematic e8 series
Cannot get it to charge from the computer and it will not set up the wifi keeps saying scanning and then disconected
Sounds like a loose USB port or defective communication circuit to me. If you have done repairs like this before, you can do it yourself. Otherwise ask a friend or a local repair shop. Free guides can ususally be found on google and youtube, the usb port or motherboard should be available on any auction website or tablet part suppliers.
Jul 09, 2012 | Polaroid 4.3" Internet Tablet
Nextbook NEXT2 Touch Screen Android Tablet Logo
73 people viewed this question
Top Nextbook Tablets & eReaders Experts
bigdawg7299
Nhat Nguyen
Level 1 Expert
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
