Question about GE Washing Machines
How do i access the brake pads on my ge profile washer model #wprb9220coww
Talked to the coin mach repair guy at work described the symptoms and gotten his advice to spray some lithium grease on the brake pads
  • GE Master
  • 3,382 Answers
I would suggest getting a repair person to look at it.
Posted on Dec 06, 2014
Ge profile microwave starts when the door closes does not heat but the light,turntable& fan are on pvn1870smc02
I'm assuming you mean "PVM1870SMC02", which is the Canadian version of the US model PVM1870SM2SS.
With the symptoms you describe, you likely have a shorted main relay (lamp relay) on the unit's controller.
This can be economically repaired. Details are here.
Jan 08, 2013 | Microwave Ovens
GE Washer Model ## WPSB9220D0WW Data Code31704 Error Code E43 Drive System Excessive Brake Time My washer don't do anything but show this error
On GE Washer Machines, E43 error code means "excessive brake time". The brake and speed sensor will need to be checked. You can try resetting the machine by disconnecting the power for 20-30 minutes. Keep in mind that your right model number is WPRB9220D0WW.
You can eliminate if it's the speed sensor by entering the service model. To do this:
- Turn off the washer at the power pad
- Remove power by unplugging the cord for 15 or more seconds
- Plug back in and within 30 seconds simultaneously press and hold the POWER and START pads for 3 seconds
- Should now display the model codes
- There are a bunch of tests but we are interested in the spin fast portion, so press the custom 2 pad until the display shows SF ( Spin Fast )
- Hit START pad... it should start spinning and display the rpm's
If it does this the speed sensor is working and the problem is the brake which means the transmission has to be replaced. Parts replacement can be find in THIS LINK.
If you do not feel able to resolve it, we recommend you call the technician to do it. Now you know what the problem.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 10, 2011 | GE Washing Machines
Ge profile washer 12 years old, won't start but when put on rinse cycle it works
http://appliancejunk.com/ge/dishwasher/31-9137.pdf
Ok, this can be a few things that show this symptom, you will have to troubleshoot and isolate your problem by using the troubleshooting steps in the manual. If you need parts, they are readily available online, simply Google, for what you need, all numbers etc, are in the manual.
Jun 05, 2010 | GE Profile WPRE6100G Top Load Washer
Ge profile washer WPSR3100W1WW won't agitate
I see this pretty regular. You have a bad transmission. This is very common with the older GE's. To replace the transmission will run around $340 / $400. Not sure about your area. Just be glad you got this much use out of it, you are one of the very few that have. From 1998 till 2007 I owned my on repair company where I did GE's warranty work in my area for them. During that time period. When I found a GE washer under warranty doing what you are describing. GE would warranty the whole machine. They would have me destroy the machine after I would deliver the customer a band new one. GE knows they had a bad transmission and it cost them a lot of money. It was cheaper for them to replace the washer than have me repair it. The transmission list price was $298.00 back then. A word of advice, when you replace it. Buy a Whirlpool, Kenmore, Maytag. These brands hold up the best. I have the least service calls for Whirlpool and Kenmore. Both are made by the same people. Kenmore is made for Sears. Good Luck.
Please rate this solution if helpful. Thanks
Aug 21, 2009 | GE Profile WPSR3100W
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
Front load washer- coin removal
Hi, The coin is probably inside the baffle that tosses the clothes around. I believe this nodel has a screw that holds the baffle in place. I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 28, 2009 | GE WSXH208A Front Load Washer
GE front load washer model WSXH208A1WW
look in back of mach for 4 shipping bolts.they are usually housed in a rubber grommet surrounded by a yellow plastic shaft.if they are there remove all 4 of them.also remove bottom access panel by taking out 2 screws(1 on each bottom corner)look for 1 or 2 yellow steel bars connecting base to tub.if they are there remove.if none of these shipping bolts or brackets are there,you have a broken basket.if that's the case,try to get your money back or buy a new mach.it is a $600 repair..good luck
Sep 27, 2008 | GE WSXH208A Front Load Washer
I have a GE Profile Washer Model # WPX214A0CC. During the spin cycle, it just stopped and the water is still in the washer without spin drying the clothes. HELP!!
Hey cissy, sounds like your pump is plugged. Could be rubber backing from a cheap throw rug, other lint type item, or object like a coin or hair pin.
Remove power, take two screws out from the very bottom front edge of machine. remove access panel to gain access to pump. Remember, disconnecting hoses to pump will cause remaining water in tub to come out, be prepared. Remove obstruction from pump. Reassemble. Fixed!
Sep 03, 2008 | GE Washing Machines
Washing Machines Logo
41 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
