I have a resistor green in color (the body) the band colors are as follows Brown, grey , silver then gold . I am trying to find the value the third band is troubling because the chart does not recognize the silver 3rd band...What you got ?
  • 3,368 Answers
15 Ohms, resistors under 100 ohms do not have one of the colors in the third band.
Posted on Dec 06, 2014
  • 1694 Answers
SOURCE: Convergence Resistor Hitachi 50DX10B
2.2 ohm 1 watt...................................T.
Posted on Jan 30, 2008
Slinteriors
  • 8617 Answers
SOURCE: need resistor value for RK62 on DP2X board for 57SWX20B
RK62 is a 2.2ohm 1 watt metal oxide resistor hitachi part number 0700054M any 2.2ohm 1 watt resistor will work although it does have to be metal oxide(flame resistant) for safety purposes.
Posted on Mar 24, 2008
lukster
  • 217 Answers
SOURCE: Dark greys appear a dull green.
could be a jumper that needs to be removed on the DMD board, or a setting in the factory mode, mute-182-power will get you in there
Posted on Jul 18, 2008
SOURCE: white colors schemes seem off white color or brownish color and blue has green tint or baby blue color. .
Check the coolant in all three crt's as chances are it is contaminated (should be crystal clear). If brown (beer color), replace coolant in all three crt's and perform convergence adjust. Picture should be like new!!!
Good Luck!!!
Posted on Jul 25, 2008
  • 899 Answers
rk46 should be a 1.8 1w
Posted on Oct 30, 2008
Samsung home-theater model no# HT-E330K, power supply resistor RA805 completely burnt can't see the value of the resistor. Pls help with the value of the resistor
This may sound like a lazy answer but without a schematic, its going to be tough. Perhaps you know someone...or maybe there is someone here who has the same unit who wouldn't mind opening it up to get the value. Good luck.
Oct 08, 2013 | Audio Players & Recorders
Does anyone know what value the R99 resistor is on the true sub junior
R99 on the Sunfire True Sub Junior is a surface mount resistor (no color bands), and measures 51k ohms. R102 near it is colored gray, red, brown, gold.
Jun 16, 2012 | Sunfire True Sub Jr Subwoofer
I need schematic diagram for samsung ct-14h4 because some of the components are hard to determine like resistors
usually a resistor have 4 to 5 color bands,an inductors looks like a resistor but have only 3 color bands and a capacitor also looks like a resistor but there is no gold or silver color bands,even though it has a color band also...
Jul 19, 2011 | Samsung Televison & Video
I have two crack green resistors colors are red, brown silver gold. what value is this. Its on the power board of a 24 dell monitor
The value = 0.21 ohms 5% tolerance
Use this WEB site to work out the value of the resistor.
http://www.smpspowersupply.com/resistor/resistorcolorcode.html
This WEB site gives you the color code values for resistors.
http://www.google.com.au/images?hl=en&q=resistor+colour+code&um=1&ie=UTF-8&source=univ&sa=X&ei=YHRsTfSsK5C2vQPA353UBA&ved=0CCsQsAQ&biw=1024&bih=416
Mar 01, 2011 | Computers & Internet
While replacing the caps on on the LCT32HA36 power supply i noticed a corroded solder joint the Z3 diode. When i attempted to re-solder it the trace came off the circuit board and I lost the R3XX surface...
The resistors are color coded.There should be 3 bands which are slightly separate from the 4th band.The 4th band is usually gold,silver,or i forget the third color which is actaually a %.The top 3 bands can tell me the value of the resistor.If you tell me all 4 colors I should be able to tell you the value,with the gold/silver/whatever as the fourth.The first one should be right near the end or top.The only 1 problem will be trying to determine the wattage rating but is usually very small within a circuit.Greg
Dec 17, 2010 | iLO LCT32HA36 Television
Value resistor 719 of chasis serial : qpwbf9254mezz,tv sharp 27" model: 27j-s100 or diagram. thank you for his help
I looked at the same chassis I have and the resistor has color bands green blue silver gold wich is a .56 ohm 5% 1/2 watt resistor
Dec 03, 2010 | Sharp 27J-S100 TV
Blowin resistor on my Acoustic Research S112PS
When I put an ohm-meter across it, I get 505-ohms. The color code looks like maybe green, dark brown, brown? Mine is discolored too. Green, brown, brown would be 510ohms. . .so that must be it. The tolerance band is gold, so that's +/-5% so that would explain the 5 ohm variance.
Feb 12, 2009 | Acoustic Research S112PS Subwoofer
NEED TO KNOW THE OHMS VALUE FOR RESISTOR ON PEANUT 8685
I have the same problem, but it is open.  The color code Brown - Green - Brown - Gold.  If it is a resistor, the value must be 150 ohms +/- 5%.  To confirm the value, I open the working trimmer and remove one leg from the circuit and measure resistance.  The meter reads only 4 ohms.  Therefore, I think it is an inductor (150uH +/-5%), not resistor.
Jan 27, 2009 | Wahl 8685 Hair Trimmer
WILL NOT TURN ON
Sir;
friend of mind had the same model # and he give me the color band for the resistor
Nov 18, 2008 | Yamaha HTR-5560 Receiver
Inquiry
Click the link below to know how to read resistors or you can use the calculator by changing the colors and pressing calculate.
http://www.hobby-hour.com/electronics/resistorcalculator.php
Let me know if you need further assisatnce.
Sep 21, 2008 | Tvone TV-207 Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
