Question about Hoover Genuine Candy Zerowatt Washing Machine White Door Handle 49003783
Candy washing machine gc4 2d washes for about 15" then stops for 30" (the screen goes black) then on again for about 10" and then stops again.
Unplugging for 30 mins, pressing the start button after unplugging and while it's unplugged without any luck. changing the program to another one it keeps doing the same thing.
    Sergeant:
  • 230 Answers
Sounds like overload protection is disabling the machine. it could be caused by a lot of reasons, the only advice I have is to check for a jammed drum, empty machine and see if drum turns freely. best luck to you.
Posted on Dec 06, 2014
Testimonial: "thanks for that, i have emptied the machine already and turned the drum, and seems to be ok but it keeps doing that switching on and off. i have to confess though that it was a bit overloaded..."
Why does my candy grand o washing machie say 08 and stop working
If the code actually is E08, there is a problem with the motor speed sensor. The motor may be rotating at high speed for a few seconds, slowing down, and stopping or there may be no rotation at all.
Feb 24, 2017 | Candy Washing Machines
My candy washing machine isnt spinning on a quix wash
are you trying to spin one item as on these machines you cannot do this under load sensor will be tiggered
try the quick with nothing in ur machine if all goes well then above would apply
Dec 29, 2014 | Candy Washing Machines
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
Candy SC1000 why will my washing machine not drain water away after a cycle wash?
Dear washer
There might be some "dirt" ( I am not familiar with the English word for the rests that sit in the in the sieve at the bottom on the front of your machine)
Take the front bit off at the bottom (ca 10-15 cm) To your right there should be piece of plastic that you can turn (theremay be an arrow to show the direction to turn). When that loosens some watermay come so a big towel on the floor is a good idea. Remove the lid and the sieve and rinse. Put back and try.
There might also be something that blocks the hose that takes the water out.
Then there might be an idea to put some"machine rinsing"stuff in the machine and let it wash without washing. Where I live you can get some rinsing liquid for dishwashers, coffeemakers anf washing machines from Electrolux.
Hope can get thissorted out.
kolbrun
Aug 11, 2011 | Candy Washing Machines
My Candy C514 Washing Machine stops half way through the cycle and lights flashing.Yesterday mechanic came and checked everything ok Motor, pump and water goes in fine, any idea? What this can be? Many...
first does the water drain in the machine or stays if so it can be your pump that sucks the water out or cloged check, next if its electronical screen it could be screen problem ,or even door lock somtime s pops half way will need to be change ,check step by step,, if helpful plz rate.
Jan 19, 2011 | Candy Washing Machines
My washing machine is Candy C435 T model.when i am filling the water it goes out directly without filling..Why?
Possibly the drain outlet is too low.
Try raising the outlet hose to a higher level, this will stop it syphoning out as it is filling.
Jun 06, 2010 | Candy AQW130 Front Load Washer / Dryer
Flashing lights on my candy washing machine
Hello Mikana, i have a brand new one and it also flashes the 90 and stain removel had the Candy eng out and it needs a new heater...all the electric goes throught this heater and if it detects a problem then it shuts down...the ones they fit at the company are not vrey good so the replacement is going to be better....ring Candy ........also if it has a large load capacity like 8kg don't under fill it it may send the drum of centre and this will stop the machine....self protection built in...hope this helps...cheers Dave
May 25, 2009 | Candy CNW156 Front Load Washer / Dryer
Sticks half way thro programme
found the problem,unplug machine pull out remove back cover screws look in side machine,there is a black pipe on right hand side bottom of machine,that is the drain pipe to the pump,remove jublie clips and check for blockages,mine was blocked refit cover and put machine on normal cycle to clean,
machine works fine now,
Jan 26, 2009 | Candy AQ130 Front Load Washer
Hoover Genuine Candy Zerowatt Washing Machine White Door Handle 49003783 Logo
67 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
