Question about Dryers
Machine shuts off after 10 minutes and clothes do not dry
    Sergeant:
  • 248 Answers
It sounds to me like your temperature sensor is bad, but it may also be the one in the motor overheat protection. this could be caused by some small object jammed between the turning drum and the frame of your machine. if the machine seems to work fine, but shuts down after a few minutes, it should be a cheap fix, heat sensors are not that expensive. best luck to you.
Posted on Dec 06, 2014
I want to know that on my washing machine lg-80BKF21P model the time(min) 10 minutes was remaining and the washing process is done,it ends but after drying all is done but 10 minutes were remaining and...
tumble driers and combination washer driers have a 10 minute safety margin, where the heat fior drying is dispersed, to avoid people grabbing very hot clothing.. especially if it is not quite dry as this would make them, hotter to the touch.
Tumble driers usually continue to tumble, but blow cool air through the clothes to get rid of the heat, before stopping.
Oct 02, 2017 | LG Washing Machines
Maytag neptune model mde5500awy
There is a spec sheet for that machine under the drum, take the bottom panel off and look for an evelope or a clear bag. IT will tell you the tests that you can run to diagnose the issue. One of the common complaints is that unless the drum is packed full, clothes dont brush up against the sensors enough to tell it how moist they are. Then the dryer shuts down thinking that it is done.
Jan 20, 2014 | Dryers
Bosch WTL5200 silver edition not getting hot enough to dry clothes
Check ur venting inside and outside the machine. the lint basket? is the air blowing out the back without any restrictions? then check ur thermostats with a multi meter for continuity, may also want to check ur moister sensor, if its mis reading the dryness it will shut off heat early
Jul 16, 2012 | Bosch Dryers
Shuts off during autodry cycle. stays on during timed cycle but clothes are wrinkled ans too hot at end of cycle.
if it works on auto but not on time you have a bad timer,it's not counting down,it's better to use auto anyway,when the clothes dry the dryer shuts off on it's own,this way your not using extra electricity,if your clothes dry in 30 minutes and it's on 60 minutes it will still run after the clothes are dry on auto it doesn't.if you open the door and look around the opening you'll see a tag with the model number,your missing a couple of letters on the model number.
Mar 05, 2011 | Whirlpool LER4634J Electric Dryer
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dyer malfunctions
Clean off the two metal bar inside the drum, near the lint filter. (these are the moisture sensors, which can become coated with fabric softener sheet residue, preventing the dryer from "seeing" that the clothes are still wet)
Jan 13, 2009 | LG WM-2277HW Front Load Washer
Dryer shuts off prematurely
The E1 code is a replace control panel code and a good way to check a sensor is to open the door with a empty machine and at the top of the opening there is a switch. Press it and start the dryer, watch the indicator for the sensor then get a wet finger and hold it across the two silver bars in the dryer, if it senses then maybe it is a mixed load or how is the machine leveled? I will lower the machine toward the sensor for better contact because after 3-5 passes the machine will assume the clothes are dry. If the sensor doesnt read then there is a question with the two mov varistors attached to a pig tail before the sensor. Here is a link to see what they look like.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=529092&PPStack=1
May 04, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
53 people viewed this question
Top Dryers Experts
