Question about Microwave Ovens
The Door will not stay latched - Microwave Ovens
  • Microwave Ovens Master
  • 3,382 Answers
Use a bungee cord to keep it closed. With out any additional information we cannot help you. Adding the make and model will help a lot.
Posted on Dec 06, 2014
Tip
Maytag MMV4205 door won't stay shut.
After tearing apart my microwave, I found a little spring broke off the latches. Open the door to the microwave, pop off the plastic piece that the latches on the door go through. You will see a spring behind the latch. If the spring is not connected to the latch it won't operate properly. The spring was held onto the latch with a tiny plastic piece that broke off. An easy solution instead of buying a new latch is to heat up one side of the spring without burning yourself and melt it through the latch piece where it was originally connected then put everything back together.
Hope this helps,
Pillarair
on Jul 21, 2009 | Maytag MMV4205 Microwave Oven
Door will not stay close
Not much data to go on here. The latch on the door has a spring that holds it down in the locked position. when you pull the handle the latch goes up and you pull the door open. You will have to take the door apart and see if the spring broke or the plastic tab that holds the end of the spring is broken.
Feb 25, 2015 | Maytag Appliances Over-the-Range Microwave...
I replaced the door latch onour LG model LMV1630ST when Ishut the door the light stays on and the start butten will not work. all the other buttens work.
There is an interlock that is part of the latching mechanism that prevents the oven from operating when the door is open. In the process of replacing the door, the interlock must not have been properly set. Look for a switch associated with the latching mechanism, it should be relatively obvious what is going on.
Sep 09, 2014 | Microwave Ovens
Sharp microwave R-520K/R-520L door wont stay closed how can I repair it
There is a tension spring pulling the door latch assembly in a downward direction, keeping the door latch closed against the door switches and latch.
Spares required will be either a spring or a latch assembly both fitted inside the door. To get to them the plastic choke cover around the perrimitter of the inside of the door must be removed to reveal fixing screws.
eSpares Spare Parts Accessories for Electrical Appliances eSpares
Oct 31, 2017 | Microwave Ovens
Why does the light / safety switch stay on when the door latches shut ?
Most likely there is a part missing from the door latch mechanism that you need. This probably broke off when the handle failed. It would be a tab or wedge shaped piece of plastic that strikes the door switch and pushes the switch closed when the door is completely shut. You will need to find that piece and glue it back on or get a new handle assembly from Samsung.
Aug 01, 2012 | Samsung Microwave Ovens
Genn-Aire JUMV 8208BAB door on microwave will not stay shut
try to adjust the latch, if not you must replace go to www.repairclinic.com and buy it
God bless you
Jul 16, 2012 | Microwave Ovens
Neff H7871 oven door does not stay closed. Catches do not appear to be working
The door latch is either cracked or broken.The door when gets closed the door latches clicks.But if the door latch is loose or cracked it will not click and door will not close.The door needs to be disassembled and the door latch has to be replaced, if the latch is cracked.Also to check the latch from inside the door needs to be removed.-------- This will help.thanks.Helpmech.
Jun 29, 2011 | Neff Microwave Ovens
The door latch button doesn't release the latch to open the door. It just goes all the way back when you push it, as if the mechanism is broken.
hi, if the door release latch is eaven from both sides and it is pivoting in and out with out staying in, i would suspect of the interlock switch assembly(this goes to a mmc5000 m.w. oven).00078674.jpg
but if it's not eaven or staying in then door latch or door actuator are suspect.00291855.jpg 00018565.jpg all these parts go to a mmc5000 but i am using it as examples, if you have the model number for yours try repairclinic.com and you can get prices for what ever you are going to need for the repair.
Jan 18, 2010 | Maytag MMC5000 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
