Question about Refrigerators
My Kitchen Aid KSSS36QDW fridge stopped working. There is no power on in the refrigerator or freezer. It's not the breaker. I am in able to turn the power switch from on to off in the top panel of the unit. Bad switch or something else. Unit was mfg in 1996.
    Problem Solver:
  • 7 Answers
Is the unit on a gfci circuit? plug something else into the outlet and see if that works.
Posted on Dec 07, 2014
Sea Breeze
  • 4654 Answers
SOURCE: amana ABB1922 refrigerator - refrigerator not cooling
Check fan for operation and vent duct for ice or the damper sticking between the two compartments. It does not take much when the freezer is on bottom, colder air (because heavier) remains there without proper circulation. I will be trying to find the maintenance /service manual to help resolve this. JT
Posted on Feb 04, 2009
  • 93 Answers
SOURCE: Chemical odor in refrigerator/freezer
put coffeee grains or orange peeles this will take the smell away thanks from gilles
Posted on Mar 15, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Kitchen Aid Refer: KSSC42FMS01: The freezer, doesn't go below 32
How long have you had this refrigerator and is this the first time this has happened? Your refrigerator has a control board and I believe the board is causing the refrigerator not to defrost every 8 hours. Let me know these questions and I will help you resolve this. Thanks, Sea Breeze
Posted on Mar 19, 2009
wheelshot
  • 102 Answers
SOURCE: Subzero 590: freezer works, refrigerator not cooling
This is a Sub Zero and many technicians do not realize that these units most all run on 2 separate systems. 2 cold controls 2 compressors 2 evaporators. They share a condenser and condenser fan motor. What you are describing is most likely a bad cold control. It is pretty common for these to get some age and go bad. If you are very savvy with repairs yourself then if you access the compressor area and feel that the compressor on the right is cool and the compressor on the left is warm then you know that the ref. compressor has not been running. UNPLUG THE UNIT OR CUT THE BREAKER OFF. Remove the shelving from the fresh food section and the cover to the lights and the panel below the lights and lean the back panel forward to access the cold control. You will see 3 wires to the cold control. The green wire is the ground wire of corse. Unplug the other 2 wires remembering their location on the control unit. Take a jumper wire and jump these 2 wires. If when you power the unit up the right side compressor comes on then you know that your fresh food cold control is bad. Replace fresh food cold control.
Posted on Apr 11, 2009
SOURCE: ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Posted on Jun 27, 2009
Refrigerator motherboard How can I tell if the motherboard of my kitchen Aid refrigerator went bad
Make sure your fridge doesn't have a recall for evaporator as is the case on my fridge I also thought it was electronic and first tech thought it was a leak in reality the evaporator was clogging and causing freon to not keep fridge cold or freezer to work properly but kitchen aid won't let you know you will have to let a tech look that info up for you.
Mar 15, 2014 | KitchenAid Refrigerators
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
KITCHEN AID REFRIGERATOR PROBLEM We bought a used Kitchen Aid fridge YKSRS22Q (1993), the ice maker is not working but water does work. What should we check to see why the ice maker doesn't work?
Ice makers work off of temperature. If it's not cold enough in the freezer it won't work. Check the temperature with a thermometer, it should be 0 to +10F
Jan 29, 2011 | Refrigerators
Kitchen aid KSRG25FKSS04 freezer is not freezing
Hello, few things to check:
1) Remove dirt / dust that has accumulated on the condenser coil located on the back of the fridge, or underneath. Use a vacuum to clean off with.
2) Remove dirt / dust in / around compressor area. Make sure you turn power off first as there are several areas in this area that can "bite."
3) Look for heavy frost / ice buildup in the freezer compartment. Defrost if necessary.
4) Make sure the fan is blowing in the freezer compartment.
5) Make sure there is air flow from the vent at the top of the refrigerator compartment. This air is driven by the fan in the freezer (most models).
6) Loading a lot of unfrozen food into the freezer compartment will have the appearance of the fridge going out, but is actually functioning normally as it removes heat from the food so it will freeze.
7) Your thermostat is not working correctly. Move it to the coldest setting if not already done so. Listen for the compressor to kick on. If it doesn't, bad t-stat.
Thanks
Jul 12, 2010 | Frigidaire FRS26KF6E Side by Side...
My kitchen aid (5 year old)fridge keeps quitting--no cooling.
Please change it Compressor because The pump of it compressor is not working properly
Apr 13, 2010 | KitchenAid Architect KBRA20ERSS Bottom...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Kitchen aid bottom freezer dripping sound
drain cloged behind freezer panel?
Aug 26, 2009 | Refrigerators
Ksrs25ikss01 kitchen aid fridge portion not
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid refigerator: door won't seal then lost power.
The GFI had becme stuck - yes we had plugged the fridge into the GFI which is apparently a bad thing to do. Replaced the GFI (and moved in away from the fridge) and all is well.
Jun 02, 2009 | KitchenAid KTRC19MKSS Top Freezer...
My refige is warm and my freezer is frosty
lg american fridge freezer my fridge is working ok but my freezer isnt can u help please ty
Dec 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
