Question about Onkyo TX-SR605 Receiver
How do I find a replacement for the speaker driver board (amplifier circuit board), or a suitable alternate?
To obtain the indication of the original part number or an alternate. Also, an orientation for its internet purchase.
  • Onkyo Master
  • 3,382 Answers
Try ebay use "audio amplifier board" as the search term. Most of what you find will be 25V or less.
Posted on Dec 06, 2014
I have a Rolland guitar amplifier and the speaker is polling, can I replace this 12 inch 8 ohm speaker with a high Fidelity 12 inch 8 ohm speaker.
You can try another speaker given the rms is the same as the original......or the wattage.....If you get the same results sound wise after replacement......you might want to consider buying something else.
Mar 23, 2012 | Car Audio & Video
Sound issues with picture turning off
you have a defective audio amplifier IC and must be replaced, likely cause is the shorting out of the speaker terminals, on the main board you will find a IC mounted vertical attached to a heat sink, flowing the speaker trace from the speaker connector may help to locate this IC, once you have found it you can obtain the part number from it and contact a local electronic pars supplier for a replacement, after you have the replacement and it is installed make cretin that there are no short circuits are in your speaker connections external and internal with an ohm meter. also you should check the speaker impedance is within tolerances of the tv speaker output impedance.
Jan 09, 2012 | Toshiba 50H81 50" Rear Projection...
I have a Denon PMA 500V amplifier. all of the output fuses were blown so I replaced them but the unit still doesn't work. Any suggestions?
hi.
Did you checked balanced impedance?load speaker impedance vs PA output?or PA might over driven,causing a trouble on the pre-amp to power amp circuits and components damage,
need to recheck related components on the pre-driver up to main output section,
Note: That,blowing of fuses with the same rating is an indication of trouble/shorted in a circuits that driven on it,
Thanks and good luck
microhit
Jun 01, 2011 | Denon PMA-2000R 2-Channel Amplifier
I want to connect my new amplifier bose ...., my car (audi a4 2003mod. ) have on the normal sound sustem with the concert audio..., i fix all the speakers from bose on my car and now i must put out the old...
Bose is premium gear at premium prices so it isn't wise to take chances - you should contact Bose to obtain a connection diagram and then you could find it isn't suitable to use the existing Audi wiring and you should wire afresh from scratch. Obtaining an Audi diagram will help or perhaps a connection diagram for the original sound system.
Sep 29, 2017 | Car Audio & Video
Hotrod amp is distorting on the clean channel once it goes past 3,is it a speaker problem or is it tubes?
to rule out the speaker, you could try one of 2 things.
1. remove the speaker from the cabinent and gently push the diaphram in 1/2 an inch to 3/4 an inch, as far as it will gently go- BE GENTLE. the speaker should recess and return to normal position smoothly, without any scratching or rubbing, or internal resistance., the only resistance should be from the paper cone itself, not internal to the speaker. if there is any rubbing or scratching from the inside (inside the area surrounded by the magnet), or any changes in resistance (not smoothly moving) as the speaker goes in or out, then the voice coil is damaged.
2. find another speaker of suitable wattage and ohmage, and disconnect the hot rod's internal speaker, and hook the replacement speaker up in the internal speakers place. a speaker of 50-100 watts should be suitable, and it will probably need to be 8 ohms- a standard bookshelf speaker may be suitable if it is a suitable wattage and ohmage rating (stamped on the back of the hot rod's speaker magnet and/or on the back of the external speaker/cabinent as "8ω",) do not, and again, do not, under any circumstance disconnect or connect a speaker while the amp is on, or even plugged in. touching the positive and negative speaker leads together, even briefly, while the amp is powered will fry the amplifier circuit, and you will smell it!!!
Mar 09, 2011 | Fender Hot Rod Deluxe Guitar Combo...
I also have an Athena ASP4100 sub woofer which blew the fuse on the circuit board and when I replaced the fuse, it just blew it again. As an electrician, my understanding would be the circuit board has a...
You should look at the circuit board for the power amplifier and check for any leaking or bulged electrolytic capacitors. If this speaker uses the circuit boards made by AMI (such as most JBL and Mission sub woofers around 1999-2001 vintage) they had a lot of problems with this as well as bad modules. Google for the module S53AMI and you will find lots of info if this is what you have in that Athena.
Feb 21, 2011 | Athena AS-P4000 Subwoofer
I have no sound at all
Have you checked that sound is coming from the computer? Make sure you don't have the output muted and that your volume is turned up. Check the output by plugging in a pair of headphones or another speaker system. If that's all normal, the problem is in the speakers.
The speakers aren't actually a part of the monitor although they do hang on the sides. Check that the audio cable from your computer to the input jack on the right speaker is plugged in at both ends. Check that the power adapter is plugged into a working AC outlet and that the power plug to the speaker is firmly seated. Does the power indicator light when you turn the speakers on? Is the volume control up? Those AC adapters sometimes do fail. The adapter is replaceable if it's gone bad (you can find a suitable one at Radio Shack).
If everything else is checking out and the speakers still have no sound, the amplifier integrated circuit has failed. While this could be repaired, you can probably buy a new set of speakers for what a service shop would charge to replace the amplifier.
May 30, 2009 | HP Compaq FS7600e CRT Monitor
How do I open a fender passport 150 speaker cabinet?
There are screws running down the sides of the front panel which you will have to remove. The circuit board is secured to the front panel by the nuts, washers etc. that the controls and jacks are fastened with. Once you get the panel; loose gently move it forward so you can see any connections to the circuit board. Make careful note of all of these and draw diagrams. You will have to completely remove the panel from the enclosure and then the circuit board from the panel. The jack in question will be mounted on the circuit board and soldered to it on the reverse side. You will need to unsolder it, obtain an exact replacement, solder in the replacement and replace the board on the panel and the panel back in the enclosure. Make sure everything is connected exactly the way it was originally. Hope this helps.
May 23, 2009 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
Visonic David 80 speakers - replacment drivers
I'm not sure down under, but check with ORANGE COUNTY SPEAKER in California. They are online and most likely will have replacements. They may ship overseas. Watch the VAT!
Mister Phil
Apr 06, 2008 | Audio Players & Recorders
Phonic Max2500
you have real problem in safety contol circuit which shut down the unit to protect the amplifier from damage
Mar 06, 2008 | Phonic MAX 2500 Amplifier
Onkyo TX-SR605 Receiver Logo
69 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
