At start up it makes a loud whining noise and once I put fluid in power steering reservoir the noise goes away
Find the leak and repair it. Could be the pump, hose or the rack and pinion. The foam is from sucking air into the system from being low. Same as the noise.
Spray down pump and hoses with degreaser and wash off. After its dry, use recomended fluid to fill. Start engine and turn steering wheel all the way left, and all the way right a couple of times. This will blead the air from the system. Now shut off and check fluid. Make sure it is full. Now drive the car down the road and make turns, and drive it back and check fluid level. If its still foamy and not leaking fluid, your pump ma be bad.
