Question about GE Dryers
How do I fix a Stuck power button GE Dryer model GDFN240El1ww
It seems as though it is stuck in/won't pop out.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Turn off power to dryer. Remove power button, and relace it.
Posted on Dec 06, 2014
Ge dryer only works if start button is pushed in model #gtdx100emoww
The start/run switch on the motor is stuck, usually with lint. Clean everything with a vacuum while you are in there.
Nov 22, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Dryer front load power button stuck in
What is the model number?
Oct 21, 2012 | Dryers
GFDN240ELOWW
My husband just fix my GE Dryer GFDN240WW "Start Button broke" issue. Here is what he did; He removed the control knob to access the phillp screw. Unscrewed screw and lift up on control to remove panel and unhook power supply. Then set control panel on face. Unscrewed 5 larger screws to removed black plastic panel w/ mother board attached. Set board aside and located power button which was broke off. Compare button to all other buttons on panel to see how they are attached to panel. My husband used Plumbers Goop from Lowes store to attached power button like the others. Then he reassembled the dryer and presto! It works!
Jun 09, 2012 | GE Dryers
Frigidare AEQ600es2 does not heat. Reports error code E68, but all buttons seem to work.
You will nee The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Apr 17, 2012 | Frigidaire AEQ6000ES Electric Dryer
Dryer won't turn on. Door is closed and has power. Button seems spongey.
The usual thing wrong when a dryer will not start is a blown thermal fuse. I wrote this tip about how to check the thermal fuse. http://www1.fixya.com/support/r10530385-dryer_power_but_start
GENE
Sep 24, 2011 | Kenmore Dryers
My GE dryer won't shut off when I open the door.
See the button to the right of my screw driver just above the model number tag?
Sometimes they stick or plain go bad.
Mar 19, 2011 | GE DPSE810EGWT Electric Dryer
I need replacement remote charger (part #5-2582) for my GE 2.4GHz speakerphone and answering system # 27958.
I love my old GE coded/cordless phone set, but the cordless phone's buttons won't dial anymore; they get stuck. Can I get a replacement for the cordless phone only? The charging cradle seems to still work. It is Model # 27958GE1 A. Thanks!
Dec 14, 2010 | Uniden Cordless Phone
Hoover 5020D Dryer door won't open... button is
You probably have a coin or other metal object stuck at the bottom of your dryer door preveinting it from opening. Take a table knife and see if you can push the object upward to allow the door to open..
Jul 29, 2009 | GE DBXR463EDWW Electric Dryer
When I turn on the dryer you can hear the juice going thru like its about to start but nothing happens, drum doesnt move. I checked, its not stuck. dryer only 1.5 yrs. old- happened suddenly
most of the time on your model it is the dryer main fuse that pops,you can pop the top and look to the right of the drum on the back wall all you will see a little round fuse,you can get it from your local appliance parts store for around $10,if it happened all of the sudden could have just been a power surge pop it-mike
Apr 20, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Buzzer won't go off when dryer is stopped - All else works fine - must leave door open
Fiddled around with the start button. It had gotten stuck in the on position and when I moved it around it freed up. I consider this a temporary fix only and have already ordered a replacement switch.
Aug 02, 2008 | Maytag Dryers
Dryers Logo
428 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
