Question about Aiwa Audio Players & Recorders
I have receiver Aiwa AV-D58U.output is good but not audio out
I change 2 power transistor front channel.i don't find audio.
  • Aiwa Master
  • 3,368 Answers
Most of the time find it is not the output transistors. When you replaced them did you adjust the bias etc correctly. Do you have audio driving those transistorts? if not it may be one of the ic;s
Posted on Dec 06, 2014
Where can i find a replacement optical audio jack for a AIWA AV-D58u?
try an online electronics parts supplier like mcm electronics. Just make sure the orientation is the same and a generic one should work.
Sep 19, 2016 | Aiwa Audio Players & Recorders
Okay my problem is its stuck on 5.1ch input and anything els i do it says CAN`T USE. (M. NO#. AV-D58U)
When turning it on hold the enter key at the same time to reset the machine back to the factory settings...worked for me when I had that exact problem.
Feb 23, 2011 | Aiwa AV-D58 Receiver
When I turn on my aiwa stereo I hear a clicking noise and it turns off and loses power.
This is an overload protection feature. Check for speaker wires shorted to ground or a blown component.
Sep 20, 2009 | Aiwa AV-X100 Receiver
Power lite is on but nothing happens when power on is pushed
Check your Speaker control button. Most receivers have a small button on the front used to control your choice of Speaker Set A, B, A & B, or NONE. It's possible you have inadvertently pressed the button and set it to where no speaker set is selected. Therefore, no sound.
Another probable cause is that one of your speaker cables may have become dislodged at the back, and if your system has an overload control mechanism, it's preventing sound to come out to avoid damaging your output transistors, your speaker system, or both.
The last (I hope not) possibility is that the volume may have been cranked up too high, that either the output resistors may have blown on your receiver, or your speakers may have given out the ghost due to too high a signal.
Aug 17, 2009 | Aiwa AV-D57 Receiver
TURNING ON, BUT NO OUTPUT TO SPEAKERS.
Try making sure tape monitor is in off position. Also I assume front speaker button is engaged. Another option is that analog setting needs to be changed to digital if digital output
Apr 22, 2009 | Aiwa AV-D67 Receiver
Aiwa AV-D97 Power Issue. Just clcks when you hit the power button
The unit is most likely in protect mode. This means that the output section has a problem and the protection circuitry is preventing it from being turned on. This is to prevent further damage. The typical defective parts are the output transistors. Figure on $20-$40 for parts plus the local labor rate for repair.
Dan
Jun 10, 2008 | Aiwa AV-D97 Receiver
Inquiries
Straight from the product's manual...
Amplifier section
Power Output-
[Stereo Mode]
125 watts per channel
[Dolby Pro Logic Mode]
Front
120 watts per channel
Rear (Surround)
60 watts per channel
Center
120 watts
Click HERE for the manual.
There you have it.
Cyryl
Nov 10, 2007 | Aiwa AV-X220
Can i bypass the protect on my receiver?
Sure!... If you want to set the unit and your speakers on fire!
Recievers/amps have protection circuits to prevent pure DC voltage of the power supply from going unmodulated to your speaker(s) if the output transistors/ICs are shorted.
Aug 26, 2007 | Aiwa AV-D67 Receiver
Subwoofer output
There could be a number of reasons causing this malfunction, try replacing the subwoofer's cord, it might be damaged, you can also try reseting the system to the factory settings according to the following instructions: Reset Instructions: 1. Press the power button to turn off the power 2. Press the power button while pressing the ENTER button. (note: this will reset all memory) Good Luck
Jan 09, 2006 | Aiwa AV-D57 Receiver
78 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
