Question about Olympus Fl 20 Fl 36r Fl 36 Flash
How do I remove the battery cover on my Olympus fl36 flash gun
Can the battery case cover of an Olympus SP550 uz be easily obtained & easily replaced?
The cover on the camera is cracked or the battery case is cracked. If it is the battery that is cracked replace it immediately. If its the camera attachment that is cracked Gorilla Tape works wonders :)
DO NOT USE THE PHONE IF THE BATTERY CASE IS CRACKED!
Sep 13, 2014 | Olympus SP-550 UZ Digital Camera
How to open OLYMPUS SP570 UZ to fix flash lift
First, remove all visible screws.
Then use a magnifier to closely examine the hot shoe. You will see that there is a spring clip which can be slid rearward and removed. Under this clip are 4 screws. Remove these and the rear cover is free.
Jan 09, 2013 | Olympus SP-570UZ Digital Camera
How i can mount a new battery cover on Olympus SP-560 UZ
i just purchased a new cover for $33 from uscamera. part#omp vg4293. You will need a jewlers philips screw driver. Make sure you lay out screws where they came out. They're different. Looking at the bottom,Remove 1 screw under battery door. Two screws on bottom my mount. Open little door on left for mem card and remove 2 screws. Open little door on right side where cable goes, remove 2 screws. Then gently on end wher door goes, pull back cover back just enough to remove old door and reinstall new door. Press back together and install screws.
Jun 18, 2010 | Olympus SP-560 UZ Digital Camera
How to remove the battery cover from the E620 so as to insert the FLD-5 battery holder
You can download Olympus E 620 manual from the below link.
http://www.dpnotes.com/olympus-e-620-manual/
Battery holder (not FLD-5, it is HLD-5) can be easily remove. Please read the picture below.
Feb 22, 2010 | Olympus Cameras
When I open the shutter door on the front it does not seem to switch on - the battery is charged - the green and orange light on the back flash and beep ???
2 thoughts. 1, with both green and orange lights flashing the manual indicates that that means that the battery is not charged. This site provided an answer to a similar question that suggested cleaning around the battery area [see Bill BS answer to Wendy]. 2, To you and Wendy, I had a similar problem and a call to Olympus suggested the likely problem was not battery related. When you open the slide, and if you press down on the cover, around where the "s" on olympus appears, that keeps the lens extended. Don't know why that is, or how to permanently fix, but it seemed to work.
Dec 07, 2009 | Olympus Camedia C-50 Zoom Digital Camera
Two buttons flash and nothing comes up; screen is blank
The problem you are describing is a problem with battery connectivity in the camera. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $51 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 20, 2009 | Olympus FE-115 Digital Camera
Battery cover for Olympus D-520 Zoom camera
https://emporium.olympus.com/innards/emp.asp?counter=&p=16&getparts=yes&productParts=857&submit1=Go
Here is the link to the Olympus parts website where you are able to find the replacement part you are looking for
Feb 23, 2009 | Olympus Camedia D-520 Zoom Digital Camera
Olympus FL36 flash unit
Hey I have an E510 and an fl 36 flash unit and no problems for a year now.
And no problems at all {knock wood]!
Have you checked to see if all the flash pins are making contact?
Normally I only turn my flash on after I put it on the camera and then turn the camera off and then on again to see if everything is ok. I remember the flash would not communicate with the camera on a shoot and after a while I realized that the flash was not all the way in the hot shoe. Fool around with the flash off the camera first and see. The flash have modes that you have to set up if the mode is set in full manual that might be a problem. There is a button that you have to hold down for three seconds to get in the menu, Get hold of your manual or download one My buttons are fine and have not faded any at all. I realize that the power button an the flash is hard to press on, I do hope I was of help .GOOD LUCK
From Chris
May 29, 2008 | Olympus FL-36 TTL Flash
Non-syncing Olympus FL-36
Normally I only turn my flash on after I put it on the camera and then turn the camera off and then on again to see if everything is ok. I remember the flash would not communicate with the camera on a shoot and after a while I realized that the flash was not all the way in the hot shoe. Fool around with the flash off the camera first and see the flash have modes that you have to set up if the mode is set in full manual that might be a problem. There is a button that you have to hold down for three seconds to get in the menu. My buttons are fine and have not faded any at all. I realize that the power button an the flash is hard to press on, I do hope I was of help .GOOD LUCK
From Chris
May 12, 2008 | Olympus FL-36 TTL Flash
Olympus mju 410- Orange lamp flashing
I had this happen and fixed it by removing the battery and leaving it out overnight and making sure it was fully charged - the next day battery inserted and it was ok. Prior to inserting battery I opened shutter cover and help down shutter release to try to drain any residual power. - Worth a try.
Oct 12, 2007 | Olympus MJU 400 Digital Camera
Olympus Fl 20 Fl 36r Fl 36 Flash Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
