Question about Bosch Maintop assembly sgcs365r s/s - 143102
Center burners on my SGCS365R won't start. spilled liquid on it, what should i do?
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Gas burner with hot jello spill spark won't turn off
Sounds like the sensor telling it that the burner is on is shorted out with the jello. turn off the power so you don't get shocked and then give the entire assembly a good cleaning.
Sep 15, 2012 | GE Profile JGSP44 Dual Fuel (Electric and...
I spilled liquid on my HP Probook 4320S (with spill resistant keyboard). Dried it up straight afterwards. Now it won't power up
Take it to a service shop asp, key board will need to be replaced, and the laptop will need to be assessed for motherboard damage.
May 06, 2012 | HEWLETT-PACKARD ProBook 4320s C Notebook
Vostro 1520- keyboard stuck on randomly repeating keys after small liquid spill.. no liquid inside, only a few drops on keys and it won't type right. Tried USB keyboard but it won't override the...
short of replacing the keyboard, there is not much you can do. If not killer expensive, then you could at your own risk put isopropal alcohol inside the tray - move around and then turn upside down. this will be easier on the electronics and may dissolve the liquid depending on what it is. If the viscocity is too high, then it wont work but worth a try.
Jun 14, 2011 | Computers & Internet
Vegetable oil spilled from pan and around sealed burner. They burner no longer ignites even though I can see a spark coming from the igniter
This can be tricky, but if you have the same range model that I have, it has a little central cap on each burner that acts as the flame spreader and the working top of the burner channels.
The igniter is off to the side and actually has it own little drilled-in hole just above the business end where you see the spark. Spills, especially big, greasy spills, can get into the hole and harden.
Than narrow little hole simply needs to be cleaned out. Find a small stiff wire and bend it in a long L shape. Work the long end into the hole from either end - wherever you can find the way in... those spills can be awful. **** it out really good so the little gas channel is free of blockage andyou should be good.
You don't have to take anything apart, just get down close and look. On my stove, the hole is in the center of a little raised bump in the burner casting when you look at the center of the burner with the little flame spreader/burner cap off.
Apr 11, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
GE range electric lighter will not stop lighting
Is your range gas with electric ignition? And are the igniters constantly clicking with the burners off? If so it sounds like you may have spilled liquids into the electric switches at the burner control knobs causing them to short. This is a common problem and the best fix is to unplug the range from the power and let the range dry out for 24 to 48 hours. Sometimes using a hairdryer can speed up the drying process. If you did not spill or get any liquids into the burner ignition switches then there is a posibillity that one of the switches is defective. You would need to test each igniter switch with a continuity tester and the burner knobs in the off position(power unplugged for safety) to see which switch is defective and replace that switch.
Mar 22, 2010 | GE Kitchen Ranges
GE profile gas cooktop - sparker firing with knobs turned off?
replace your spark module
have you spilled liquid on the cooktop recently?
if yes let it dry for a couple of days and see what happens.
sometimes when you spill liquid on the cooktop it grounds out the spark module and it will continue to spark until it drys.
let me know if you need more help
Feb 15, 2010 | Cooktops
My burner sparks though my burners are off
did you spill liquid on the cooktop? sometimes if you just let it sit for a few days to let it dry out it will fix itself. but if you spilled oil on it it will not fix itself. you have a bad spark module and the only way to fix that is to remove the cookyop fromt he burner box. and find where all the wire go into this usually redish orange box sometimes its blue. but that is your spark module. let me know if you have any more questions
Jun 01, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Bosch Maintop assembly sgcs365r s/s - 143102 Logo
374 people viewed this question
Top Bosch Garden Experts
roeb
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Garden Expert? Answer questions, earn points and help others
