Question about Whirlpool Kitchen Ranges
Whirlpool electric stove XERP4110SS oven and burners do not light up
Clock, timer and oven light are OK. I cut power and reconnect and the problem is still there. The problem started gradually and I would simply shake to stove and turn all the knobs to finally get it working. Now this doesn't work anymore.
  • Whirlpool Master
  • 3,368 Answers
That is a classic sign of a bad connection or a bad relay. You will have to take it apart to find the problem however be sure the power connections are good first.
Posted on Dec 06, 2014
HOW DO YOU SET THE CLOCK? I CAN'T GET THE OVENS TO WORK
If the clock is showing time you may have accidently knocked the auto button this will shut off the power to both ovens until the timer times out you must press the manual button it usually has a little hand printed on it. If you do not have any lights on the clock or oven it may be due to
1. a blown fuse or tripped power supply
2.Thermal cut out tripped or failure
3.A broken live or neutral wire isolate the power before doing any continuity tests.
4. A faulty timer.
Apr 30, 2015 | Ovens Ovens
Oven won't turn on, had a power outage on the street 3 times today. Tried flipping the fuse, but nothing has happened. Any suggestions? Not sure which model Zanussi it is, except it is not brand new!!
The electronic clock/timer must be in manual mode for the oven to operate. When the power to the oven is cut the electronic clock/timer reverts to automatic mode when the power comes back on.
Mar 07, 2011 | Zanussi ZBS963X Electric Single Oven
Range Model YKESC307HWO: Received Voltage Spike from Power Supply Company resulting in damage to several appliances including my Kitchen Aid Range. The control panel does not light up anymore, resulting in...
It sounds like the control board of the timer is faulty. Do you need the electronic timer/clock. If you don't it is normally easy to by-pass the timer altogether. Find the main active wire coming into the timer. Then identify the load wiring which runs from the timer to the oven thermostat control. These two wires simply need to be connected and the timer is bypassed and the oven will work.
Feb 12, 2011 | KitchenAid KESC307 Electric Kitchen Range
I have an oven with digital clock. Every time power is cut, it seems that the digital clock needs to be repaired by replacing it. If the clock does not work, oven is not operative. Is there a way to solve...
Yes, it is simply matter of bypassing the clock/timer so that the oven thermostat will have permanent power going to it all the time. It is a matter of removing the active and load wire at the rear of the timer and joining them together.
Feb 11, 2011 | Ovens
The oven tripped the main fuse switch to the house while on and when i restored power the clock on the oven came on but nothing else works no grill, oven, fan or lights ???
you have to set the clock befire anything works .if you have done that its could be that the element has failed and the fault current has damaged any of the contacts in the circuit which can be themostat ,timer contact thermal cut out contacts. failure of the timer contacts would leave nothing working
Aug 04, 2010 | Baumatic B187 Stainless Steel Electric...
Hi i have a de-dietrich dod338 oven but ive found the light on the clock is very dim yet if i have a power cut and when i reset the power trip again its bright but as soon as i try to set the time it goes...
i had this problem also - it is the timer assembly. you can replace the timer assembly as a whole, or if you're useful with a soldering iron, replace the capacitor which is right next to the digital display. the display gets warm and this gradually breaks the capacitor. I replaced this - it was about £3 from rs components (the capacitance and other info is printed on the side of the capacitor). Hope this helps - i bought a replacement main board and clock assembly ( which got lost in the post so i tried to fix it in the mean-time while the replacement was sent out.) obviously don't do this fix if you are not confident, but that was the fix for my problem which is the same symptoms as yours.
Dec 14, 2009 | Ovens
The timer clock has gone off.
to stop the clock area from flashing and for it to display time, the time must be set.
Apr 09, 2009 | Ovens
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
97 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
