Question about Nintendo Wii Console
Video from my Wii to my tv is no longer working. It used to work fine. Audio still works. I bought a new composite cable, but it still doesn't work. I have a hitachi 42hds69 tv. Any ideas?
The video from my Wii to my hitachi 42hds69 TV is no longer working. I bought a new composite cable, but that didn't help. What else should I try?
  • Nintendo Master
  • 3,368 Answers
Try your unit on a different tv or a different unit on your tv, you will then know the problem.
Posted on Dec 06, 2014
SOURCE: No video on Wii console
Go to http://www.wiierror.com/
They have solutions to yours under Misc Error link & most common problems on that website for Nintendo Wii.
Good Luck!
Posted on Nov 24, 2007
SOURCE: Black and White Video - Wii Component cable
put yellow in video red and white in audio and change source to av
Posted on Jul 08, 2009
  • 20 Answers
SOURCE: When I hook-up my Wii directly to my TV have audio but no video
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
kibriya15
Posted on Jan 13, 2010
  • 7 Answers
SOURCE: NO VIDEO problem. I have
I would buy a new video cord for the system first and if that does not work i would have somebody check out the system.
Posted on May 05, 2011
  • 5 Answers
SOURCE: Wii to Philips LCD TV
Looks like the AV port in your Philips television is busted. It's the only factor if the Wii is able to function with other tv with the same cable. You can either purchase a new television/get the one you have fixed (these will cost money) or you could just purchase an hdmi cable which doesn't use the same port so it could possibly work with your Philips television.
Posted on Jul 08, 2011
My Wii U wont work on my RCA TV!
U will need to get another av ..connecter...the color cords you said..there rca jacks..then it will work
Jul 29, 2014 | Nintendo Wii Video Game Consoles & Games
I just bought a toshiba 50M2U 50' series TV. I also bought a audio/video switch to connect my bose 3,21, surround sound sytem which still uses the red, blue, green cables and I have a wii system w
i think your problem is with cabling your surround sound is audio only and you wii is video and audio. i would hook up wii first and get it working first. dont plug the surround into the yellow jack on your audio video switch
good luck
Sep 09, 2012 | Toshiba 50L2200U 50" 1080p LED-LCD TV -...
Denon 1312 receiver composite video inputs do not work.
I'm having the same problem with my Wii output. The manual for the Denon AVR-1312 says that analog video signals (i.e. component/composite outputs from the Wii) are not converted to digital video signals (i.e. HDMI output from the rcvr). I'm running only HDMI to a projector, so the video signal is essentially lost. The fix appears to be to run an additional composite cable all the way to the projector. Sounds like your fix is the same. No Wii tonight! :(
Jul 07, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
Need to know how to connect to tv it comes on but in black and white
If you're using composite video cables (red/white/yellow) but your TV doesn't have a yellow jack to plug into, plug the yellow cable into the green "Y" plug instead. If there is more than one set of video jacks on your TV, make sure you're using the first set, usually labeled "Video 1" or "Component 1". If it still comes up in black and white after all that, you may need to look in your TV's settings menu to see if there's an option to change the settings for that port from Component to Composite.
If you're using component video cables (red/white & red/blue/green) make sure the cables are all plugged in to the proper color-coded ports on the TV. Mixing up the video cables can cause the image to show up in black and white
May 12, 2012 | Video Game Consoles & Games
Wii to Philips LCD TV 32"" - sound but no video. Just bought a refurb. Philips LCD TV for our WII. The standard AV cable gave sound, no video. The warning message flashes up in the beginning...
Jul 07, 2011 | Nintendo Wii Console
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
My wii has power but no picyure why?
Check The cables that connect to the TV. Make sure that the cable is securely connected to the console. Next make sure that if your using the Red, White, Yellow composite cables everything lined up. Yellow is video and should go with the slot labeled video on the TV or the yellow slot on the TV. Red is right audio and should be put in the labeled spot for right audio on the TV or with the red spot on the TV. Lastly white is left audio and should be put in the spot that is labeled left audio on the TV or in the white spot on the TV. If all of the cables are hooked up like so, and everything is secure yet there is still no picture, you need to buy a new cable because it seems that one may have been damaged. If there is still no picture with the new cable, then your last option is to try it with another TV. If it works with the other TV, the 1st TV your trying to put it on has a faulty composite input. If it still doesn't work on the other 2nd TV, then there is an internal problem with the Wii and needs to be repaired or replaced.
Hope this helps!
-MarcusTuttle
Jul 17, 2010 | Nintendo Wii Console
Trying to add Wii, but no video only sound.
The manual says you can get an optional Component Video cable (RVL-011) for the Wii. There is apparently one unused Component Input on theDenon where you could connect it. You would still have to use the Red/White analog audio.
The Yellow is for Composite Video only. It's lower quality and not compatible with Component Video (3-wire).
In the short term, why don't you just run the Wii's combined Composite video / analog audio cable to the provided Composite Inputs labeled DVD, VDP, TV/DBS, VCR-1 or VCR-2 on the Denon?
It would not be necessary to have BOTH Composite and Component video from any device, much less the Wii.
Ponder this, why do you need to run the video from anything to the Denon at all if your TV has mutliple video inputs? TV's specialize in video, theDenon specializes in audio. You can always extend the Red/White audio cables to reach the Denon.
May 06, 2010 | Denon AVR-2802
Yamaha HTR 5760 Video Problem with Wii
You need to connect a composite cable from the receiver. The receiver does not carry a composite signal over component cables.
Feb 25, 2009 | Yamaha HTR-5760 Receiver
Onkyo TX SR 606 -- Connection Issues with Cable/ Dig Coax Audio
1. Video-out to TV: You should be able to connect the receiver to the TV with any / all of the available video modes.
However, if you don't have the HDMI connection, then the Video-In on the TV would have to be switched back-n-forth between Composite / S-Video, depending on how each device is connected to the receiver. [If the TV has 'auto-sensing' Video-In then it should automatically detect the incoming signal from the receiver whether S-Video or Composite or Component.]
2. Audio-Input to receiver: As the receiver provides only two Coax-Inputs, you would have to first assign Coax-1 to DVD and Coax-2 to Cable. Then connect the coax cables accordingly; that should do the trick and allow you to hear the cable sound over coax.
If you still have a problem then check the 'Input mode' setting; leaving it on Coax-1/2 (Auto) would be the better option. This is on pg. 50 of my manual "Specifying the Digital Signal Format".
Jan 14, 2009 | Onkyo TX-SR606 Receiver
Nintendo Wii Console Logo
60 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
