Question about Treadmill Doctor PROFORM 770 EKG TREADMILL Drive Motor
Preform 770 ekg slows down speeds up then stops completely. It runs fine with no weight on it.
Tighten belt
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: 770 ekg pro form knocks after running, comes and
Dear Sir:
I will try to help you, please be patience and carefully; you will use basics tool+Dvom:
http://www.youtube.com/watch?v=23ZgWaVEQjA&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=hKbAqvuOBS0&feature=related
http://www.youtube.com/watch?v=AFuRo2zHpCg&feature=related
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
With this you will fix it.
Thank you in advance, if you need further assistance, please reach me. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA.
Posted on Oct 23, 2011
ercupa190
  • 12223 Answers
SOURCE: My Proform 770 EKG treadmill's motor is overheating. What is the voltage that should be pulled during use? Should the walking belt be replaced if we replace the motor?
see the video and lube correctly. 2) go to my personal TIPS for motor help.3) however you must see the voltage in the plate of motor. the tolerance will be +- 10% of voltage. can be voltage continuosly or alternating voltage.God bless you6527db9f-a9f8-47a6-9208-af2b680ea3a0.jpg
Posted on Apr 01, 2013
Tighten belt on proform 770 ekg treadmill model no 291661
see the video attached, and follow the step. God bless you
Oct 22, 2013 | Epic View 550 Treadmill
Apr 01, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
Belt stops during workout and have to step offf
you need LUBE in according with the instruction manual maintenance schedule . You have a deck belt worn 2) Test the drive Belt for replace 3) Test the input voltage motor, if there are the motor need repair 4) Test the output voltage from motor board, for input main motor, if there are NOT the board is faulty.
RUN the software calibration for easy diagnose and troubleshooting. See my personal TIPS for HELP.
Apr 27, 2012 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
My treadmill work fine when i turn it on but when i step on it the blet. slows down to crawl.
What make/model is the treadmill? What speed does this behavior occur? Does the walking belt slip, while the motor and rollers continue to turn? If the walking belt is slipping then the motor belt needs to be tightened. If the walking belt slows with your weight on it, does this happen at 1-3 mph and still occur at 4-5 mph? It could be your body weight causing it to slowdown, try to increase the speed to 4 or 5 and see if it still happens. If so, is the treadmill rated for your body weight? Please be more specific.
Feb 08, 2011 | Exercise & Fitness
Treadmill slows suddenly and when i step off it starts again. only happens to me.
hi it sounds like the belt is too loose, i had the same problem when the wife uses the treadmill works perfect, untill i step on it really slows down and once i step off it runs fine. so i tightened the belt just a fraction and now works fine. check your instruction manuel it will explain how to do this. normally its two screws at the backend of the roller. hope i have helped.
Nov 15, 2010 | Proform XP Weight Loss 620 Treadmill
Belt is not the correct speed when you put ypur weight on it...slows down.have to put on 5 to get a 3 walk?
If the walking belt is overtightened, treadmill performance may decrease and the walking belt may become damaged. Remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts counterclockwise, 1/4 of a turn. When the walking belt is properly tightened, you should be able to lift each edge of the walking belt 3 to 4 in. (8 to 10 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened. . If the walking belt still slows then lubricate running deck the lube may be purchased from iconfitness.com
May 04, 2010 | HEALTHRIDER S600 Treadmill Motor Control...
After walking about 15 seconds the belt slows way down and stops completely.
The walking belt slows when walked on the walking belt maybe overtightened, treadmill performance may decrease and the walking belt may become damaged or the opposite the drive and /or running belt may need tightening. Last thing would be that the belt needs lubrication to be applied between belt and deck.
Apr 26, 2010 | Cadence Weslo 620/630 Treadmill Walking...
I have a Proform 770 EKG Treadmill jerks and squeaks
The drive belt was loose. I tightened up the motor just a smidge using a crow bar. That solved the problem.
Dec 29, 2009 | Exercise & Fitness
Bogs down
Sounds like either the belt is loose or the belt/deck need to be lubed.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
To lube the treadmill, use silicone spray and spray between the belt and deck on both sides. I hope this helps. Let me know if you have any other problems.
Feb 21, 2009 | Exercise & Fitness
Treadmill Doctor PROFORM 770 EKG TREADMILL Drive Motor Logo
158 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
