Question about Whirlpool GHW9400 Duet Washer
How do I get the relay off the CCU in Whirlpool Duet Washer?
  • 32 Answers
Not made to
repace ccu
Posted on Dec 17, 2014
aborcass
  • 2651 Answers
SOURCE: F 06 whirlpool duet washer
mcu is responsible for the f06 fault code
Posted on Mar 24, 2008
  • 4 Answers
SOURCE: Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
Posted on Mar 24, 2009
  • 220 Answers
SOURCE: What id a F28 code on a whirlpool duet washer
Can be the machine control or the motor control here is a link to the Repair manual....
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Posted on Sep 13, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Oct 16, 2009
  • 7 Answers
SOURCE: NEW CCU for Whirlpool Washer
I found this site, they actually repair the CCU for you. Mainly for the F11 Error Code. I see on the site that they have repaired 95 of them with 100% feedback.
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2#ht_2034wt_1165
Posted on Mar 11, 2010
Duet sport with an error code f01
A power glitch may have cause this error.
Try this; Unplug washer or disconnect power for two minutes.
If that doesn't work the main control board (CCU) has failed. replace it to fix the problem.
Hope this helps. Please be sure to rate my answer.
Thank you.
EEPROM ERROR
A communication error between the Central Control Unit (CCU)
and the EEPROM onboard the CCU occurred.
Possible Causes/Procedure
A power glitch may cause this error.
- Unplug washer or disconnect power for two minutes.
- Verify CCU operation by running a Diagnostic Test or any
cycle.
PUMP DRIVE ERROR
The pump driver fails to activate.
Replace CCU board.
MAIN RELAYS ERROR
One of the main relays is not working properly.
The relay might be soldered or always open.
- Replace CCU board.
Sep 09, 2014 | Whirlpool Duet GHW9150P Front Load Washer
F-01 code on a whirlpool front load washer
Frontload failure code
F-1 EEprom error due to:
power glitch
remedy: unplug washer for 2 minutes
if error still exists replace CCU board
Causes:
Pump driver failure to activate on CCU.
Main Relay stuck on CCU.
Relay points welded or open on CCU.
Sep 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer showing code F11?
The F11 code is a loss of communication between the CCU circuit board and the MCU circuit board. (CCU Central Control Unit, MCU Motor Control Unit) The most probable cause is bad solder joints on the CCU circuit board (also known as cold solder joints). This condition is also noted for causing a FdL code (door lock) The cure is to remove the CCU (inside machine, top, back, plastic case) remove the plastic case then the circuit board, it's easier that way. Then touch-up the large solder joints holding the spade connectors and the relays (5 of them). If you're not up on soldering techniques, you could take the CCU and this response to a good appliance repair shop and they should be able to help you out. Good luck.
Apr 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Fi pops up on my front load whirpool duet model wfw9200sqoo. and wont finish the cycle. unless we manualyput in rense and spin mode and somtimes unplug it, and reset spin mode,, and somtimes like today...
F-1= EEprom error due to:
power glitch
if error exists replace CCU board
Causes:
Relay points welded or open on CCU. Bummer.
DUET SERVICE MANUAL AND MORE HERE
Jan 25, 2011 | Whirlpool Washing Machines
F14 code on whirlpool duet
the central control unit{ccu}receives its data from an eeprom onboard the ccu.a power glitch may couse this error.unplug washer for two minutes.verify ccu operation by running a diagnostic test or any cycle.if you still have a problem you nead ta replace tnhe ccu.
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
After pressing the pause button on my Whirlpool duet washer I got an F01 error code. From checking around online, it seems that this happens to alot of people when they use the pause button. Would this be...
Error code F01 =EEPROM ERROR
PUMP DRIVE ERROR
MAIN RELAYS ERROR
Verify CCU operation by running a Diagnostic Test or any cycle.
Replace CCU board.
Replace CCU board.
Nov 11, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
My whirlpool duet washer has code F-01, and will not start.
After about year and half Whirlpool duet sport gave F01 error code. The technician manual is located under the lower front panel. There are three possible reasons for F0:
1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me).
2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer – it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force (watch “Armageddon” movie for more instructions on it). Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following.
3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU.
Good luck and please rate
Sep 16, 2009 | Whirlpool Washing Machines
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing codes
you have a communication problem between your door lock and your ccu board. Are you hearing a click click click before it fails? If so this is a relay inside your ccu board. Replace the board this will solve your problem
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader door locked
My Tech sheet reads F01 is a EEprom Error ? Unplug washer or disconnect power for at lease two minutes. EEPROM ERROR A communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU occurred. Possible Causes/Procedure ■ A power glitch may cause this error. ? Verify CCU operation by running a Diagnostic Test or any cycle. PUMP DRIVE ERROR The pump driver fails to activate. ■ Replace CCU board. MAIN RELAYS ERROR ERREUR - One of the main relays is not working properly. Possible Causes/Procedure ■ The relay might be soldered or always open. ? Replace CCU board. Good luck and let mre know what you come up with
Sep 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
62 people viewed this question
Dan Webster
Dan Webster
Sal De
