Question about Refrigerators
Compressor won't run fan works. What should I check?
  • Refrigerators Master
  • 10,263 Answers
Check the start capacitor and the thermal overload on the compressor. Make sure the thermostat is applying power to the compressor first.
Posted on Dec 06, 2014
My ac fan works but the compressor won,t kick on
The fan on the condenser or air handler? Check the capacitor on the condenser. If you don't have a meter that does uf you can take the amp draws of the comp multiplied by 2650, divided by the voltage between com and herm on the cap. If cap is good be sure compressor is not off on thermal overload, cool with water hose, careful to not soak electrical. If not hot and cap good , try hard start kit. If still no compressor ,ohm compressor, com to start plus com to run should equal start to run on ohms. Hope this helps.
Apr 04, 2016 | Heating & Cooling
Why my A/C condenser fan won t stop running, dodge ram 2008
To clarify, the compressor and fan will run in defrost mode. The compressor and fan runs to dry out the air blowing onto the windshield.
Now if the condenser fan runs in "heat" you may have a problem with the fan relay or the main controller.
Sep 25, 2014 | 2008 Dodge Ram Pickup 1500
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
It freezes but won't stop
as long as the compressor is running on your freezer the longer the fan runs has to too cool the compressor . . .thermostat problem
Jan 11, 2013 | Boating
Fan won't run / won't cool
It may have a faulty compressor relay or overload, best to change both at the same time. It's either that or a bad compressor.
Jan 06, 2018 | Kenmore 73055 Air Conditioner
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
I have a Goodman gmp100-3 furnace and a/c unit. The outside fan and compressor are working but the inside blower won't come on Any Help ?
try putting thermostat on fan only see if it runs,if not check for any broken or loose wire on the thermostat wire take cover off and check.
Jul 17, 2011 | Heating & Cooling
May refrigerator freezer and refrigerator won't get cold
My first reaction would be to look inside the freezer for ice buildup or if cooling at all. Check that freezer fan and condenser fan are also working when the compressor should be working. Then if everything is working topside as it appears to should be working but not cooling I would pull the refrigerator away from wall, unplug power, remove lower cover over compressor and then feel top of compressor with my hand to see if warm, cool or too hot to keep hand there. Here is a photo of compressor parts=> MSD2756G Compressor Components In that photo there are three parts I want you to consider as possible reasons if compressor is not running but very hot to the touch.A small percentage of the time it is the compressor itself that is defective and it would pay to do the test of compressor listed on this page HERE and listed near end of page as How To Check For A Burned Out Compressor.Tell me if both fans are on because that tells me the thermostat is good and calling for cold. Here are the most likely reasons your compressor may not be starting=> 12002794 Relay and Overload Kit, and 65889-4 Run Capacitor
I will be here to answer any questions you may have, Thanks, Sea Breeze
Jun 12, 2011 | Maytag MSD2756G Side by Side Refrigerator
My freezer is no longer freezing food- why?
I looked up your model. This is a self defrosting model which features a fan motor for the compressor and the evaporator. If either of them 2 fans is out then the freezer won't work well. That is the first thing I would check. If only one of the fans is gone out then replace that fan and rock on. If Both fans and compressor are not working then hunt down the timer. It may be stuck in defrost mode. The timer is nestled up behind the cold control and light bulb inside the nice little console in the fresh food compartment. Look under the console for a hole about the size of a dime. Inside that hole a timer advance. Use a flat blade screwdriver to advance the timer till you hear the compressor and fans come on. If the timer is fine the next thing to look for is ice buildup inside the evaporation compartment. If you see that then the defrost heater and termination thermostat needs to be replaced.
If both fans operate ok but the compressor is not working then I would remove and inspect the compressor relay for wear. The cold control would be the next thing to take a look at. If it is open the compressor and fans will not run but the inside light will work.
May 18, 2011 | Frigidaire FRT17B3A Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
