Question about Cell Phones
The usb plug will not work, only charges phone how do I fix that
    Problem Solver:
  • 19 Answers
You need to download a driver.
Posted on Dec 06, 2014
Where is place on charger to plug USB cable?
AnUSB cable can be plugged into a n USB charger. The charger has a USB port that the cable plugs into, it is usually compliant with most USB charging cables. If your charger has a fixed cable, i.e. for a single make, you cannot fit a USB charging cable.
Most computers now also have the charging facility even when the computer is switched off.
Jul 03, 2015 | Cell Phones
MY alcatel FIERCE ONE TOUCH CELL PHONE WONT CHARGE UP LIGHT LIT BUT NO CHARGE AND WHEN I PLUG IT TO MY PC USB UNRECOGNIZED ?wHAT DO HAVE TOO DO SO THAT I CAN FIX THIS PROBLEM WITH MY alcatel FIERCE ON
Have you tried using another charging cord? There could be a fault there. If the cord is the only one you have, see if you can find a friend with the same phone to test whether theirs works for you, then buy a new cord if that's the problem.
Sep 21, 2014 | ALCATEL-LUCENT USA INC One Touch Fierce 4...
My i phone 4s wont charge past 70%
The First solution is that plug and plug tour Charging USB cable. it should work.
nd change the USB Charging because the USB cable pin become week after some time. and also download Battery app for ur Iphone it will tell u every thing. :)
Dec 10, 2013 | Apple iPhone Smartphone
My samsung gt 15500 won't charge up. It was working fine 2 days ago and yesterday i brought the usb lead to work with me to charge it with my computer. Nothing happened when i plugged it in so i...
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
Success.
May 12, 2011 | Cell Phones
My Lg Xenon is not charging properly. It says full battery after i charge it but then when i talk to someone on the phone after about 20 mins it starts beeping saying it has low battery and eventually...
I had a similar problem with a brand new LG Xenon. The battery charger said it was charging but the phone didn't charge. When the battery life on the phone died the phone would not turn on with the charger. I plugged it into my USB port on my laptop and the phone fully charged for real. I got 4 days before I had to recharge it again. Try USB cable to a PC to charge phone. Charger is probably bad. I am getting a replacement and will see if that works.
Oct 21, 2010 | LG Xenon GR500 Cell Phone
Z550i when i am puting in charging, it is promting as USB port, and it is not charging at all
If you the mobile phone screw driver kit open the cell phone by removing the screws at the back side of the panel you can find the charging connector if plug out the charging connector it will come separately after that rub that connector contacts in the cell phone board by using a normal eraser after finishing it fix the mobile as it is it will work.
Oct 22, 2009 | Sony Ericsson W200i Cellular Phone
Cect i9 wont charge battery is fine
the issue is with the wall usb ac adapter just replace it (with a better quality one) and it should work, you can also charge the phone using your computer. Well... this fix worked for me.
Dec 10, 2008 | Dual Electronics CECT P168 Cellular Phone
USB Connection
I fixed my problem of my HTC touch not Syncing with my phone thru the USB cable.
Go to
Start, Settings, System, Power, Advanced and select/enable the option that says "When device is turned on, do not charge the battery when connected to the PC."
If it still does not work at first then disconnect the USB from your PC/device, wait a few seconds and then plug it back in.
You'll suddenly see your phone and your PC syncing.
Hallelujah!
-Nina Sarkar.
Jan 24, 2008 | HTC Touch P3450 Smartphone
Broken USB Port on T-Mobile MDA
My daughter's MDA had the same problem. I just opened the phone and soldered the legs on the corners back to the board. You have to bend the pins on the back of the plug down to make contact with the board, before you solder. Place plug back down and line it up with contacts. If done right should work as normal. Hope that helps
Jan 16, 2008 | T-Mobile MDA
USB Cable and charging problems
Try checking the usb cable. Some usb cables aren't made so you can charge your phone. Believe it or not but usually the cheaper cables are the ones that work for charging my motorola razr v3 phone. If that doesn't work, check to see if you didn't mess up the interface when you plugged into the phone.
Dec 08, 2006 | Motorola Mobility RAZR V3
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
