Change battery in life cycle 5500
No access to the battery case without taking entire cycle apart
  • 1,243 Answers
Bad news. If you don't wanto do it, have someone else do it.
Posted on Dec 07, 2014
How do I change the light in gas dryer
there is likely an access spot on the back of the dryer that allows you to change the bulb without taking the entire dryer apart. the most you may need to do is remove the back panel of the dryer to access the light socket. it should either pop out with a clip or twist out 1/4 turn like the headlamps of most cars then you can replace it with a high temp appliance bulb as they last longer than standard bulbs
Nov 12, 2014 | Kenmore 74602 Gas Dryer
I dropped my aiptek IS-DV camera and now the joystick that controls the menu functions doesn't work. Is there a way to fix this without buying an entirely new camera?
The only maybe on this is the joystick is out of alignment with the touch points. You will have to take the camera partially apart to investigate if this is the case.
Jan 29, 2014 | Aiptek IS-DV Memory Card Camcorder
How to replace a battery on the life fitness 5500 stepper
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Some of these units have 9 volt battery found in the back of the console. Also some of these units that do not have the 9 volt battery, still used the same console shell. If you have an empty spot with no wiring in it, then you are fully relying on your external power supply. I am attaching a link to the picture of the back of the console I am referencing. CASE BATTERY DOOR 0K36 01187 0001 SPORTSMITH net
Dec 08, 2013 | Life Fitness Exercise & Fitness
I have a Bright Future for Baby Melanie wooden baby crib (product # 343-7407); how do you unhook the brackets in order to lower the mattress without disassembling the entire crib?
A:You remove the dropside by removing the bumpers and lowering. Then you loosen the screws on th wooden bar under the mattress base without taking apart . If necessary loosen the screws on the frame, but should only be necessary if the mattress base was put in with the straight hooks facing you. In any case you should not need to completely take apart, but still a pain!
Aug 03, 2010 | Toys
Mouse dead and wont charge. is there a battery to change?
I have the same problem, called Logitech and they were no help at all. I tried to open the casing to see if there was a replaceable battery and the entire casing broke, now its useless.
Apr 15, 2010 | Logitech Cordless Mouse
Can't get any power running on my 5500 hr life cycle
You have to start pedaling to get it to start up, some times you have to pedal pretty fast to get it to start up
May 27, 2009 | Life Fitness 9500RHRT Recumbent Bike
Accessing left lowbeam light to replace connectors
Most head light bulbs are easily accessible from the rear, inside the engine compartment. Sometimes it is easier to move the battery for better access. Remember not to touch the bulb as it will greatly reduce it's life.
May 09, 2009 | Saturn Outlook Cars & Trucks
97 ford contour gl, info on transmission pan filter installation?
trans filter can only be replaced by taking the trans apart. absolutely not worth it.
Apr 10, 2009 | 1997 Ford Contour
Change the battery. It is a 9v battery behind the small door on the back of the display panel.
Mar 15, 2009 | Life Fitness 9500RHRT Recumbent Bike
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
