Induction heater not heating - Heating & Cooling
    Novelist:
  • 135 Answers
As Johnney 5 would say in the movie Short Circuit, "need input, more input." No model number mentioned. I'll pretend to be customer support, Is it plugged in (really?), does the outlet have power, is the cord damaged, is it turned on (yep they really ask), has it suffered damage. Electric heaters have a safety switch in them that breaks the circuit if it tips over, the heater could be leaning or the switch is bad. The thermostat could be open or set too low. A final cutoff over temp switch could have opened, these have to be replaced after the defective thermostat is replaced. Then comes the infra-red tubes if it's that type, or the heating element if it's that type.
Now if you are talking about a induction cooking element then the representative icon is misleading. That's another issue. If it's a cooking issue, I'd say it's more likely the control module or the magnetic coil.
Posted on Dec 06, 2014
Cook top not heating up unless i put it on high
It's probably the control. Some of them have little heaters in them that heat up a bi-metal which cycles the element off and on to get infinite heat control. That's usually the problem. The last one I replaced cost about $20.
Jun 24, 2016 | Electrolux 36"" Induction Cooktop
If induction cooker does not heat the pot
Induction-compatible cookware contains contains iron or has a layer with magnetic properties. Cast iron, enamel cast iron and most types of stainless steel cookware are all induction compatible (But not all types; for instance, All-Clad's MC2 line, which is made of aluminum and stainless steel, is not induction compatible)
Nov 25, 2014 | Winco Professional Induction Cooker -...
Pressure cooker is not heated on induction cooker
Likely the pressure cooker base is not induction-compatible. This is the case with all aluminum pressure cookers and some older stainless steel models. Your cookware store will have a small metal plate that you can put on your induction burner to heat non-induction compatible cookware.
Nov 10, 2013 | Home
I have a Toyota Rav4 2002 code 1155and1135 for fuel/air
code p1155 refers to heated oxygen sensor(HOS)-RH front heater circuit malfunction==causes -wiring--HO2S-- ECM. Replace the oxygen sensor.
Code p1135 refers to heated oxygen sensor(HO2S) -LH front-heater circuit malfunction==causes --wiring--HO2S--air induction system--fuel pressure--injectors--ECM replace the o2 sensor and have a pressure test done on the fuel manifold to check for pump/regulator/ filter problems.
Sep 06, 2013 | Cars & Trucks
Hello. I have a new hotpoint CIO644 induction hob but when I turn a hob on, and put a pan of any size on the hob, it start ticking. The ticking stops when I take the pan off. The display shows the setting...
Hi
I'm not sure that you really have a problem as with induction hobs you need to put your pan (metal only) with the ingredients in it on the hob before switching the heater on.
it is the pan which will get hot, the ticking may or may not be the pan heating up.
Try it with water only in the pan and see if it works.
Dec 20, 2010 | Hotpoint Ovens
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
AEG 50740
Some machiens front bottom plastic is a "bump" off type (push sideways clip) Some machiens have electrical elements but some (later models) have inductive heater that fit in line with thewater pipe feeding to the main top washer arm. The electrical connection to this inductive heater could be loose or the inductive heater itself could be faulty
Sep 12, 2009 | AEG 24 in. Favorit 40850 Free-standing...
Furnace start buts shuts off
It sounds like you have an obstruction in the exhaust vent. Thats why when you bybass the pressure switch it runs ok. Steve
Dec 15, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
