Question about Sony Audio Players & Recorders
I've lost all sound on my Sony DHC MD373 hifi system. LED Info shows cds. radio etc are all working but no sound and not even a crackle. Any ideas as to what went wrong. Sound failed after I plugged i
Checked all settings and connections and tried different cable for aux to no avail
  • 28 Answers
SOURCE: Sony DAV SA30 dvd player
Hi From the symptoms, you mentioned, ie playing CD's ok., Mpeg decoder chip is faulty. The new one supplied is a modified type. IC207, part no.6-707-406-01. Good luck. Capital98
Posted on Feb 14, 2007
  • 3 Answers
SOURCE: Can't play AUX inputs through Panasonic surround sound
Check the TV audio output setting. There may be 3 settings for audio output. Fixed/variable/none. Try all of the settings, and see if you get your audio back. If not, try a different cable between the TV and DVD player. I suspect this is a red/white RCA audio cable.
Posted on Dec 14, 2007
SOURCE: crackling from surrond sound
I have a SONY home theater4.gif system, HT-C800DP, there is a crackling sound when playing DVDs - it is almost as if the unit overheats. Is there any solution to this? Sometimes I cannot even finish a DVD as the noise gets very loud.
Thanks,
Cindy
Posted on Jan 05, 2008
SOURCE: sony DAV-S300 NO SOUND
Had the same problem. I traced it to the main sound processor chip. This is a large surface mount device. The easiest (and cheapest fix) is to search e-bay for a broken DAV-S300 but with working sound. The one I found has a broken disc tray and was generally scruffy. It was cheaper than buying the chip itself. Then change the main PC Board.
Posted on Jul 16, 2008
uge44
  • 226 Answers
SOURCE: i cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Posted on Nov 20, 2008
System DHC-FL5D shows a red light near power on switch but won't start
inside, some flap cable may have been disconnected. get it serviced. also let me know if you want to sell.
Apr 25, 2015 | Sony Audio Players & Recorders
Sony DHC FLX5D hifi system shows a red light near power on switch but won't start
You opened the case to check the fuses, do that again and look at the devices that resemble small cans. See if the are bulging, leaking or exploded.
Jan 06, 2014 | Sony Audio Players & Recorders
Sony DHC-MDX10 Whitout sound
hello it sound like the output transistor could be the problem also check any capacitors for swelling and any dry joints round the transistor
good luck
shaun
Aug 23, 2009 | Audio Players & Recorders
Sony DHC-MD333- Is there AUX to attach to laptop??
the lines in for the tape deck would likely work. or look for any other inputs on the unit.
you will need a mini (headphone) jack to stereo RCA cable's. your local radio shack sells them. walmart also carries them.
you can also use an headphone extension cable and coupler then connect the coupler to the headphone to RCA cable.
picture of it here
http://budgetgamer.files.wordpress.com/2008/08/audio1-rca-to-headphone.jpg
Aug 06, 2009 | Sony DHC-MD333 Shelf System
Radio presets
I have the almost identical MD373. Tune to the station you want, press MENU/NO, right arrow (either one will work) to "P. Memory", press ENTER/YES, use arrow keys to select the number you want to assign to, then ENTER/YES again. This system won't let you assign to a number higher than the first unused preset, so the first preset must be number 1. Options to erase one or all presets are on the same menu.
Feb 02, 2009 | Sony DHC-MD333 Shelf System
Mhc-gnz88d (sony hifi DVD System)
5e592bd0-46d6-403f-ab4a-21969e3345d5.jpegI have a SONY MHC-GNZ88D Mini Hifi System. Everytime problem while play a CD or a DVD. The problem display "DESK ERROR". CD & DVD working but Next, Fwd, Stop etc buttons are not working.please help me.
My cont number - +91-9031257594 Nazish
May 21, 2007 | Sony Multi-System Mini Hifi Systems / DVD...
Crackling from surrond sound
Thanks,
Cindy
Aug 14, 2006 | Sony HTD-C800DP System
75 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
