Question about Kenmore Washing Machines
I have a kenmore elite top-loading washer, a quarter got stuck in between the ring and tub. I got it out but it looks like the ring is rubbing on one side. will it be ok or should I replace it. is the cap and ring easy to remove?
    Master:
  • 560 Answers
Check for other things jammed in there.
Posted on Dec 06, 2014
Dime stuck in tub of washer of tub won't agitate
try tweezers and a thin bladed knife to get it out.daughter just had same problem with her Maytag.
Oct 03, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
I have a top loader kenmore elite washer t won't finish a load without rocking
You may have an item between tubs:
Service Manual
If this ain't yer model look around the blog for yours. American made stuff is what I do. Cheers
Jun 21, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Elite top loading washing machine that gives me the error code F51 incessantly. Any idea what this means?
The F-51 error code on this washer indicates that the machine control board in the console detects a motor RPS (Rotor Position Sensor -- tachometer) failure. This can be caused by a number of different problems. You could have a bad RPS sensor, a failed motor, a wire harness connection problem or an item stuck between the spin basket and the outer tub that is interfering with spin basket rotation. A water filling problem could also cause this code to be displayed since the basket would have excessive friction if water is not entering the machine properly. With the washer off, spin the basket to see if it rotates freely. If you detect resistance or suspect that an item is stuck between the basket and the outer tub, you will likely need to remove the basket and check this area.
Oct 18, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My washing machine is causing holes in the clothing, whether it be 1 item or a full load, but it does not happen all the time, can this be repaired
sounds like you might have a sharp object stuck in the tub and its only coming out every so often i would recomend taking the agitator out and looking throughly in the tub....rub your hand around the tub spin the tub a few times by hand and check several times with your hand.happend to me one time , ended up a small screw was loged in the tub
Dec 30, 2009 | Kenmore 22642 Top Load Washer
Where do I Find the model number on my Kenmore Elite Top load washer?
The model number on Kenmore top loaders is usually printed on a nameplate along the wash tub rim opening under the washer lid. The model number has 8 digits with a prefix of "110". If you cannot locate it, please let me know. I hope this helps you.
Nov 30, 2009 | Kenmore 24032\24036 Top Load Washer
My kenmore elite washer does not drain; 2002 Top load.. It does spin, but it is not draining the water
Check the drain hoses and pump for blockage. Look carefully if not obvious, I had one with a quarter in the drain hose and it acted like a flapper and gave intermittent symptoms.
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Cant get my washer back together.
Make sure the rear seal has not turned in and become curled into the path of the rear ring on the drum.
Oct 04, 2009 | Kenmore Elite 45986 Front Load Washer
I have a top loader kenmore elite washer that is leaking. The service guys have replaced everything from valves, tub ring and the fabric softner dispenser but its still leaking Help
Hi, Did they check the pump seal or the hoses. Does it seem to leak from the front center? Is it leaking while filling or during agitation or spin cycle? Are you getting water every load and is it a little water or a lot?
Please forgive all the questions, I have to ask.
Questions I need to ask in order to assist you as best I can.
Vic
Jun 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Squire
