Question about JVC Televison & Video
HOW DO I FIX THE DISPLAY OF JVC TV? IT SHOWS PICTURE BUT THE COLOUR IS BAD. I HAVE DONE SEVERAL COLOUR SETTINGS WITH NO RESULT, DURING THE ADJUSTMENT, THE PICTURE CAN TURN TO SEPIA GREEN, SEPIA BLUE E
PLEASE HELP AND TELL ME THE COMPONENT THAT IS ACTUALLY CAUSING THIS PROBLEM FOR ME TO FIX IT. THANKS
    Scholar:
  • 124 Answers
This sounds like a bad cable or connection. Swap out the cable with a known working one and see if that helps. Next, wiggle the cable nearest to where it connects to each device and see if that recreates the issue. If so, your cable either has bad ends or your device has bad ports/connectors.
Posted on Dec 06, 2014
SOURCE: No picture - power indicator shows red
It will have to go into the shop! Our LG Plasma did the same thing twice now.
Posted on Apr 01, 2008
pazman
  • 81 Answers
SOURCE: there is no red in the picture
you might have it in component cables in the rear and one of them is not all the way in. sometimes these cables are a bit hard and may think that its all the way in and its not. check it out.
Posted on Apr 09, 2008
SOURCE: JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Posted on Jul 26, 2008
electronick
  • 505 Answers
SOURCE: LG 42PX3DCV 42 in.
Pixel misfiring (diffusion errors) are caused when the tv is not firing and erasing the pixels correctly. It can be caused by a number of things, usually a voltage or waveform is off somewhere. If you just bought the tv, return it and get another. If you are out of warrany, you can remove the back panel and run the tv to check the voltages. Don't touch the heatsinks! they're electrically hot and will zap you.. the voltages are labeled on the back of the plasma panel with a sticker. first check Vs and Va. sometimes you can check -Vy, Vset, Vscan and others if labeled on the board. If you have to adjust waveforms you need a very $$ o-scope and should get qualified technician to adjust. If a board is bad, its likely your power supply or Y-sustain pcb, and less likely your Z-sustain or contol (logic) board.
Posted on Dec 07, 2008
  • 92 Answers
SOURCE: westinghouse LCD TV - broad vertical green and blue lines
try to go to the factory reset and see if that helps. If not, you can then check your connection. if you use component (red, green and blue for video and red and white for audio), make sure all the color matches when you plug it in. if everything have been checked then you need to replace the main board and it should correct the problem.
Posted on Jun 22, 2009
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Can't get picture too get any brigther ,,have bright adjustment all the way to bright
There are several brightness adjustments on this TV. Download the manual from the following link. Set the size to a readable %. Then click "Edit", then "Find", and type "bright", then click "Next" repeatedly to review all your brightness options. http://www.manualslib.com/manual/82813/Jvc-Lt-32e488.html#product-LT-37E488
Jun 28, 2014 | JVC 37" Lcd Tv - Widescreen [lt-37e488]
My Xbox 360 shows a grey screen, the sound works fine and i do have picture
Hey dude, I had this problem and found a solution on another website. Basically, I had either changed the display settings on my tv, or it had done it by itself or my new ps3 had done it or whatever, but to fix it I went into the TV menu, went to display options, on my tv it has something entitled 'Colour system' I changed that to PAL-60 and I now have colour, just to give you an idea of whether you have the same problem, try setting your x-box display to pal-50 and see if that shows colour (if it's easier to do), if it does then try then solution above! Hope it helps!
Mar 13, 2012 | Microsoft Xbox 360 Console
Jvc hd 52g787 my position adjustment in my menu will not highlight so i can adjust picture over to the left. help please
Hello
Just make the picture status button on the remote control and get the display setting to its factory mode.
The VIDEO STATUS button gives you a choice of three TV picture display settings, including a
display of your own preferences.
Standard - Resets the picture display to the factory settings.
Dynamic - Heightens contrast.
Theater - Gives a rich, film-like look to video. (AV-27D303, AV-27D203 and AV-20D303 only)
Sports - When you watch a sports program. (AV-27330, AV-27320 and AV-27S33 only)
Press the VIDEO STATUS button repetedly to get these choices.
Aug 13, 2011 | JVC AV-27750 27" TV
My jvc tv is showing everything more green than it should be, the colour settings dont help, even with colour reduced to zero it still is green
A common problem with older sets that have weak tubes. The auto colour tracking runs out of tollerance and cannot cope anymore.
Not a lot can be done, maybe turn the green A1 down or cathode voltage up a bit, perhaps that will get a bit more life out of it.
Dec 23, 2010 | JVC Televison & Video
Picture on tv JVC 27" AV-27530 is getting to dark to enjoy. During dark scenes you can't see much. Have tried adjusting controls and settings to no avail. Any solution greatly appreciated.
I have the AV-27S33 model and in the rear to the right of the inputs are two slits and inside these slits are two screws. The top screw is the focus,the bottom the brightness.Your tv is a different model but it may have this same adjustment,if it does try turning the bottom screw to the right to increase the brightness.
Jun 11, 2010 | JVC AV-27530 27" TV
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
JVC AV-27S33 27" Picture
I've found several bad solder joints on the neck board of my JVC 32' leading to the exact same issues as yours. Inspect the Driver resistor solder on the neck board.
Dec 10, 2007 | JVC AV-27S33 27" TV
JVC AV-27230 27"
Mike,
Go into menu settings, closed caption and turn off closed caption... What you're seeing is the text box of closed caption.
Bill
Nov 23, 2007 | JVC AV-27230 27" TV
Hitachi Standard T.V.
Some of the problem could be a weak or damaged picture tube - especially if it encountered rough handling in the move. Other possibilities are bad capacitors in the power supply and deflection circuits which are common with this aged set. No adjustments come to mind that could permanently fix these symptoms.
Feb 11, 2007 | Hitachi 27UX01B 27" TV
Televison & Video Logo
61 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
