Question about Electrical Supplies
I have one of the first generation room as, not sure of model # but need a battery pack.. . Part #02002. Where can I find this part?
    Problem Solver:
  • 20 Answers
Personally I'd try Batteries Plus. The images and descriptions should help. If you have a Batteries plus near you taking the battery in the store is a plus. If not, here is a link to their website and the Roomba Category. Roomba Original Series iRobot Home or Electronics Battery Batteries Plus
Posted on Dec 06, 2014
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Jan 23, 2016 | Ryobi Garden
Having problems with 35,000BTU Williams Wall Heater. Have changed thermostats twice using the 986-1R. Heater not coming on when dips down to lower temp and not shutting off when on just keeps runnin
Wall furnaces operate on millivolts of electricity, about 750 mv which is only 3/4 of 1 volt, 1000 mv being 1 volt.
The electricity is created by a pilot generator that is in your pilot assembly, the pilot generator has a hot end in the pilot flame and a cold end that is not in the flame, this temperature differential is how the pilot generator creates the 750 mv or 3/4 volt.
As this is not much voltage, it is very easily disrupted by a patina on the connections, wires and terminals, I would clean them all shiny new, this often will fix it, if not try jumping the 2 thermostat terminals that the thermostat wires are connected to, this bypasses the thermostat and wiring so if it runs you know why it was not before. The pilot generator likely needs to be replaced, you can test the gas valve with a AAA battery with a wire taped on each end, then wire the battery to the gas valves terminals that the pilot generators wired to, this simulates a good pilot generator.
If the system operates via battery do not use it this way it is not safe as no pilot safety exists in case the flame blows out! gas will still flow due to the battery powering the heaters valve, it is for testing only, if it works by battery then the pilot generators bad.
Jan 07, 2015 | Williams Wall Heaters: 35,000 Btu/hr...
My champion generator 9000 watt breakers keep poping
How much time have the Generator?
looks like batteries needs to change it.
Aug 11, 2014 | UPG 12V 18Ah Champion Generator 9000 7000...
How to fix power button
I could spend a lot of time describing how you heat round the screen, pry it off, move battery, remove 2 screws holding button assembly, relocate or shim button and reassemble it, but it's easier to point you at someone else's good work and some videos (thanks to those people)
Fix Power Button iPod Nano 6th Generation
Nottingham Solving power button problem in iPod Nano 6th gen The Computer Room...
iPod nano 6th gen power button problem The Computer Room How to
Jun 27, 2014 | Apple Ipod Nano 6th Generation Silver 8 Gb...
Not enough steam
This may either be because you may not have the correct generator(either the wrong size model or the wrong voltage generator) or the heating element may be damaged, although this would be unlikely being it is a new generator. Go to www.mrsteam.com and size your room. Remember it is important to have the exact room dimensions AS WELL as material of the wall (ceramic, porcelain, natural stone etc) due to the fact that wall material is largely where you have all your heat loss and units have to be sized accordingly to the wall material of your shower otherwise you would surely end up with the wrong size.
Feb 11, 2014 | Mr Steam Ms400e Steam Shower Generator
Why are there different batteries for models with manual transmission vs. automatic transmissions?
Only reason for different batteries would be because of size and placement. An auto trans is larger than a manual trans and often leaves little room for a battery underhood. Auto engineers try to pack so much under the hood it seems like the battery is forgotten and just stuffed in wherever there is room. Some even stuff it under the seats or in the trunk now. Normally a manual trans will not require as powerful battery as an auto. Basically any battery similar rating to auto will work in manual. Usually the only issue would be the actual physical size, length, width, height.
Nov 01, 2013 | Cars & Trucks
Battery drain in a few minutes
Sounds like alternator (generator) is at fault. Voltage at battery should read about 14 volts when charging. Sometimes onlythe regulator (diode pack) on alternator is at fault some can be changed without having to have a new alternator (not sure about yaris)
Aug 24, 2013 | Toyota Yaris Cars & Trucks
Basically we are getting a static sound every now and again. I think it has to do with the wireless signal because it only happens when the room is filled with people not when the room is empty. How can...
Try moving belt pack around on person (speaker) and try moving receiver closer to person speaking, also keep receiver elevated, off floors and antennas need to be up. Wireless signal is like "line of sight" and if there's a ton of obstructions you're cutting signal strength. Also make sure you ALWAYS use fresh batteries, weak batteries will do the same.
Feb 25, 2011 | Sennheiser MKE105S LAV MIC w/PIGTAILS -...
Dropping cylinder at 10rpm and possible generator /stater problem
It seems the charging system of your bike is not working
Recharge the battery and thn fit it in the bike and start it and check the charging rate.
Remember with lights 'on' it drains power from the battery butthe charging system of theengine takes over i.e. if its working alright, with your explanation, its for sure the charging system is not functioning.
Chekc the altenator and the rectifier.
Sep 08, 2009 | 1994 Suzuki GSF 400 Bandit
Electrical Supplies Logo
29 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
