Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Does liquid glass work on transmissions its a 95 Chevy 1500
Front seal leaking
    Master:
  • 416 Answers
If you plan to permanently ruin your trans use the liquid glass
if it is a new transmission and leaking right from the start, there's most likely nothing you can do other than replace the torque converter support bearing behind it and the seal ,
if its been rebuild, I have seen the pump bolts loosen due to improper torque and the symptoms are the same and no sealer will work,
if its been a good trans and just needs some help, give it a fluid change with a new filter and add lucas trans seal and anti slip to the system and you should be fine in no time, maybe even another 10K miles.
Does liquid glass work on transmissions its a 95 C - 25310062-303l1024csjy330g3zaxemfc-4-0.jpg
Posted on Mar 26, 2015
    Sergeant:
  • 406 Answers
Not normally liquit glass is used as a solid seal not on someting that turns on a shaft..give it a try..but most likely will not work..
Posted on Dec 06, 2014
How to install front gasket for transmission inside front of transmission on 1997 chevy pu 1500 4.3 6 cylinder
Lilia,
You have a front and rear seal on a transmission, if you are speaking of the front seal,the transmission will have to be removed to get to it.
If you are speaking of a different one, please repost and I will try to help you.
Thanks, Robert
May 04, 2017 | Chevrolet 1500 Cars & Trucks
My 95 mercury grand Marquis is leaking transmission fluid got the transmission fluid gasket replaced but it's still leaking what else could it be.
Hello , You could have a leak at the transmission dip stick tube o-ring, the front pump gasket, the torque converter seal , the transmission output shaft seal or the transmission oil cooler lines. I suggest you put the car on a lift to make it easier to see where the leak is coming from.
Nov 05, 2015 | Mercury Cars & Trucks
What works best as a temporary fix from a front seal leak in tranny chevy 1500 95
Dec 06, 2014 | 1995-1997 Chevy 1500 Truck Ignition...
I have a 1993 Chevy WT1500 pickup with a leaking transmission.
did you use lock tight on the torque converter bolts when installing them? it may be coming loose and ruining the seals. It doesn't take much. You may have some kind of buildup on your output shaft or a bur of some type that is cutting the seal. Check the outside hub of the torque conv. for roughness or spurs. The seals should work if everything is done right.
Feb 01, 2013 | Chevrolet Cars & Trucks
Oil leaking trans 1999 chevy S10 replaced torque converter seal leaks at front
ou may need to remove the front pump and replace the seal on the pump and the converter seal as well
Aug 08, 2012 | Cars & Trucks
My 2003 chevy silverado is leaking transmission fluid between the engine and the transmission what could be the problem thank you
Probably the front seal on the transmission between the input shaft and the torque convertor but it could be the pump seal. Either way, the transmission has to be removed to repair it.
Jun 03, 2011 | 2003 Chevrolet Silverado 1500
95 chevy 1500 v6 2wd. the transmission is
lower planetary gearset is shot. They are a weak spot in this trans. Rebuild or replace trans... they generally make alot of metal when they fail
Apr 18, 2010 | 1997 Chevrolet K1500
95 ford escort transmission leak
Dont waste your time and money trying to use a transmission stop leak product, they don't work on large leaks, you say the leak is excessive in this case the you must remove the transmission to access and remove the torque converter, after you have removed the torque converter carefully inspect the torque convert imput shaft for wear and also you will need to visually inspect the transmission front pump bushing for wear also, I have seen it all to often people just replace the seal thinking it was just a seal failure, well more times than not there is a reason for seal more than just the age of the seal, excessive wear on trans pump bushing and torque converter imput shaft is usaully the cause, check and repair those as good practice during this repair unless you just like to do the repair over again for free... also check the torque converter run out, sometime when they are repaired they are welded back together somewhat crooked which will cause it to spin off of a true center, this will cause immediate damage to transmission. Check also your engines crankshaft end play for looseness this can cause wobble which will transfer to transmission causing this problem as well... do the repair thouroughly and who ever does it for you have them check all that I listed and you should get a good repair which will last without issues.... please rate my help thanks...
Aug 08, 2009 | 1998 Ford Escort
Transmission leaking nearfront changed front seal still leaking transmission fluid
Most transissions front leak is the front seal but it can also be the pump gasket over flow expelling fluid.To save money you should first change the filter. Them if it still leaks pull the trany and pull the front pump and change the gaskets and seals. If this does not fix it then you should seek professional help.
Jun 20, 2009 | 1999 Chevrolet Silverado 1500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
69 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
