Question about GE Lands Phones
Need an Adapter [9VDC] for this model, can't find
On line search & GE manual search
    Sergeant:
  • 406 Answers
They all are pretty much the same..any 9 volt should work..see if you can find how much MA power your origional has.would be something like MA400. MA500. Etc. the more MA the longer the charge will last..JUST MAKE SURE IT IS NINE VOLTS.. GOOD LUCK
Posted on Dec 06, 2014
Hi, i need to know the exact power plug so i dont have to run the pedal on battery power.i know i need a 9v power supply but i dont know the size of the jack that goes into pedal..many thanxs..
Unfortunately, battery jacks and plugs similar to the type you're describing do not have any real standardization - unlike the outlets and plugs in homes and businesses have.
You best bet is to either bring the plug / jack to a shop to match it or contact the instrument's manufacturer to obtain the connector specs for physical dimensions
Be sure to obtain the power requirements in either watts or amps so that you can obtain a power source capable of delivering what you need without overheating during longer periods of use. Adding 25% to 50% more amps or watts to the minimum required should provide years of trouble free service. Example: 9VDC at 50 watts should be supplied by a 9VDC 62 watts or even 75 watts; or in the case of a rating of 9VDC at 6 amps should be supplied by a 9VDC at 7.5 amps or even 9 amps. With DC powered devices, make sure you observe proper polarity! Good luck!
Mar 16, 2016 | Music
I need to find a new ac adapter or at least the model number for it
Hello
buy a 9VDC output AC adapter. You can use anu company's adapter, provided the voltage rating shoule be 9VDC 2Amps. OK.
Dec 23, 2011 | Sony S2 Sports ZS-XN30 Radio/CD Boombox
I tried to plug in a digitech bp200 pedal and then my amp went on the fritz and starterd buzzing loudly. I attempted using the effects loop section on the back of the amp with my bass direct into the amp,...
DO NOT try a guitar pedal as an effects insert via the back jacks... they are for an external line level EQ/Effects type unit. Your guitar pedal should NOT have caused any damage. Check the power adapter you are using with the BP200. The BP200 takes a 9 VAC adapter, NOT a 9VDC type common to most pedals. You cannot use one of the Pedal Train type supplies with the BP200. Also check that you have the in's and out's correct on the pedal... backwards and they will cause what you are observing.. Verify your cables are good. The output of the pedal goes in the FRONT jacks of the amp. ONLY line level drives go to the back jacks.
Jun 05, 2011 | Hartke Lh1000 Bass Amp Head 1100 Watts...
Lost the adapter. I know i need a 9 V dc transformer, but what is the amp required?
This is all i could find
requiring 9VDC 500ma power .... Cyber Acoustics Studio CA-3000WW Multimedia Speaker System
Aug 03, 2010 | Cyber Acoustics CA-3000 Computer Speakers
Looking for power supply for diamondback Htr 1000u.Can you help.thank you
I recently bought the same bike and had the same problem. I contacted Diamondback and they told me that power adapter fits several models. The basic specs are 120V, 60 Hz input and 9VDC 1 amp output. The OD for the plug is 5.5mm and you should be able to find these plugs/transformers at Radioshack
Dec 30, 2009 | Exercise & Fitness
Speaker power supply
Found power supply for MLI-691 H speakers
Output is 9vdc, 600 ma. center of plug +.
SUN 9
Jun 10, 2007 | MidiLand MLi 691H Computer Speakers
Lands Phones Logo
Top GE Lands Phones Experts
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
