Question about Samsung Computers & Internet
What Is The minimum internet speed Netfix will streamline and operate decently? Will it work with any internet provider? how to get signal to my Samsung blue ray from my wifi router?
  • Samsung Master
  • 3,368 Answers
This is from Netflix Website.
Several ISP providers are throttling Netflix because they consume a huge amount of bandwidth that the ISP does not get additional revenue for. Check with your neighbors and see what they are using.
Internet Connection Speed Recommendations Below are the Internet download speed recommendations per stream for playing movies and TV shows through Netflix.
  • 0.5 Megabits per second - Required broadband connection speed
  • 1.5 Megabits per second - Recommended broadband connection speed
  • 3.0 Megabits per second - Recommended for SD quality
  • 5.0 Megabits per second - Recommended for HD quality
  • 25 Megabits per second - Recommended for Ultra HD quality
HD Video Quality
Movies and TV shows we have available in high definition will play in 720p or better with a fast enough internet connection. To watch Netflix in HD, ensure you have an HD plan, then set your video quality setting to High in the Playback Settings for your account.
Netflix Bandwidth Usage
Higher quality video uses more bandwidth than lower-quality video. If your service provider applies a bandwidth or data cap to your Internet service, you canManage Bandwidth Usage by changing the video quality settings to Low or Medium to consume less data.
Posted on Dec 06, 2014
The netfix comes up slow. The menu doesn't show what is playing. having this problem for 3 or more days now.
Only with Net flix? Has your network speed dropped? Try uninstalling application and reinstalling it.
Sep 06, 2017 | The Computers & Internet
What sources are available to finance working capital needs of small businesses?
There are many such sources which are available to finance working capital needs of SMEs. For example, Capital float is providing working capital finance for up to 200%. Particularly if a substantial part of your revenue is from cash less transactions.
There are some criteria for availing such loans. If I talk about Capital Float only then they are asking for these requirements for eligibility:
  • Operational history of 1 year - minimum.
  • Required turnover of Rs. 20 L- minimum.
  • Card volume of Rs. 1 L - minimum.
  • Card acceptance vintage of 6 months- minimum.
  • Six settlements per month - minimum.
May 30, 2017 | Computers & Internet
Netfix wont work
You need Microsoft Silverlight installed on your PC in order to watch Netflix in your browser. Please ensure that you have installed Microsoft Silverlight on your PC, and that should let you. If it still does not let you watch Netflix, check your internet speed to make sure that you have adequate speed, and if that is alright then you might want to clear your browser's cache. You can look on how to clear your browser's cache in your browser's documentation. If this helped you, please leave me positive feedback. Thank you.
Oct 17, 2014 | ErrorExpert Computers & Internet
Slow loading
It must be the problem with your internet connection or with your service provider. Sometimes your internet speed drops because of the maximum number of users using bandwidth on single back end providers IP, which is shared for all users. For that there are some points that can help you attain your loading speed:
- Refresh your internet connection
- Shutdown your router for minimum 10 minutes so that your back end IP can be change by service provider
- Remove your Temporary files from your system
- Try to use Reginout for constantly refreshing internet connections
Oct 21, 2013 | Cambridge Audio Azur 650BD Player
Which codes (OBDI or II) do I use for my 1994 Jeep Grand cherokee laredo 4.0 2wd
before 1996 they use onboard diagnosis system for jeep.
when you turn on key you need to count check engine light blinks.
here are codes taken from internet.
11* No crank reference signal detected during engine cranking.
12* Direct battery input to PCM was disconnected within the last 50 key-on cycles.
13** No difference recognized between the engine MAP reading and the barometric (atmosphereic) pressure reading at start-up
14** MAP sensor input below minimum acceptable voltage.
or
MAP sensor input above maximum acceptable voltage.
15** No vehicle distance (speed) sensor signal detected during road load conditions.
17* Engine coolant temperature remains below normal operating temperatures during vehicle travel (thermostat).
21** Neither rich nor lean condition detected from the oxygen sensor input.
or
Oxygen sensor input voltage maintained above the normal operating range.
22** Engine coolant temperature sensor input above maximum acceptable voltage.
or
Engine coolant temperature sensor input below minimum acceptable voltage.
23** Intake manifold air temperature sensor input above maximum acceptable voltage.
or
Intake manifold air temperature sensor input below minimum acceptable voltage.
24** Throttle position sensor input above maximum acceptable voltage.
or
Throttle position sensor input below minimum acceptable voltage.
25** A shorted condition detected in one or more of the idle air control motor circuits.
27* Injector #1 output driver does not respond properly to the control signal.
or
Injector #2 output driver does not respond properly to the control signal.
or
Injector #3 output driver does not respond properly to the control signal.
or
Injector #4 output driver does not respond properly to the control signal.
or
Injector #5 output driver does not respond properly to the control signal.
or
Injector #6 output driver does not respond properly to the control signal.
33* An open or shorted condition detected in the A/C clutch relay circuit.
34* An open or shorted condition detected in the speed control vacuum or vent solenoid circuits.
or
Speed control switch input below the minimum acceptable voltage.
or
Speed control switch input above the maximum acceptable voltage.
35* An open or shorted condition detected in the radiator fan relay circuit.
41* An open or shorted condition detected in the generator field control circuit.
42* An open or shorted condition detected in the auto shutdown relay circuit.
44* An open or shorted condition exists in the engine coolant temperature sensor circuit or a problem exists in the PCM's battery temperature voltage circuit.
46** Battery voltage sense input above target charging voltage during engine operation.
47** Battery voltage sense input below target charging voltage during engine operation. Also, no significant change detected in battery voltage during active test of generator output.
51** Oxygen sensor signal input indicates lean air/fuel ratio condition during engine operation.
52** Oxygen sensor signal input indicates rich air/fuel ratio condition during engine operation.
53* PCM internal fault condition detected.
54* No fuel sync (camshaft signal) detected during engine cranking.
55* Completion of diagnostic trouble code display on the malfunction indicator lamp (check engine lamp).
62* Unsuccessful attempt to update SRI (service reminder indicator) miles in the PCM EEPROM.
63* Unsuccessful attempt to write to an EEPROM location by the PCM.
* - Check engine lamp will not illuminate at all times if this code was recorded. Cycle ignition key as described and observe code flashed by check engine lamp.
** - Check engine lamp will illuminate during engine operation if this code was recorded.
PCM = Powertrain Control Module (the engine computer)
MAP = Manifold Absolute Pressure (the sensor that measures how hard the engine is sucking air through the intake manifold
EEPROM = Electrically Erasable Programmable Read Only Memory (a type of computer chip used inside the PCM)
Nov 19, 2011 | 1994 Jeep Grand Cherokee
I want my pc very fast and internet videos buffer in a seconds
upgrade your ram memory and reload windows fresh from scratch and install klite codec from google search type kilte
Mar 07, 2011 | Computers & Internet
Netrworking
In a "small business" environment, where 30 computers are being primarily used for "office" purposes (Word, Excel, E-mail), a standard "business Internet" package is sufficient, costing about $60/month,
i.e., $2/computer per month. Workers should be "working" and should not be streaming FM-radio stations, and should not be watching YouTube videos.
Jan 07, 2009 | Microsoft Windows Vista Ultimate Edition
Hardware requirements for FE065 card
There are no minimum requirements for most digital communication devices other than the operating system because a network card does not monopolize processor cycles, have access to RAM, or large drive space requirements beyond that of the driver. If the board has the ports to run the card, it has the ability to support the card with a driver. Some specialized cards and video cards as well do have minimum requirements, but only because of power consumption, the heat they produce, and the fact they communicate directly with the processor at much faster speeds. I/O devices don't have to be nearly that fast since the wireless signal and or copper connection, not architecture, are the limiting factors in the speeds you can operate.
Dec 10, 2008 | Dell (FW065) Pre-802.11n Wireless Adapter
Is Intel Celeron processor speed ok for programming?
Nothing much you can do with the speed but you can of course always add more memory. Additionally, you may want to streamline the startup programs to the barest minimum.
As to overheating, try a matching docking station with additional fan/blower.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 15, 2008 | Acer TravelMate 4320 Notebook
Computers & Internet Logo
136 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
