Question about CellPhoneTrek.com LG Optimus Dynamic Multi Color Ice Cream Cones Case
I have account and password What I want to do is find out how to check on my available minutes how do I do this
How can I check my new account..I can't seem to get in with my email and password..Can I check please?
Not a good idea to post your password! Call this dedicated number: "Cannot access account" call 1-800-318-0612
Change your password the minute you are in your account again!
Dec 02, 2014 | Computers & Internet
Tip
How to Hack Your Forgotten Password in Windows 7?
<span>For convenience, we often create an easy-to-remember and uncomplicated password for the PC like birthday date, which makes great possible to<span> </span><b><a href="http://blog.passwordunlocker.com/how-to-hack-window-password-in-windows-7/">hack Windows 7 password</a></b><span> </span>by guessing. So, how to prevent from your Windows password being hacked?<br />Following is the tip and trick that tells you to hold back hackers' access into your laptop with the guessing password.<br /> Enable Account Lockout if one tries to guess your password <p>Regarding your worries that someone tries to hack Windows 7 password by guessing it, you can simply in case of this by enabling Account lockout in Windows 7.<br /> <ul> <li><b>Step 1.</b><span> </span>Open Local Security Policy windows by inputting open local security policy in the Start search box and hitting Enter.</li> <li><b>Step 2.</b><span> </span>Double-click<span> </span><b>Account Policies on the left and select<span> </span><b>Account Lockout Policy</b>.</b></li> <p>You'll find that there are only three policies in the right hand pane, and your account should not automatically lock out when the password is entered incorrectly by default.<br /> <li><b>Step 3.</b><span> </span>Right-click the<span> </span><b>Account lockout threshold Policy</b><span> </span>and select<span> </span><b>Properties</b>.</li> <li><b>Step 4.</b><span> </span>Set the number of login attempts that you want Windows to allow before it locks the account when the properties window comes up, and then click<span> </span><b>OK</b><span> </span>to save settings.</li> <li><b>Step 5.</b><span> </span>Windows will prompt you to set suggested settings for Account lockout duration and the length of time to Reset account lockout counter. We usually use the default values of 30 minutes by clicking OK. You can also modify the values according to your needs.</li>Your Windows 7 user account will lock after the set number of failed login attempts. With the settings in this case, you account will be locked for 30 minutes if the password is entered incorrectly 5 times in a row.<br />The Account Lockout Threshold is a security setting that determines the number of failed login attempts before that account is locked out.<br /></ul>But sometimes you may still feel worried as your password is too "strong" that you would easily forgot Windows password by accident. Therefore, you have to find way to hack Windows 7 password. If you have the similar troubles, you can take the following tip for reference.<br /> Hack Windows 7 password with Windows Password CrackerAlthough there are many options that can<span> </span><b>hack Windows 7 password</b>, in my opinion, the best and effective is to get a Windows password crack, like<span> </span><b>Windows Password Unlocker</b>. Why? Looking upon the questions about Windows 7 password hack I meet, few askers can access the computer with another administrator account or create a password reset disk in advance to in case of a forgotten Windows password.<br /><b>Windows Password Unlocker</b><span> </span>and other crackers allow you to crack Windows 7 password by burning a password recovery disk with a CD/DVD or USB flash drive in a few minutes, no matter the length and complexity of the lost password. Never requires previous password and special compute skill: Never needs to reinstall computer and no data lose after Windows 7 password hacks.<br />Only 4 simple steps as follows.<br /><img src="sta-reset-button.jpg" /> <ul> <li><b>Step 1.</b><span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Download Windows Password Unlocker Professional</a></b><span> </span>from any available computer and install it.</li> <li><b>Step 2.</b><span> </span>Burn a password recovery disk with USB flash drive</li>Insert your USB flash drive in the computer and run the application. Next what you need to do is to burn a password recovery disk with the USB flash drive via the application. <li><b>Step 3.</b><span> </span>Set your locked PC to boot from USB</li>When the password recovery USB disk is burned, you should plug it in your locked computer. Boot your computer and set USB as the 1st boot device. <li><b>Step 4.</b><span> </span>Hack the forgotten Windows 7 password</li></ul>The interface of Windows Password Unlocker Professional will appear when you boot from USB. And you'll find all Windows 7user names of your accounts will be displayed with the passwords showing unknown or empty. Now you can select the target Windows 7 account and start to hack its password within a few seconds.<br />Ok, now you have sucessfully finished to reset Windows 7 password with this special utility.<br />After the tips and trick s listed above, are you still afraid of your Windows 7 password being hacked or can not access into the comp if<span> </span><a href="http://www.passwordunlocker.com/knowledge/forgot-windows-7-password.html"><b>forgot Windows 7 password</b></a>?<br /></span><br />
on Dec 22, 2010 | Computers & Internet
Tip
How to Reset Windows Vista Administrator Password With Three Simple Methods?
Have you ever experienced Windows Vista administrator password forgot? Absolutely, there is nothing worse than forgot your Windows admin password when you have a great deal of work to do on your PC. Even though you can enter your computer with a standard user account, you still could not download anything and install programs on your PC. Therefore, how to reset or recover Windows Vista administrator password efficiently?
Here we will show the top three easy and efficient Windows Vista admin password recovery methods to anyone who have Windows Vista admin password forgotten issues.
Method 1: Reset Windows Vista administrator password on safe mode
Preparation Time: about 10 minutes
Pros: Simple and do not need third party tools
Cons: Need an available admin account on your Vista PC
You can reset Vista administrator password on command prompt with an available admin account to enter safe mode first. If you have another Windows Vista admin account, try these steps below:
Step 1: Press F8 when your Windows Vista PC is booting. You will come to the Advanced Boot Options. Then choose Safe Mode with Command Prompt and press Enter.
Step 2: Enter safe mode with an available admin account.
Step 3: Type "net user" and press Enter. The command prompt will show you all accounts on the Windows Vista PC.
Step 4: Type "net user Paul 123" (Paul is the locked admin account's name and 123 is the new password) and press Enter. Now you have successfully created a new password on the locked admin account.
Step 5: Type "shutdown -r -t 00" and press Enter.
Your Windows Vista PC should be rebooted automatically and then you can logon Windows Vista with the new password.
Method 2: Recover Windows Vista administrator password with freeware
Preparation Time: More than 30 minutes
Pros: Free and do not need to change the forgotten password
Cons: The freeware should not work if the password is too long
Ophcrack is freeware for Windows password recovery. This software can help you to recover your forgotten Windows Vista admin password. So that you can regain access your admin account without changing the password.
Ophcrack is used to create a Windows password recovery disk. You need to boot your computer from the disk to recover your password. You can follow these easy steps:
Step 1: Download Ophcrack
Step 2: Burn a Windows password recovery disk with the freeware
Step 3: Recover the forgotten Windows Vista admin password with the disk
You can logon Windows Vista with the old password now.
Method 3: Reset Windows Vista administrator password with shareware
Preparation Time: less than 10 minutes
Pros: Fast and 100% reset the forgotten password
Cons: Not free
Windows Password Recovery Tool 3.0 is easy-to-use shareware to reset forgotten Windows password, including administrator password and other standard users' passwords.
Unlike Ophcrack, Windows Password Recovery Tool is designed to reset the forgotten password. No matter how long and how complicated the password is, this software can 100% reset the forgotten password in few minutes. All you need to do is just three steps:
Step 1: Download Windows Password Recovery Tool
Step 2: Burn a Windows password reset disk with the shareware
Step 3: Reset the forgotten Windows Vista admin password with the disk.
These three Windows Vista administrator password recovery solutions are helpful for us to resolve the Vista admin password lost problem. Now, you are no more Vista admin password forgot matters.
This article is free for republishing
on Jul 12, 2010 | Computers & Internet
Facebook account hacker
Facebook Customer Support:
Phone Number: 1-650-543-4800
Average Wait: 12 minutes - 24 hours, 7 days
Aug 13, 2014 | Facebook Social Network
I need to change login details and new email address for my facebook site so how do i do this?
That is quite easy.
  • Log in to Facebook.
  • Drop down the "Account" button which is located at the Top Right Corner.
  • Click on Account Settings.
  • You can change your Name from the Upper Most Setting.
  • You can change your User Name by using the "change" link in front of it. Just choose a new name and check the availability. If its available a button will be their to activate it. It will take 1 Minute to 24 Hours to change.
  • You will be able to change your e-mail settings using th 3rd link. Click on change and Provide the e-mail Address. After the approval you will be able to Remove the old e-mail Address.
  • Fourth one is the Password. You have to supply the Old Password and a New Password. You will be asked to provide the Old Password in order to Change the Password / You will be Prompt to Re Log if the changes were successfully applied.
Hope this helps. If you still have problems or any unclear point, please feel free to ask. Please be kind enough to RATE the answer as well!
Have a good day! Thanks for contacting Fixya!
Jul 13, 2010 | Microsoft Windows XP Professional for PC
Tip
How to Reset Windows Vista Administrator Password with Three Simple Methods?
Cons: Not free
Windows Login Recovery is easy-to-use shareware to reset forgotten Windows password, including administrator password and other standard users' passwords.
Unlike Ophcrack, Windows Login Recovery is designed to reset the forgotten password. No matter how long and how complicated the password is, this software can 100% reset the forgotten password in few minutes. All you need to do is just three steps:
Step 1: Download Windows Login Recovery
on Jun 24, 2010 | Computers & Internet
I need assistance with my Norton Account immediately!
Go to www.mynortonaccount.com and click on forgotten password, you will get temporary password with in 5 minutes
Once you get the temporary password you can access Norton account.
Apr 13, 2010 | Symantec Norton AntiVirus 2004 for PC
How to reset change windows 7 password
Windows 7 ?
you can try some password recovery tools ,I used one called windows password recovery tool 3.0. It successfully set my vista password to blank in minutes. I download it from
http://www.windowspasswordsrecovery.com
or Here is a solution, you can try it.
http://windowspassword.blog.com/
Nov 28, 2009 | Microsoft Windows XP Professional
I have a Gateway notebook computer with Microsoft Windows XP Media Center Edition. I have set up user accounts with passwords. I am on the admin. account. If I am logged on and don't do anything with the...
The prpblem is your screen saver settings. The screen saver is password protected, which means when your computers screen saver is active and you start to use it again you have to sign back in. Beside the minutes settings there is a box that if it is check off than it dislays the log in screen, uncheck that box and your good to go.
Let me know how you made out.
Good luck.
Jan 11, 2009 | Gateway Computers & Internet
I can't log in
Hey there - Try booting into safe mode (hold F8 during boot up) choose the safe mode option. This should bring the administrative account available at the login screen. Hopefully you have not password protected it. If you can log into that account you can remove/change the password settings for the your account under the "users" in the control panel settings.
NOTE* This fix assumes you're operating in Windows XP
Jan 05, 2009 | E-Machines T3882 PC Desktop
CellPhoneTrek.com LG Optimus Dynamic Multi Color Ice Cream Cones Case Logo
588 people viewed this question
Top CellPhoneTrek.com Cooking Experts
Tom Chichester
ray gallant
Are you a CellPhoneTrek.com Cooking Expert? Answer questions, earn points and help others
