Question about Taylor Health & Beauty
How do I set taylor scale so I get accurate weight
Pushed all buttons. Nothing makes sense
    Master:
  • 560 Answers
There is an adjustment on the scale itself. Just set it to zero.
Posted on Dec 06, 2014
How to turn on
-Make sure power cord is plug very good into the printer.
-Make sure Plug to outlet and make sure there is power there.
Try again.
Good luck
Mai
Dec 05, 2017 | HP Computers & Internet
Why does my GE washer turn off during a cycle?
I purchased a 4.8 cu. ft. High-Efficiency Top Load Washer with Steam in Metallic Carbon, ENERGY STAR.
I had issues when I used the machine for the first time. I started by loading some clothes and then the detergent, bleach and softener into the respective dispensers. I used the smart dispenser for the detergent, there are 2 detergent dispensers. Then I waited and ended up with water and a machine that would not spin .I kept getting the error message " Sensing " and it made light clicking sounds but was told that this was normal. I then waited 40 minutes and still no improvement. clothes stayed in the same spot.. nothing was happening but the Sensing Scroll Message.. I had to push the power button to stop it. I then pushed start but I still kept getting the error message scroll " Sensing "
I started over by setting it to drain & spin. It worked and my clothes got spun finally. Since I kept getting the sensor message and that is all it would say is " Sensing" .... I decided to try something else.
I powered it off and started a new load.
Next Load Trial:
I added soap to the detergent dispenser " Not the detergent smart dispense. Then i pushed the control lock button and last I hit the start button and whoala It works now.
Try getting familiar with your washer. do some light loads until you figure it out. It will eventually get where you need it to ,just be patient. Now I wash loads easy as pie.. I hope this helped you out with your problem. ;) . I am still learning mine and will post future issues and fixes if I come across any. Thank You.
Christine G. Hobbs, NM
Aug 26, 2014 | GE Washing Machines
Electrical issue
Does the vehicle start an run ? If it does ,the brain as you call it is working fine . The check engine light has nothing to do with the PCM /ECM sensing problems .You probably should take your vehicle to a qualified repair shop .
May 19, 2017 | 2000 Chevrolet Silverado 1500
A few years ago I purchased a Philco capital turntable CD cassette. One day my wife was listening and for some reason she pressed the standby button, ever since then nothing will work. The power does come...
maybe the button when being pressed isn't releasing through a bad button . it would make sense that when the button is pushed it stops all functions so if you r able to disconect the button from the wires tape the wires together to create a closed circuit and see if it works personally i would take it to a repair facility for the safety factor of messing around with it but if u want try it
Sep 26, 2013 | Philco 841205 Turntable
How do you tare out this scale?
Why didn't you take it back since it was new and not working? Does not make any sense.
Aug 23, 2017 | Homedics SC-104 Silver 5" Dial Scale
I have two Taylor Lithium scales and neither one of them will turn on. I have replaced the batteries, still they will not turn on. I have done a "reboot" as suggested on FixYa, but without...
The scale may need to be initialized. This process is necessary because the scale was moved during the shipping process. Initializing the scale "re-seats" the internal parts allowing the scale to find the correct "zero." Here is how to initialize your scale:
- Place the scale back on a hard surface floor.
- With one foot only, place just enough weight on the scale for the display shows zero's or dashes. Once you see zeros or dashes remove your foot.
- Wait for the scale to turn off again.
- Step up onto the scale for a weight.
Or, your scale may be on an uneven surface or on carpet. Be sure to place your scale on a hard, flat surface to get an accurate weighing. Are you sure that the place the new battery with the "+" sign up into the battery compartment?
Keep us updated.
Jul 15, 2011 | Taylor 5599 440 Pound Tempered Glass Body...
My weight is not accurate. I weigh 260+ and the scale reads 245 to 249 and is inconsistant. I just replaced batteries (CR2032)for the second time
Very few electronic scales are accurate as they are a function of a resistance measured against a voltage. They may be accurate when you buy them, but over time the electronic components decay and read differently as the components are cheap 10% type resistors and capacitors and cannot hold their specific values over time.
If you want accuracy, you will have to get a balance type scale that can be calibrated on site.
May 17, 2011 | Taylor & Digital Scale Lithium Scale
Health & Beauty Logo
97 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
