Question about Welding Tools
MyCH115v flux core welder will not feed (wheel will not run)nor will it arc.What should I look for to be the problem?
Nothing
    Master:
  • 560 Answers
Look at the power supply feeding the unit. Has the breaker tripped? Turn the breaker off to the outlet supplying the welder and then turn ot to the, "on" position. You can't reset the breaker from the tripped position. You need to turn it, "off" first. Look at the connectors to make sure they're plugged in properly. Check to see if there is an internal breaker that might have tripped.
Posted on Dec 06, 2014
Testimonial: "Tried that didn't work. No internal breaker on this unit. Thanks anyway"
  • Ronald Thompson Dec 06, 2014
    Try tracing the current through the various connections. This should only be done if you have experience with electricity because you could easily shock or kill yourself .
Wire wont feed on my welder
I would call miller and get a number for the closest repair station. They have a three year parts and labor warranty. 1-920-735-4505
Jan 10, 2015 | Miller Multimatic 200 MIG TIG & Stick...
Very little power at wire
try to use bare .032 wire and co2 shielded gas, If the equipment does not have a gas solenoid you may have to wire a solenoid to the trigger mechanism to get the gas to flow while the wire is feeding. The bare wire usually copper coated burns much hotter than the flux core when there is a gas shield. Also a .032 bare wire with a gas shield burns a a lower amp range and will get better penetration.
You may have to experiment with the feed rate and gas flow to get the correct setting, but the bare wire has a lot less resistance to current flow than the flux core and will burn a lot hotter when you use a gas shield.
At 115 vac there is not a lot of amperage left to create an arc and run the feeder and the rest of the unit , and the flux core wire takes a lot of amperage to burn both the wire and the flux . .
Apr 03, 2014 | Campbell Hausfeld ® 115V MIG Flux Core...
Will a ya219b snap on by century mig welder weld flux core wire
Are you using knurled rollers? Check the wire. Is it reversed polarity. Flux cored wire is very voltage sensitive.
Jun 14, 2012 | Century Welding Tools
How do you switch the polarity switch on the 115 farmhand versa-arc mig welder. trying to switch from mig to flux core wire.
Hi:
Disconnect you ground clamp form the negative side pole and switch it to the positive pole, same for the gun disconnect the from the positive side and switch it to the negative pole.
Good luck.
Sep 07, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
I have a wg2020 campbell hausfeld flux core mig welder I have to turn my wire feed all the way on max to get the wire to feed. It seems like to motor is getting weak. Sometimes it seems to work right but...
Hi:
Sometimes the drive motor collect a lot of metal dust from the environment and it requires a clean up. Take the tensor off and remove all wire, try to apply compressed air into it and then apply WD40 and run it. Make sure your tensor wheel it's not to tight and that you are using the right wheel size for the wire in use. Another problem rely on the gun liner if this one hasn't been change in 12 months, it is time to replace it, or, if it is not kinked at all, try to use clean air to blast out all metal particles from it. (take off you gas nozzle and gas mixer also known as contact tip holder).
Good luck.
If this was useful to you, please vote.
Feb 25, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
I have power mig 100welder wire come out slow
Make sure that the wore feed wheels are tight and the is nothing in the way if the wire when flowing
Nov 19, 2010 | Firepower Flux Core Wire Feed Welder 88...
I dont know what kind of metals this wire type can do, it says fire power 1440 u235 flux wire, but not sure what kinds of aluminums or steels it can weld. Im a certifed MIG aluminum welder, but this is a...
Usually a flux core only welds steel. It is a higher penetration weld than a MIG. Usually it acts similar to 6011 rods in SMA (Shielded Metal Arc) welding -- a.k.a. stick welding -- if you're familiar with that. I don't believe there is such a thing as flux wire for aluminum. There may be stainless wire for it, but I've never seen it. It probably could also be used for building up cast iron and cast steel, but nothing structural. I have a Chicago Electric one and I love it -- simple and it penetrates hard. My 90 amp will weld to 3/8" without breaking a sweat and if I baby it will go to 1/2" or better. It is difficult to go much lower than 12 or 14 gauge though due to the high penetration.
Nov 28, 2009 | Campbell Hausfeld MIG / Flux Core Wire...
Flux core welders are burning up tips, insulators, and leads
Try to turn up the wire feed and the volts and pull the cup 1/8 inch past the tip
Nov 30, 2008 | Campbell Hausfeld MIG / Flux Core Wire...
Welding Tools Logo
71 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
