Question about Depo Auto Parts 2000 Dodge Durango New Condenser/Radiator Cooling Fan Assembly 5.2/5.9 Liter
I have a 2000 dodge durango 5.2 it is overheating and my check engine light flashes when I accelerate I have changed I have changed the the theramastat and the water pump and atc sensor and it is still over heating I have changed the spark plugs and the check engine light still flashes I have no clue what it could be anymore help please
    Sergeant:
  • 406 Answers
Is the motor getting hot like boiling over etc or is it just the gauge or light..if not may be a bad gauge or light .if it is it may be your intake or head gaskets,, have someone do a cooling system leakage test..normaly called a radiator test..puts compressed air in in tne radiator that in turn puts more pressure inside the engine and heads it will find a leak due to leaking gaskets...good luck..
Posted on Dec 06, 2014
I'm having trouble with overheating my 2000 5.9L 4x4 Dodge Durango. I've replaced the thermostat,fan clutch, water pump & still running hot heater core.would flushing cooling system fix my problem
The radiator is most likely plugged. Flushing is the least expensive way to try to fix the problem. It may not clear a severely plugged radiator. Watch the lower radiator hose with the engine running. Accelerate the engine. If the hose tries to collapse, then the radiator is definitely plugged.
Dec 17, 2015 | Dodge Cars & Trucks
Code P1899 2000 Dodge Durango
try to reset.but if not why shows code.
Feb 24, 2013 | 2000 Dodge Durango
Have a 2006 Dodge Durango. 96000 miles. Regular maintenance. Idling rough, excessive vibration and loss fo power on acceleration. Check engine light flashed at 2500 rpms. Check engine light stays on, but...
i would do a tune up and this should fix your problem, i think the coil packs are around $30 a piece, you can just replace the spark plugs first, then if needed the coil packs. Hope this helped Tim
Mar 29, 2011 | 2006 Dodge Durango
My 2000 dodge durango is stalling all the time 4.7
Hello! I'll need a little clarification..Does the problem occur when engine is hot or cold?...Will the engine idle?...Does the problem occur when accelerating?...
Guru...............Saailer
Jan 22, 2011 | 2000 Dodge Durango
Overheating 2003 dodge durango. What could be the problem??
When engine running, ensure no engine combustion gas bubbles in coolant resevoir (if so, the head gasket is blown).
Check cooling fans are operating ok (when required when car warms up), if not check
1) fuse,
2) relay operation,
3) heat sensor switch.
Replace thermostat.
When re-filling cooling system, bleed off any airlock as necessary.
Check for collapsing (soft) coolant hose on suction side of waterpump when engine revs above idle.
Sep 01, 2009 | 2003 Dodge Durango
2000 dodge durango 4.7
two probably thing , you have a pluged radiator or the fan clush is not good, if when you are cruising it doesn' t overheating , but when you stop for 2-5 minuts it does, then is the fan clush, if when cruising it overheating then is the radiator . all this thinking that you checked the cooland level and changed the termostat with the correct oness
Aug 01, 2009 | 2000 Dodge Durango
2001 dodge durango temp. is high
use 50/50 mixture of coolant/water, use synthetic oil or no more than 5w 30. Change thermostat, make sure fans come on when idleing, otherwise change relay
Jul 09, 2009 | 1999 Dodge Durango
Dodge durango Engine cut's off
Try replacing the fuel filter.
Jun 12, 2009 | 2000 Dodge Durango
Depo Auto Parts 2000 Dodge Durango New Condenser/Radiator Cooling Fan Assembly 5.2/5.9 Liter Logo
89 people viewed this question
Top Depo Auto Parts Computers & Internet Experts
Todd Arndt
Todd Arndt
Matthew Spark
Matthew Spark
Andrew Taylor
Andrew Taylor
Are you a Depo Auto Parts Computer and Internet Expert? Answer questions, earn points and help others
