Question about Canon IR 105 Digital Copier RECONDITIONED
Canon ir 105+ has been showing Error code e000202-0000 can u plz clrify the error code
ThemachineshowinganerrorcodeofE000202-0000can plz clarify
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
SOURCE: Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Posted on Nov 20, 2009
SOURCE: Canon IR3300 showing the error code E000602-0003
ERROR CODE E000602-0003 what i do
Posted on Feb 08, 2010
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Posted on Feb 11, 2010
canontech
  • 1219 Answers
SOURCE: canon ir 3530
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Posted on May 04, 2010
My Facebook has stopped since last night I've tried everything to get it back ok.plz help me fix it plz thank you.
Could you clarify if there is an issue while logged in to Facebook or you can't log in at all?
As for solutions, it may be caused by your internet browser, so you could try updating your browser to its latest version.
Jan 15, 2016 | Facebook Computers & Internet
Keypad is not working in samsung gt b-7722
My samsung GT B7722 Keys not working. Only ON/OFF switch working. Kindly Clarify plz? - My samsung phone GT B7722 , Touch screen fully working. Hard key not working Except ON/OFF Key.Call Attend,Back, Volume Up/Down, Sim Change,Lock Key Not working. Kindly Clarify me the step to resolve the issue.
Nov 14, 2012 | Samsung B7722 Cell Phone
Sir i have a problem in 7610.the problem is the screen show that white.doesnot show nokia...
plz clarify your problem in brief .there is a display problem or a nokia logo problem.plz tell us your problem again so that we can help you.
Aug 17, 2012 | Nokia 7610
I just changed the batteries in my wireless mouse, and although it is lit up, it does not seem to connect to the laptop- there is no control from it. What have I done wrong?
Hi, plz clarify what type of mice u r using in laptop? If it is bluetooth plz reconfigure in bluetooth dock installed in your laptop. Or if is is PS/2 / USB check the dongle connectivity and functioning.
Sep 12, 2010 | Computers & Internet
I need to get and install wireless adaptor software
Plz clarify which driver You want.
Plz tell model of ur pc/laptop
Jul 16, 2010 | Computers & Internet
Helper.dll
If you want helper.dll then Download it from here!!
or
Just Clarify Your Question!!
Vikas Agrawal
MCA
Feb 06, 2010 | Computers & Internet
I just telecharge nero7.i have no number can someone give a number
sir,
U need serial number? can't understand ur questions. plz clarify
Thanks Good Luck
Appreciate to rate as "Fixya"
Apr 21, 2009 | Ahead Software Nero 6.0 (60045) for PC
THE NEC LAPTOP LCD IS NOT LAPTOP IS WORKING BUT
i did not understand ur problem plz clarify
Jun 26, 2008 | NEC Computers & Internet
Canon IR 105 Digital Copier RECONDITIONED Logo
144 people viewed this question
old marine
old marine
