Why does the menu on my tv keep comming on and it wont go away.. if it does its only for a few secs
Change batteries in remote and just playing around with it
    Scholar:
  • 124 Answers
Typically this happens if the button on the remote is stuck due to gunk or damage. Is there a possibility that something spilled on it or it was sat on? Use a cotton swab and rubbing alcohol to clean around the button to see if that frees it up. I'm assuming this only happens when there are batteries in the remote based on your question. If this is so, you've already isolated the issue as being with your remote. Check the hardware as I recommended. If this happens when there are no batteries in the remote you should check for any other remotes nearby. If you have remotes from the same manufacturer (e.g. Samsung tv + Samsung Blu-ray player) it's a possibility that the other remote is actively being pressed somehow. Make sure there are no other remotes from the same manufacturere around.
Posted on Dec 06, 2014
2 Suggested Answers
ice man
  • 68 Answers
SOURCE: after programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Posted on Mar 25, 2007
Anyone know why my LG tv has the input menu stuck on the screen. it is not the remote and the buttons are not stuck.
Disconnect the television overnight. Remove the batteries from the remote as well. Tomorrow, put new batteries in the remote and plug the television in.
Nov 04, 2017 | LG Televison & Video
Won't stay on channel. keeps reverting back to next lower channel.
Remove the batteries from the remote and see if the problem goes away, if so the remote has a bad button, that can possibly be fixed by cleaning it. Try these links:
The Remote Control Keypad Silicone Oil Problem
Cleaning Remote Control
How to Clean Remote Control
How to clean remote control
May 29, 2016 | Televison & Video
Lg plasma menu screen wont go away
The exit button on the remote may not be working or some other button on the remote is jammed. Try removing the battery of the remote and switch off the TV manually and the input power. Wait for a few minutes and then switch on the TV manually. The try changing the menu from the TV control panel. If nothing works, this is a case to be handled by a qualified service technician.
Jul 17, 2012 | LG 50PC3D 50 in. Plasma Television
My Hisense lcd is lock.
This is how I got mine to work after weeks of struggling just trying to find a new remote (hisense is really hard to contact....).
1) Turn the TV ON. unplug the tv while still ON 2) hold down the "menu" button on the side of the TV and plug it back in. keep holding it down. the TV should turn on with the menu popping up. use the Vol <> keys and Channel <> keys to navigate the menu. go to the Vchip menu, and play around. I'm not sure what ultimately worked, but i changed the Vchip password to 1111, turned the reset menu to "on" and played around with the ratings settings (turning most of them to "u"s etc).
I went through this process several times and finally, the black background behind the menu turned to static. I played around with the channels, and the TV was unlocked. I turned the TV off, and then on again, and the channels showed up normally (no static). and it was no longer locked. I had to do the unplug thing several times, and was getting really frustrated looking for an "unlock code" in the manual (it just says press the button on the remote. so it was not really helpful).
But really, once you can just get to that menu you've made some progress, and just keep playing around with it until something works.
Best of luck!!
Jun 03, 2008 | Hisense TL1700 17 in. LCD Television
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Whana change my sanyo tv to input to play games?
you need a sanyo remote with input button - can buy from www.sanyo.com
Dec 09, 2007 | Sanyo DS31590 31" TV
Demo Mode wont go away!!
to turn off the demo mode on model 32af42 toshiba tv you can either press recall,exit or power buttons / if this fails enter the menu screen go to the setup menu highlight demo select stop .
Sep 15, 2007 | Toshiba 32AF42 32" TV
Black squar in the middle of tv after a few minuetes of play.
Turn off the closed caption on the remote or in the setup menu.
Jun 13, 2007 | Toshiba MW24FN1 24 in. TV/VCR/DVD Combo
Demo mode wont shut off
I have this same problem, just started 2 days ago. Changed batteries in remote and everything - driving me nuts- now i cannot change channel or adjust volume! I powered off TV, took batteries out of remote, turned back on and now still stuck. I think we bought junk!
May 21, 2007 | Toshiba 32A33 32" TV
Televison & Video Logo
Top Televison & Video Experts
