Question about Kenmore Refrigerators
Where is the defrost timer located on a Kenmore side by side model # 56541
    Novelist:
  • 135 Answers
It's usually near the thermostat or somewhere at the top of the refrigerator compartment under a plastic cover with a screwdriver sized opening in it. Just follow the plastic duct work from the thermostat and you should find it somewhere along the route.
http://www.searspartsdirect.com/ is a good source for diagrams and parts but your model number didn't match probably because it wasn't complete. Look for a metal tag hidden on the framework which should give a part number like 156-111111 and plug it into the sears website.
Posted on Dec 06, 2014
Defrost timer
The defrost timer is part of the electronic control baord located on the back of the refrigerator. If the freezer is not defrosting check the thermistor on the evaporator(freezer) coils. It can cause the control board to thing it doesn'y need defrosting. a common problem
Mar 22, 2014 | Kenmore Side by Side Refrigerator
Kenmore refrigerator side by side. EnergyStar sticker says model series 56541-56551. Freezer side cold; fridge side between 50 and 60 degrees. I unplugged for at least 2 days for ice to melt. Fan at...
If there is ice built up on back inside freezer wall, you have a defrost problem. Either defrost heater, defrost thermostat, or defrost control (timer or Board) is bad.
Sep 05, 2017 | Kenmore Refrigerators
How to remove defrost timer
need complete model # to give correct help but most kenmore sxs ref / the defrost timer is located in the control panel . two screws to remove an un plug it .. reverse to install .. some older models are locaded behind the toe grill . same two screws.. mm
Oct 23, 2010 | Kenmore 52282 / 52284 Side by Side...
Kenmore bottom freezer refrigerator model 596.71109101 were is the defrost timer located / freezer froze up deiced with heat gun but can't find the timer
it may not have a timer but a aditive defrost control . most common with newer model .. its located in the fresh food side just behind the thempt contro knob and its a pc board .. . . do ck your heater first and the defrost terminator as thes two parts ore more common to cause your freeze up .. mm
Aug 18, 2010 | Kenmore 65234 Bottom Freezer Refrigerator
Kenmore side-by-side freezer is fine but fridge is not
Yes, Airflow is what cools the frig. Check for frost buildup on the coils indicating a problem in the defrost components r a fan not running fast enough. Eric
Aug 18, 2009 | Kenmore 53092 / 53094 Side by Side...
The refrigerator side has stopped cooling.
, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 18, 2009 | Refrigerators
Kenmore won't cool down.
I you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 15, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore model 57029 side-by-side refrigerator not working
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 12, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Fridge Defrost fan wont stop running
Hi, The defrost timer is located in the control panel. There should be 2-4 screws holding the control panel. Remove the screws and lower the panel to see the defrost timer. There are 2 screws holding the defrost timer in the control panel.
Please let me know if this helps you at all or if I can assist yyou further.
Vic
Jul 21, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrigerators Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
