Question about Electrical Supplies
Get engine parts - Electrical Supplies
    New Friend:
  • 137 Answers
Hello, it would help if you posted the make and model of your generator. OK?
Posted on Dec 06, 2014
I switched my SR830 mower from the original 8 hp briggs to a 17.5 hp Tecumseh off a later model. I need to know how this engine and starter solenoid wires up
  1. Tecumseh Small Engine Parts - RepairClinic.com
    www.repairclinic.com/Shop-For-Parts/.../Tecumseh-Small-Engine-Parts Huge selection of Tecumseh Small Engine parts in stock. Same day shipping. Open 7 days a week. 365 day return policy.
Jul 20, 2015 | Snapper Garden
I need an intake runner module but can't afford $400.00. Anybody know what cars might be interchangable?
Several suggestions. Try best-deal.com when you find correct part number. Also Ebay and Amazon. Salvage yards would be good. Car-parts.com is an online National locator service for Salvage parts which has free Request feature and results show many details. Details include Photo, Part grade, Price, Warranty, location. Could easily give you 100 results.
As with parts store and Salvage yards, some have cross-references and some do not look up alternate part numbers. Can tell you that with Ford parts, engineering changes reflect in some part numbers. Typically an "A" is a first issue, B,C,D etc. are later changes and THAT Engineering numbers are not the exact match to a Ford Part number. So you can have different Engineering numbers be the same Part number.
Why? Supplier deviations. There can be modifications to the original design that suits the Supplier due to machinery problems, material costs, or to simplify assembly. Once approved by Ford, the part is assigned a different Engineering number from that point on; yet it is still the correct part for the Ford Part number. Basically the Engineering number is meant to be an internal number and the Part number is external.
So if you get a part with molded numbers that are different, it is often the sticker or soft label which matters.
Sep 23, 2013 | 1998 Ford Contour
My 2006 honda civic dx is missing the plastic part that is under the engine that protects it
the front engine cover located on the underside of the front of engine can be replaced as a used part.check your local used parts places.it doe not have to be new as it only protects the engine from water,ice,snow. from going into or onto your engine,but without it,you may have a water problem that this cover prevents. suggest you call used part suppliers in your area ffor a replacement. the replacement is easy,if you are mechanically inclined,if not suggest you ask parts place to recommend at least 2 places and get an estimate of replacement of the part,if you supply the part.hope this helps and thank you for choosing fixya.com
Jan 25, 2011 | Honda CR-V Cars & Trucks
Need to change engine
All engine parts available at buyautoparts which provides free shipping and parts at discount prices. All parts available with OEM number. Find all parts here. http://www.buyautoparts.com/auto-parts/engine_parts.htm
Oct 30, 2010 | 2000 Hyundai Accent
Missing a spring on briggs 5.75 HP engine. spring is for "engine stop lever" where the cable connects to on the engine. It is a small spring. What is the size and part number to that spring ? Thanks, Terry
Enter your engine model, type and code off the 5.75 engine on the Briggs website to get a detailed parts list and diagrams for that motor. (including OEM part numbers).
Aug 09, 2010 | Briggs & Stratton Garden
Where do i find parts for my stanley mower?
Stanley Mowers were made by Murray. Most Lawn mower repair / parts stores have replacement parts for these mowers.
Even if you do not have a model number you can probably use this link (left side of page) to find your part.
http://www.outdoordistributors.com/Murray/Murray_Pushmower/Murray_Pushmower.html
If it is just an engine part that you need mose of these had Briggs and Stratton engines onthem and the engine model number and type code are on the air shroud just above the spark plug for engines 4 HP or less.
Jun 13, 2010 | Garden
Light engine blue bad any way to buy parts or fix
The only fix is light engine replacement. Search google with UX27712R part number. There will be many sources. All are rebuilt engines. If consumer buys the part and installs with no success, part suppliers will bring up issues relating to damaged by user or incorrect installation.
After replacement there may be some alignment issues or faults caused by incorrect installation and assembly.
Experienced technician that has changed an engine before, usually under warranty, has had an opportunity to learn the correct way to do it in a shop situation with known reliable parts.
User replacing may have a "no start" or "poor picture" situation and not have the experience or skill to recognize a secondary problem, minor connection problem or defective replacement part. It is more complicated than a fuse, bulb or other minor part replacement.
easyab
Apr 22, 2010 | Hitachi 55VS69 55" Projection HDTV
Wd52525 Ballast
Good Day, monkbuist;
TRY THIS:
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010. Good Luck, big IRISH. back.gif
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Electrical Supplies Logo
20 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
