Question about Electrical Supplies
I have a mini Execuheli rc helecopter, It is fully charged but when I try to throttle up for lift off you see the power fade from the lights then it just shuts off. I toggle on/off and it comeback on
Tried to lift off with power connected Tried to toggle on/off switch to see if it had a glitch
rynanlimpiad
  • 36 Answers
SOURCE: Blinking remote light when charging
check the remote indicator censord
Posted on Apr 08, 2010
SOURCE: My Kodak EasyShare M340 turns on, but then shuts off immediately.
omg! thank you so much Stephan you are th best i just bought the camera for Christmas. Went to the beach yesterday and it sttopped working the method with holding the lens and moving it around i saw some sand come out now it works!!!!!! :-D
Posted on Jun 06, 2010
  • 3 Answers
SOURCE: Hi...I bought a syma s018 rc mini helicopter a
I believe the Syma S018 is the same as my Yiboo UJ417.
Mine never got off the ground out after charging for an hour.
It just skitters along the ground. Must be a bad battery. Returning it if I can.
Posted on Nov 15, 2010
SOURCE: propel rc execuheli upper rotor
I had the same trouble this morning, I used the screwdriver that is supplied and removed the right side of the body. I found the gear on the motor shaft had slipped up the shaft and was not meshing with the bottom rotor gear. slide the motor gear down into postion, and install the right side of the body.
Posted on Dec 25, 2010
SOURCE: MY PROPEL RC EXECUHELI WILL
counter clockwise would be the nose tuning to the left. My sons did this and pressing the right trim button on the controler repeatedly untill it slows is all I had to do. If you go to far it will spin int the oposite direction then you have to trim to the left and find the happy middle
Posted on Dec 27, 2010
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
Spinning
It's not fully charged. Try putting in brand new batteries and fully charge before trying again
Jan 05, 2014 | Brookstone Remote Control Helicopter -...
Will not fly lift . Seem to run well but will not lift off the ground
The batteries on the Helicopter need to be fully charged to take off.
And important: to recharge the helicopter fully it needs really good base unit batteries.
I find all this a waste so - I used a wall power supply to supply suitable power to the charging bases of these helicopters give more consistant results than using batteries.. Just make sure you are using a 9V DC wall transformer (6 1.5v batteries = 9v) and that the polarity is correct.
manual is here
http://www.brookstone.com/webassets/pdf/651307p_manual.pdf
Dec 18, 2013 | Brookstone uControl Cloud Force RC...
Fully charged the choppers battery,the controller has all new batteries,turned on the chopper power switch,turn on te controller power switch and wait till light stops flashing.push on the power controll...
The light will keep flashing unless you are on the correct channel A B or C and you hit the "Light" button on the front of the unit.
As far as the high speed take offs I suggest identifying which A B or C setting is correct for your copter. In order to do this turn off the RC controller. Set the Selector switch to "A" move the left joystick "throttle" half way up and then turn on the power. Assuming that the copter is still ON it will either fire up or do nothing. If it does nothing try the same sequence with the selector switch set to "B" and try again. If nothing try "C".
Now, as far as the rapid accelleration, I read one online comment that indicated that there is some type of "programming" sequence that the unit learns by pushing the left joystick throttle all the way forward and then back to zero when you start to fly it. So after the first "blast off" set the copter back down or even hold it in you hand by grasping the the landing runners and move the throttle forward until the rotor spin up and it lifts off. In your hand it is easier to keep it from going up too quickly.
Aug 21, 2011 | JCPenney Gyropter RC Helicopter
Not getting altitude
Use only alkaline batteries, rechargeable batteries do not have sufficient voltage to fully charge the heli.
Apr 05, 2011 | RC Micro X Copter Mini RC Helicopter
How do i reset my rc traxxas stampede?
I don't believe the reset (or syncing) is necessary on this model. However, on similar models you pull the batteries from the vehicle and the remote. Wait 30 seconds. Replace with fresh (or tested as good) batteries.
Best regards
Mike
Nov 20, 2010 | Traxxas Stampede Monster Truck Rtrw/Xl 5
Hi...I bought a syma s018 rc mini helicopter a week ago and it was working great but now, when i fully charge it, it doesn't have enough power to lift off the ground. Is my battery defective? It seems to...
Nov 13, 2010 | SYMA Toys industrial Syma S018 Air Wolf...
Apr 07, 2010 | Toys
Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Mar 30, 2009 | Razor MX350 DIRT ROCKET - BLUE
Electrical Supplies Logo
51 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
