Question about Dryers
Panal wires melted , store wants to replace wiring is this a common problem with this dryer
  • Dryers Master
  • 744 Answers
Hello Linda;
My name is Peter. I am a retired field service appliance technician.
If the store replaces the panel wires that is good, but what component failed to cause the panel wires to fail? And they will burn out again.
Appliance manufactures put products on the market that have not been field tested. They wait until there are multiple failures and then issue either a notice (if it fails repair is at manufactures cost even out of your fist year coverage) ,Manufactures try to avoid
recalls for bad designs) and hid them on notices. Field techs can access the repairs or replace parts.
Is the part that they are going to replace have a thermal sensor?
If they replace the part with the original part, then what is to keep this part from burning out again.
Wish I was there to help you,
Peter,
Baltimore, Maryland, USA 443-306-1362
Posted on Dec 07, 2014
jsrock516
  • 5911 Answers
SOURCE: Maytag Neptune.
I'm not sure WHICH wire you're talking about, so its hard for me to assume in this situation. However, if your model number is correct, go to searspartsdirect.com. There are several wiring diagrams listed that you can use to assist you. If the wire is not melted too bad, note the color and/or any identifying marks on the insulation. Wires will melt if the current traveling through the wire exceeds the limit of the gage of wire used. This can be caused by a short circuit and/or a loose terminal where the wire is intermittently making contact (arcing). Definitely, not a normal situation. As a preliminary, if you replace the wire, make sure you use the proper gage. Also, double check all terminal leads in the circuit to ensure they are snug and making good contact. If you have questions, please don't hesitate to let me know.
Posted on Jan 18, 2009
jsrock516
  • 5911 Answers
SOURCE: Dryer outlet does not have common wire.
The following link explains how to convert from a 3-wire to 4-wire configuration and vice versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference between these two configurations is how the ground (green or bare copper) and neutral (white) wires are terminated. In a 4-wire confugration, the ground and neutral are independent of each other. In a 3-wire configuration the neutral wire will be grounded at the terminal block in back of the dryer by a ground strap.
Since you have an existing dryer outlet with a 3-prong configuration, the easiest solution would be to replace the dryer cord with a 3-prong cord to match your outlet. No need to rewire your house. A new cord can be purchased at an appliance parts retailer or hardware store for about $20 or less.
If you have questions about this repair, please let me know. I hope this helps you.
Posted on Sep 10, 2009
dmftrucker
  • 1922 Answers
SOURCE: Three prong cord problem on my maytag dryer
2 blues are both phase hot wires, the white is neutral and your yellow is case safety ground,if it will make you feel more secure, take an ohm-meter/multi-meter and check the wires each separately to the case, the 2 low resistance ones are neutral and safety ground
Posted on Oct 07, 2009
wfservices
  • 262 Answers
SOURCE: Frigidaire electric dryer feq1442eso melted
There should be a schematic inside of the back panel or inside the control panel(where timer is)
Posted on Feb 23, 2010
  • 3074 Answers
SOURCE: one dryer prong burned and
i would take the dryer apart and see how it looks inside, the real question is what caused the melt down, if it looks good then I would just replace the outlet and the cord, as long as the stud is still good. I would not run the dryer unattended as it sounds like you might have a problem, since you will have the dryer apart might as well clean all the lint out with a brush and vacuum. here is a website that will help with the dissemblance, Tim:
http://www.partselect.com/dryer+open-cabinet+repair.htm
Posted on Nov 20, 2010
The wire connecting to the heating element keeps melting/burning. Ive replaced it twice, each time it melted, how do i fix it?
What size wire? When you replaced the heating coil, what did you use? Was it OEM? What part number? Do you have an ohm meter?
Apr 11, 2014 | Dryers
Dryer gets so hot the door has melted
follow this test and fix it. God bless you
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork and/or replace the cycling thermostat.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . It will have 4 wires connected to it. 2 wires opposite each other will be closer than the other 2. The ones that are closer together should have continuity if it doesn't replace thermostat
Sep 30, 2013 | Hotpoint Dryers
One dryer prong burned and melted were the cord meets the dryer,do i need to replace the wire housing box were the wire meets the dryer. i am replacing the outlet and the wire
Nov 20, 2010 | GE Profile Harmony DPGT750EC Electric...
My tub on my dyer has quit working-where is the belt located and it is hard to change??
first you nead to unplug the dryer.next you nead to remove the lint filter and remove the two screws that are under it.now grab the top on both sides and pull it forward and up.roll top back and let it lay on back wall.look between the drum and the frount panal and remove the two 5/16 screws one on both sides.next pull the frount panal forward 6"and pull up on the frount panal.rotate the frount panal and let it rest on the side of the dryer.you do not nead to remove the wires from the door switch.next look under dryer drum and you should see the old belt.remove the belt.next place the new belt over top of drum,next with your left hand grab the frount top of the drum and lift it about 2"and with your right hand grab the drum belt and feed it under the drum.2/3 the way back.next lay down in frount of dryer and look under the drum.you will see that the idler assembly neads to be reinastaled in the slot in frount of motor.with your right hand hold the idler assembly and with your left hand you nead to feed the drum belt thrugh the idler assembly and over the moter pully.next you nead to replace the frount panal to the two clips one on each side at the bottom.next with your left hand push back on the drum and with your right hand push the frount panal forward and set the drum with the frount panal and replace the two 5/16 screws.next lower the top panal and replace the two screws and the lint filter.plug the dryer in and test unit out.
Jan 21, 2010 | Whirlpool LER4634J Electric Dryer
Model ler8857eqo wont start has powr timer makes clicking sound when timer is turned off start button clicks back out
you nead the unplug the dryer and pull the dryer away from the wall to get to the back panal.next remove the vent hosefrom the dryer.next remove the back panal and the power cord cover.if you look down and to the left you will see a white plastic thermal fuse.remove the wires from the fuse and check that it is closed.if it is open the replace the fuse and reassemble dryer.
Jan 19, 2010 | Whirlpool LER4634J Electric Dryer
I'd like to know how to change a heating element in my dryer (29' whirlpool) I'd like to know exactly how to take it apart and where to find the element. I'am not sure of the dryer #
first you nead to unplug the dryer,next you nead to remove the vent hose,next you nead to remove the back panal and the power cord cover,on the left side you will see the heater housing,at the bottom you will see the heating element,there are four wires,the two at the bottom are hooked to the element,you nead to pull them off,the other two wires are hooked to the high limit switch,you nead to pull them off,next there are two 1/4"screws,one on each side off the heating element,remove them,now pull out on the bottom of element,with element removed,remove the high limit switch from old element and put it on the new element,take new element and put it back in the heater housing and replace the two 1/4" screws,you will see that the two wires that go to the element are biger than the two going to the high limit switch,put the two wires to the element,now replace the two wires to the high limit switch,replace the back panal and the power cord cover,replace the vent hose,plug power cord in and check element out.
Nov 25, 2009 | Whirlpool LER5636P Electric Dryer
NOT WORKING AT ALL
whirl pool dryer's have a one time saftey thermo in them . when they fail they wll not start untill what caused the problem if corrected . (a ) maybe the vent needs to be cleaned . (B) dyrer is packed with lint . and must be cleaned out yearly to prevent lint fires . C if the vent tube on back is flex it may have kinked . after you find the problem replace the saftey thermo . mm
Nov 22, 2009 | Whirlpool LER5636P Electric Dryer
I had to replace my belt on my dryer and the wires have came out of the panal for the start and timern temperature buttons can you please send me a wire diagram for this, please help me thank you
Sorry I do not have a wire diagram for your dryer but I do have a couple of websites that might be able to help you out.
Both websites have 24/7
And this website has Live Chat Assistant:
http://www.appliancepartspros.com/index.aspx
Good Luck,
Oct 19, 2009 | Hotpoint Dryers
You can replace the 4 prong with a three prog cord found at Lowes etc.
First, disconnect the black wire, one of the "hot" connections, from the left side post by removing the terminal screw. This is one-half of the 240-volt connection.
Next, disconnect the red wire, another of the "hot" connections, from the right side post by removing the terminal screw. This is the other half of the 240-volt connection.
Then, disconnect the white wire from the center connection. It is used for the neutral connection.
Now, disconnect the green wire from the machine case by unscrewing the green screw.
The next step is critical to return your electrical connection to factory condition before installng the 3-prong cord! Locate the white machine wire that is now connected to the neutral (center) screw terminal. Disconnect it from there and install it under the green ground screw.Connect the outer two wires (hot wires) to the outer two screws, obviously, one on each screw.
Now connect the center wire (neutral) to the center post. You'll notice the white machine wire is now the case ground connection, unlike the 4-prong cord connection in which the green wire from the cord makes the ground connection.
Sep 10, 2009 | Dryers
Need wiring diagram for kenmore dryer model: 110.92826102
Diagrams are on the inside of the back panal, under the console or in a envelope glued to the front panal.
eric
Jun 06, 2009 | Kenmore 64732 Electric Dryer
Open Questions:
Dryers Logo
64 people viewed this question
Top Dryers Experts
