Question about Amana Heating & Cooling
What heat component is sticking on my Amana PTC153B50AM PTAC unit?
I have an Amana PTC153B50AM PTAC unit. The heat only works for 2 minutes and turns off; the fan keeps running but the heat never comes back on. I replaced the heater core which has built in limit switch, but didn't solve problem. Following the brilliant advice of a fellow questioner on this board, I slapped the side of the unit by the control box hard, which made the heat come on again. After several rounds of this, the unit appears to be working properly. What is the component which is sticking so I can replace so this won't happen again?
    Novelist:
  • 187 Answers
The problem is a contact on the control board. The heat control contact is in one of the small black boxes on the control card. Whacking the side caused some mechanical obstacle to release. If it occurs again, you will probably need a new control card.
Posted on Dec 11, 2014
  • Nathaniel Persson
    Nathaniel Persson Dec 14, 2014
    Happy Valley Air was correct. To clarify, the small black boxes are called relays. I replaced both marked "heater 1" and "heater 2". Fixed the problem. Can order relays from Digi-Key for $4, but you have to solder them into the circuit board. Or buy a new circuit board for $100.
3 Suggested Answers
  • 4 Answers
SOURCE: I'm not getting heat from my unit..
the compressor is controled seperately from the fan, this is done with the thermostat, try turning the thermostat on then of or untill you hear the "click" sound from the thermostat. If the compressor is still not turning on this may be more than you can fix if your not familiar with electrical hvac troubleshoting... more than lilkely the thermostat may be bad, or your compressors starting components are failing...if the compressor is comming on when the unit is turned on you could have a freon leak causing no heat. hope this may help some there is just too much to write on the causes this will give you a start though!!
Posted on Jan 18, 2010
  • 3 Answers
SOURCE: Amana PTAC
I know this is late but I had to add a solution to this problem since I had the exact same problem and was able to solve it. The probelm is not your control board. On these units, the heat pump compressor will not kick in unless the temperature you set on the control panel is within 2-1/4 degrees (or 4 degrees depending on your unit model. Otherwise, the unit locks out the compressor until the electric heat coil bring the indoor temperature up to that level - and then will switch the compressor back on for heat pump operation. So the problem is not the control panel or the compressor, it the electric heat coil. The coil has two manual limit switches on it that may be tripped and should be checked. The coil can be easily accessed by shutting down the power, removing 4 screws around the air outlet, pushing the screen up and sliding the panel out the top. The power wires can remain in place while the limit switches are reset. Hope it works.
Posted on Nov 06, 2011
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
Amana Ptac model PTC153B50AM, getting no heat
The heater relays on the circuit board are famous for going out in this model.. Can purchase circuit board for about $100 or individual relays for about $4. Have to solder them in.
Nov 13, 2013 | Amana PTC153B50AM Split System Air...
Model PTC153B50AM no longer heats
The heater relays (little black boxes marked "heater 1" and "heater 2" on the circuit board are known for going out. $100 will buy you a new circuit board, or you can order the relays from Digi-Key for $4 apiece if you are willing to solder them in yourself.
Nov 05, 2013 | Amana PTC153B50AM Split System Air...
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
I have a amama a/c ptc153b50am works well but
Check filter,and clean , and outside cond. unit most probably needs cleaned. Wash it out with a water hose,not high pressure, and it should work better.
Feb 22, 2010 | Amana PTC153B50AM Split System Air...
Jan 17, 2010 | Amana PTC153B50AM Split System Air...
Amana air and heating unit model # ptc153b50am w/ power cor 37470
Sounds as though the power cord reset switch might be bad and need to be replaced. If not, then there is a short somewhere in the system. Do an ohms test on the switch to determine if it is bad.
Mar 16, 2009 | Amana PTC153B50AM Split System Air...
Need parts for an Amana PTH123A25AA PTAC
The Amana parts line # is 1-800-227-2919, you can also obtain parts numbers and names from their website, www.amana-ptac.com.
Please rate this answer and let me know if this helps.
Dec 13, 2008 | Amana PTH123B25AJ Heat Pump Air...
Amana ptac
WHAT DID YOU DO TO IT?
Sep 10, 2007 | Amana AAC051FRB Air Conditioner
Heating & Cooling Logo
46 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
