Question about Radio Communications
DW 911 radio works on mains power but not with battery inserted
Fitted new charger unit and battery plug in holder
    New Friend:
  • 10 Answers
Change the battery connector pcb board part# 5140019-41 12.07 on ereplacementparts.com
Posted on Dec 29, 2014
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
If the battery is charging as intended with the standard DeWalt charger and the indicator led's on the charger indicate that the battery is charging and also you need to check that the same battery will run your other DeWalt tools like a drill with no issues then the next obvious issue would be with the internals of your DeWalt radio.
If you're up to disassyembling it and doing some more testing with a multimeter you can contact me.
Posted on Dec 11, 2014
    New Friend:
    Problem Solver:
  • 5 Answers
Using a test meter check that the battery's voltage is at the radio's designated voltage. If not, then the battery is dead recharge it. If it is within the required voltage, then ensure that the polarity terminals of the battery are in good contact with the radios positive and negative points. If still not good, replace the battery.
3 Suggested Answers
laptopsbatte
  • 77 Answers
SOURCE: dead battery for one unit won't charge at all. voltage -0- both radios and charger work fine. where can I get battery? P/N MN-160001 capacity 950mAh
First put the dead laptop battery in a zip lock.
Then put the zip into refrigeratory and keep it in freezer for 14 - 15 hours.
Afer waitinf for a long time, take the dead laptop battery out of refrigeratory .
Using clean and soft cloth to dry the battery and get the battery to room temperature (about 20° - 25°)
In the end fully charging and discharging the battery for 3 - 4 cycles.
Now you would see that your dead battery holding up charge for 1-2 hours.
See the detail video in metacafe.com
View more info in : http://www.laptops-battery.co.uk/blog/revive-dead-laptop-battery.htm
Posted on Dec 18, 2008
eradiostore
  • 1654 Answers
SOURCE: no charge
Here are a few troubleshooting thoughts:
1) Check your charger contacts for film/debris. Use a pencil eraser to clean them. (This can be done on the charger and the battery.) If the charge light comes on and stays on consistently you know you have good contact.
2) Be certain your radio is shut off when on the charger.
3) New batteries sometimes need initialized. It will sometimes take 3 or more chargings to fully charge the battery. Check the date code of the new batteries to be certain what you obtained is truely new/fresh. Contact the vendor where you purchased the batteries and let them know of your difficulties in charging the new batteries.
Posted on Mar 13, 2009
Got new batteries and charged them and they will not turn on
You have the batteries in the wrong way. Or the batteries are faulty, the charger is faulty or the radios are faulty. You can test the radios by inserting a new set of Duracell batteries. If they don't work then you narrow it down to incorrect insertion and polarity or the units themselves.
Nov 11, 2015 | Uniden Radio Communications
Dewalt DE0245 battery charger blink fast without battery inserted
It really sounds like the electronics in the charger are failing or failed, it's probably cheaper to buy a new charger
Mar 25, 2014 | Computers & Internet
I have a pair that takes batteries an a charger base charger how does this work
They are often fitted with rechargable AAA cells. These can be charged by putting the phone on the charger base. Obviously the base must be plugged into power. You could alternatively take the rechargable cells out and charge them in a standard charger. The radios will also work with non-rechargable batteries but don't try and charge them or use the charging base.
Oct 29, 2013 | Radio Communications
AOR AR 8200 wont power up on new batteries but will when connected to charger/mains. Old batteries left in long time but contacts have been cleaned. Can you help please ?? Thank you .
I have had problems with these battery holders at times. When you push the batteries in, the spring contacts in the battery holder will move down into the holder. If they move far enough, they will not make a complete circuit to the scanner. I finally used a dot of hot glue to secure the contacts in the holder - between the batteries, not where the batteries go - and that cured the problem. Quite a delayed answer but I hope it helps.
Oct 07, 2013 | Radio Communications
Unit will not work
has to have batteries,
Jul 24, 2009 | Kitchen Appliances - Others
New battery fitted but nuthing no power to any
Are the main battery wires crossed? Red goes on the + terminal. Check the fuse box. The battery is filled isn't it? Put a 2amp charger on the battery for 6 hours. Be sure all lights, key switch, radio etc. are turned off.
Jun 10, 2009 | 1992 kawasaki GT 750
Kenwood th - 79E playing up
Charger should be able to power the radio at 'EL' level, if NOTHNG happens, I'd say charger is on the blink.
Mar 05, 2009 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
WILL NOT TURN ON
There are generally 2 causes for this symptom.
1. The input connector is usually a 3 terminal device. When the plug is inserted into the device, a spring loaded contact is pushed away from another terminal which effectively disconnects the battery section from the device. This stops any electricity from the plug from being connected to your batteries and causing overload conditions. If this spring loaded terminal has been damaged, when the plug is removed from the device it will not "spring" itself back to its terminal and the battery power will not reach the PC board.
2. The battery case (compartment) has 2 wires going from it (internal to the device) one black and one red. If either of these wires has broken off the battery holder or broken off the PC board within the device, it will not power up.
You can also make sure that all the batteries are inserted in the correct direction. Since the unit works when plugged in, you can cross out anything else having to do with the unit.
Mar 06, 2008 | Radio Shack Pro-97 Handheld Scanner
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Jan 01, 2008 | Radio Communications
Radio Communications Logo
80 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
