Question about Panasonic VIERA TC-P50ST50 50-Inch 1080p Full HD 3D Plasma TV
Panasonic 50inch flat screen tv won't turn back on
Turning it on and also plugging it out and plugging it back in and holding the power button for 5min
    Problem Solver:
  • 13 Answers
I would recommend getting The power supply replaced. It may have been a surge in voltage that ruined it. Depending on If you want a Genuine or Replacement part you are looking at around $76.00 - to $187.00 for a power supply.
Hope this helps!
Posted on Jan 02, 2015
    Top Expert:
  • Panasonic Master
  • 74,118 Answers
Hi Melvin
Contact any service technician. Its main power supply regulator board [inside] is faulty. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Merry X'Mas & Happy New Year; Melvin.
Posted on Dec 10, 2014
likha
  • 790 Answers
SOURCE: Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Posted on Oct 02, 2007
SOURCE: Panasonic 32" HDTV keeps turning off
Check or have a repair tech check connectors AP1 and AP2. Vibration rattles the power supply board (a crappy design, as the board is almost "floating") and causes the wires in the connectors to break, and may make intermittent contact. Heat may also cause intemittent contact. A very common flaw.
Posted on May 06, 2008
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
SOURCE: panasonic th-42px60u plasma tv not turning on
Power LED on front panel blinks several times, there is a delay, then repeats. After fiddling and fuming (mostly fuming) I found that changing the input signal source allowed the TV to be turned on. When I changed the input signal source back everything was ok.
In other words...
My TV is connected to my PC's video card via an HDMI connector. My card has 2 HDMI connectors. I moved the connector (the part that comes from my computer) from one HDMI out to the other. The screen powered up. When I changed the connector back to the original HDMI out I got my display back.
So yeah, try changing your input signal source. If you're using cable try switching to your Xbox/PS3/whatever, or vice versa. If you only have one possible signal source then I have no clue.
It's almost like the TV doesn't get any signal from the current cable then goes into sleep mode until it gets another signal. My problem had to do with me changing a bunch of sleep/timeout/screensaver settings on my TV/comp.
Hope this helps someone.
Posted on Mar 06, 2009
beast_b9
  • 113 Answers
SOURCE: TV is not working anyore
maybe stupid but try to plug-unplog from power outlet.. does it make any sound? kliking sound? if nothing helps than your starter is gone.
Posted on Apr 28, 2009
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
How to reset lamp w/o remote panasonic pt-52lcx16
Instructions
    • 1 Pressicon1.png the "Power" button on the TV remote control to turn the Panasonic rear-projector TV on and display a picture on the screen.
    • 2 Press the "Menu" button. The "Main Menu" will appear on the screen. Press the "Option" button.
    • 3 Press the "Enter" button. The "Optional Menu" screen will appear. Press the button to select "Lamp Runtime."
    • 4 Press the "Enter" button and hold it for about three seconds. The "Lamp Runtime" will change to display "Time Reset (Powericon1.png Off)."
    • 5 Press the "Power" button to turn the TV to the off position.
    • 6 Unplug the power cord from the electrical socket. Wait about one minute and plug the TV into the electrical socket
Read more: http://www.ehow.com/how_7201809_reset-lamp-timer-panasonic.html#ixzz33LeXpAsl
Jun 01, 2014 | Toshiba 37WLT66 37 in. LCD Television
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Televison & Video
Red light constantly on but not turning on
Hold down power button until it goes off . Count the times it blinks to get error code. Heve you unplugged set and plugged it back in?Get back if error codes?
May 31, 2013 | SNK Skyworth SLC1963A 19 in. LCD TV/DVD...
Panasonic tv
Try couple of things .hold the volume button on the tv and at same time press the menu button rapidly 3 times.if this does not get into the correct screen try holding the volume button on tv and press the zero(0) button 3 times rapidly and another is to hold volume button on tv and press zer(0) button on remonte rapidly 3 times each o fthese methods these should get you into various set up screens but be careful and take notes if you change settings .you may have to unplug or turn power off at mains and power up again to see changes
Feb 16, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
What happens to a plasma tv when the power goes out and it won't turn back on? 50inch plasma Panasonic vieja
If you are lucky either a fuse is now bad or the event may have caused damage to the power supply board inside the TV set.
Jun 13, 2012 | Televison & Video
Every 10 minutes my Panasonic plasma 720p turns mute
the problem is it is locked in store mode. I had to call panasonic to fix it, this is what they had me do.
1 hold the volume down on the tv while holding the menu button on the controller.
2 after the screen changes to the check menu, hold the off switch on the tv untill it turns off.
3 unplug the tv for 30 sec.
4 plug it back in and turn on the set.
5 select home option
6 your done.
Jan 22, 2009 | Panasonic Viera TH-42PX80U Plasma TV
No channel available
Unplug it for 10 secs and plug it back in then wait 10 more seconds and turn it on with the on/off switch. Unplugging makes it reload the firmware, but on/off does not. If that doesn't work try a factory reset. For my Panasonic you do this. Open front door to get at the buttons. Turn TV off. Press and hold the OK button and at the same time press and HOLD the on/off switch for about 3 secs. You should get a self check screen that will last a little while and then the TV will go to the menu screen.
Sep 06, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Panasonic VIERA TC-P50ST50 50-Inch 1080p Full HD 3D Plasma TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
