Question about Genie Pro Screw Drive Garage Door Opener with Rail Assembly for 7 Door - 1/2 HP - CM8600XL-7
My Genie CM8600 garage door opener runs, but prematurely goes back up. No obstructions, settings adjusted on power head-- maxed out. It seems like it reacts to resistance. Is the motor just old? I r
I've adjusted the sensitivity for the closing pressure all the way up so that it has no reason to reverse. Everything is lubed and moves fine when door is disconnected. The power head does not reverse when the door is not connected.
    Sergeant:
  • 406 Answers
Try manually disconnecting the door and run the mechisim up and down using the opener..see if it runs the entire length up and down... If it does it most likey the door or its mechinism is binding...good luck
Posted on Dec 06, 2014
My Genie door opener does not seem to want to connect to the Chamberlain remote control. Please advise!
If you have a universal remote or a max remote you can go to chamberlain.com to check compatibility. if it is not a universal or max remote it won't work with any genie product.
May 04, 2015 | Building Materials
Garage door opener not working
Sensor must show steady light to close circuit and let opener work. If aligned, then there is a loose or broken wire. Try reaiming first to get steady light. Then check all wires . Another way to test and prove that is the issue is if u hold down the wired button at ur back door and the opener closes, then it is sensor issue. Good luck.
Apr 11, 2015 | Genie Company Genie Garage Door Opener...
Why won't my Genie garage door opener close without going back up.
So it seems the Main garage door unit on the ceiling is ok. The problem is with hand held unit. Usually the circuitry is ok. Try changing the battery. It has helped me. Also make sure the sensor on ceiling unit is not blocked ad is free of cobwebs.
Jun 26, 2013 | Genie Company Garage Door Parts Genie Gwkp...
Genie H4000A manual
The garage door will only go down by holding the button on the wall switch
Aug 30, 2012 | Sears Genie Garage Door Gpwk12 Wireless...
How to open genie 1/2 hp garage opener for light bulb
Set a step ladder under the power head of the garage door opener so you can reach the power cord and the lens cover safely.
Climb the ladder and pull the power cord from the outlet in the ceiling. Press the two lens tabs in to disengage the lens from the power head. The lens tabs are below the opener rail on the upper corners of the lens. Pull the lens cover straight off of the power head.
Unscrew the light bulb from the light socket. Use a new 60 watt bulb to replace the defective bulb. Do not use a short neck bulb. Screw the new bulb into the light socket just as you would a regular lamp socket.
Slide the lens cover back over the front of the power head. Push the lens cover in until the locking tabs engage the top corners of the lens cover.
Plug the Genie garage door opener power cord back into the ceiling electrical outlet.
home light
May 28, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a genie pro max PMX 300 IC/A garage door opener and bought a Genie 3-button remote (model G3T-R) and I can't get it programmed. I push the button on the back of the opener, push the button
Take the opener apart and see if there are about 4 numbers that can be set. If you have an older remote take it apart and match the numbers, then program it.
Feb 07, 2012 | Home Security
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
May 04, 2017 | Sears Genie Garage Door Gpwk12 Wireless...
I want to program my Genie ecellerator isd 1000 so that I can use my Homelink system in my car and my wife can continue to use her Genie remote that came with the opener. How can i do this? Thanks
Inside the car press the 2 outer buttons on the homelink until the led light by it goes out or flashes rapidly. This erases all old/factory codes. Hold the remote 1" from the button you want to program and press the button on the remote and the homelink button until it flashes rapidly. Then press the learn button on the motor head and then press the button on the homelink you pressed before 4 times and this should code in. Thanks BB
Aug 21, 2010 | Sears Genie Garage Door Gpwk12 Wireless...
Genie Pro Screw Drive Garage Door Opener with Rail Assembly for 7 Door - 1/2 HP - CM8600XL-7 Logo
199 people viewed this question
Top Genie Pro Building Materials Experts
rdjagger
ray gallant
Are you a Genie Pro Building Material Expert? Answer questions, earn points and help others
