Question about Teledyne Laars Pool & Spa
Where do I find the heating element on my Teledyne laars hot tub? I have looked in and aound the control panel, Thanks
See above.
  • 21 Answers
There is no such thing as a laars hot tub. They make heaters for pools and hot tubs. The laars is the heater. There is a chance that someone remote connected the thermostat to the heater which would be in your boiler room, or some other remote location, like near the pumps...
Posted on Mar 10, 2015
  • 718 Answers
SOURCE: Where can I download an instruction manual for
You can download some information from;
http://www.manatron.net/Pdf's/JANDY%20MANUALS/heaters.pdf
This will give a parts list, applications and diagram.
Posted on Mar 27, 2009
  • 61 Answers
SOURCE: My teledyne Laars Telstar Model TGS-50 spa heater
Without doing more troubleshooting i would have to say that it is the main board (the board with the knobs on it) Take it out and see if there is any corrosion on it.
Posted on Apr 06, 2009
  • 139 Answers
SOURCE: starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Posted on Jun 21, 2009
  • 139 Answers
SOURCE: My teledyne laars pool heater will not cycle on. The pilot is lit and the valave is in the on position
check millivolt output should be 400-600.if less than that you dont have enough voltage to power valve
  • 139 Answers
SOURCE: I need an install manual for teledyne larrs one
try jandy pool products on internet.most manuals are available
Posted on Aug 20, 2009
I have a Teledyne Laars XE and it came with the house I just moved into. It's at least 15 years old and whenever I try to heat up my spa (it's natural gas), it won't get above 80 degrees,
It sounds like its either the temperature sensor (thermistor) or the control board. If you remove the control panel you will see two gray wires that plug in the back next to each other.
unplug the wires and use a multimeter to check the resistance (ohms).
At 80 degrees the reading should be about 9 thousand ohms (9K ohms); at 75, 10.5K ohms; at 70, about 12K ohms. Otherwise the thermistor needs replacing. About $70 Not too hard to DIY but you will have to take some panels off to get to it
If your readings were pretty close, it is probably the control board having trouble, but be warned they are not cheap, about $350. Tell you pool store what you are doing and some will loan you a good board to plug in just to verify whether or not that was the problem.
Who ever you buy from, make sure they have a return policy. Some companies will not accept return on heater parts that have been removed from the original packaging.
Mar 21, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Ineed an Elec & plumbing drawing or manual on a Teledyne Larrs SW1271ED008 H935B0034 hot tub........thanks
I would call the Laars technical support line at 800.900.9276 and they should be able to help with a manual.
I hope this helps.
Sep 13, 2011 | Teledyne Laars Pool & Spa
Hi! I moved into a bank owned home with a hot tub that has a gas LAARS LITE 2 Teledyne heater. It is not working, so I had someone come out and check it. He said I need to purchase a pilot assembly before...
Go to www.laars.com and download a manual for your model. Get the model number from the heater, and look up a manual. If yours is a milivolt model, the pilot must be working to troubleshoot further. The manuals will be full of information.
Oct 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
It heats the pool but the hot tub gets warm for ten min then the heater shuts off ???
ARE THE TEMPETURE SET HIGH IF YES THEN THE FLOW VALVE IS BAD . WHAT ABOT THE FLOW TO THE SPA CHECK THE PRESSURE READING WHEN SWITCH FROM POOL TO SPA IF VERY HIGHT THE JETS MAY BE PLUG MAKING THE FLOW TO SLOW FOR THE HEATER TO WORK OK
Dec 01, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars lite 2, mod-lg125n, sn. d03pj3400.
sounds like heat exch is plugged.remove top of unit and inspect for nests.could also be plugged with soot because of poor burner flame characteristics.with top off,turn htr on and look straight down into unit. you should be able to clearly see burner flames between fins. if not remove exchanger and clean
Jun 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
What type of pipe is needed on the inflow of the teledyne laars?
Most pool stores carry a set of two pipes used for older heaters. They are about 17" long, stainless steel, and bend 90 degrees about 8" from one end. They are usually refered to as heat sinks. The fact that the old one has pin holes in it would lead me to believe using PVC would be a bad idea.
Jun 01, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Series 2 esc 325p won't get above 85 degrees on full throttle
if using a aqualink and hooked into pins 1 and 2 on long plug turn heater all the way up and let the aqua link control heat
Feb 17, 2009 | Teledyne Laars Pool & Spa
Pool & Spa Logo
113 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
