Question about Husqvarna Garden
Husqvarna 460 xtorq with not start. Just replaced the clutch and sprocket now it will not start. I'be got spark. Thought it might be flooded but tried open throttle start and let saw sit for two days.
I even tried emptying the cylinder thinking there might be to much full in it. Also clean air filter.
  • 2 more comments
  • Eugene Rounds Dec 06, 2014
    Hi William Rich, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    How did prevent the crank from turning when removing and installing the clutch?
  • William Rich
    William Rich Dec 07, 2014
    I first used a flat head screw driver and then a piece of rope. I inspected the cylinder and piston and found that I scored both accidentally. This could be the problem. No compression.
  • Eugene Rounds Dec 07, 2014
    Yes the lack of compression is definely going to be big cause of the problem. Depending on how bad you scored the cylinder you may have jammed the compression ring But be prepared for a full top end replacement.
    In future you should a regular piston stop. The rope trick works a lot times but there setups that it will not work very well. I tried this yet but are planning to take a bolt of the proper size and thread pitch and grind off the leading edge threads an half inch or so to make a homemade piston stop tool.
There should be two adjustment holes for the carb turn them to the left as far as they can go not tight just less than snug and then turn to the right half turns at a time and then fine tune when it starts
Posted on Dec 07, 2014
steve_lima
  • 181 Answers
SOURCE: poulan chain saw P3314
pull the muffler off and check if the piston is scored,if it is you need to replace the piston and cylinder.
Posted on Jan 07, 2009
dontbother10
  • 2220 Answers
SOURCE: 353 husqvarna chainsaw, floods during start process
Husqvarna says the initial carburetor needle valve settings are from lightly seated 1 turn CCW for both H & L.
Your Operator's Manual can be downloaded here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140204-95.pdf
Once flooded Huskys are very hard to start. This works well on my 359.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close - sets fast idle) pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually the next pull)
Warm:
  3. Pull (close - sets fast idle) choke, - Don’t pull with choke closed.
  4. Push (open - fast idle maintained) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Posted on Oct 03, 2009
  • 4088 Answers
SOURCE: husqvarna 435 xtorq chainsaw will not start
Remove the spark plug and check for blue, snappy spark. If nothing, try a new plug--set gap at 0.020". If still nothing and machine is still under warranty, take it back to your dealer for free repair. The problem could be the ignition switch or the ignition module. Hope this helps!
Posted on May 07, 2010
  • 4088 Answers
SOURCE: chain saw carburator settings for husqvarna 61
Turn both screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Allow the engine to warm up, then pull the throttle full on. Turn the H jet screw CW until the engine starts to speed up, but still 4-strokes. Proper adjustment occurs when the engine is 4-stroking, but immediately 2-strokes when cutting. This gives best power and lowest heat. Release the throttle and adjust L jet CW until the engine idles fairly well, but will allow the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Posted on Jun 17, 2010
SOURCE: my husqvarna 575xp chain saw starts and runs for
I had the same problem with my 575 xp and was able to correct it by cleaning the orange nipple that the gas tank breather hose connects to. The hole in the nipple is really tiny. I cleaned it out with a fine wire and then blew air through it.
Posted on Nov 27, 2011
Husqvarna 576xp auto tune won't start seem to be flooding
you might have to have the unit re-calibrated with the auto tune software available at husqvarna dealer. there is no adjustments that you can do with an auto-tune carb. it will need to be hooked up to a computer at your husqvarna dealer.
Mar 03, 2015 | Husqvarna Garden
Why does the chain keeps tightening
Has it ever come off while using it? If so, there may be burrs on the drive teeth making the chain wider than the bar opening, also if there is no oil getting to chain while operating chain could bind from heat, check sprocket on the bar tip for blockage and inspect the clutch bearing.
Sep 07, 2014 | Husqvarna 340 345 346 350 351 353 445 455...
I have a 2011 husqvarna 345 xtorq only done 2 hours work .i got spark , cleaned out carb new plug still wont start or even fire any ideas plz
did you check for spark? you need air fuel and spark for engine to operate. check all of these then if it still wont start check the ground wire from coil to switch
Aug 14, 2014 | Garden
What causes my 460 chain saw to tear up the teeth on the chain in the clutch
wrong pitch of chain for that saw . sometimes folks bring me a saw that they have no idea what the correct pitch chain is for saw , im lucky n that respect as I got dozzens and dozzens of old chains laying about so I grab a few a try em for size on the ole saw . so my suggestions to you if your unable to do that is to go to a ole chainsaw shop and ask to test fit a few chains for size , saves you from tearin up a clutch sprocket
Jun 29, 2014 | Husqvarna 20" 60cc Rancher Chain Saw 460
Replace sprocket on rancher 460
The factory do not offer a rim sprocket for the 455/460, they are classed as semi pro saws and as such get a spur sprocket, there may be an Oregon after market one available.
Dec 29, 2012 | Husqvarna 20" 60cc Rancher Chain Saw 460
Husqvarna 460 rancher: oil pump not working. Clutch ran hot a few times. When the bar and chain are removed no oil appears from the supply port
The oil pump is adjustable ( 3 positions ) the adjuster screw is located under the crankcase below the sprocket, there is also a filter in the oil tank, you will need to gently lever out the oil pick up pipe from the oiltank, it has a grommet in the centre to keep it tight in the tank, failing that there is a nylon gear driven via the drive sprocket, this may have become damaged.
Oct 25, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 435 xtorq chainsaw will not start. you flip the start stop switch prime the gas and pull until its supposed to turn over and does nothing. switch it off of choke and does nothing. thought maybe...
Apr 14, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 460 chain brake not aactivating
If you haven't owned for over 2 years it should be under warranty.
Oct 04, 2009 | Husqvarna Garden
NO power to spark plug
more then likely it is the kill switch wire off your coil
Nov 15, 2008 | Husqvarna Garden
Garden Logo
67 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
