Question about Watches
I have not worn it for two or three weeks because I broke my wrist and it runs by movement and it wont work now
Just wearing it now for about an hour
    Master:
  • 560 Answers
Putit on the other wrist and wear it all day.
Posted on Dec 06, 2014
Watch running fast about 5 seconds per minute. it had stopped because didn't wear it for a few days. didn't wind it at all. just set time and it started but now running way too fast. any...
mcdevito75 here, Depending on how new your IWC watch is, without running at all can be bad in the way that the oil in the movement can settle and more or less drain off the moveing parts, and without the oil distributed thru out the movement, your watch could run a bit fast. Re--starting your watch as you"ve done will help, re-distribute the oil, in the mean time switch your watches position on your wrist every couple of hours, crystal on top of wrist, then 2--3 hours later crystal turnned under the wrist, it may take a day or two for the condition to correct itself, if I'm right. Hopefully you have a warrantee with IWC on your watch. Hope this helps.
Aug 03, 2010 | IWC Spitfire Pilot Mark XVI Steel IW325505...
I have bought a new daytona but after every few hours it just stops anf i have to reset it again.its quite frustrating
A Rolex watch is automatic.It needs to be worn 8 hours per day to store enough power to run 36 hours off the wrist.Assuming that you are wearing the watch daily if it still stops there is a problem with the auto winding or mainspring.As a new watch it will be under the Rolex guarantee so return it to the place of purchase.If you dont have a guarantee contact www.rolexrepairs.co.uk for advice or a free estimate.
Regards
Jul 06, 2010 | Rolex Daytona 116520 Wrist Watch
Watch winding is not holding
Two words: Wind it! When any self-winding (automatic) watch runs down from not wearing it you have to manually wind it to get it going again. Once you've done that the movement of your wrist will cause the self-winding rotor mechanism to keep it running as long as you are reasonably active and wear it everyday. Just wind it about 40 turns and you'll be good to go. Oris is a great watch company and you should enjoy it for many years.
Apr 16, 2010 | ORIS Watch TT3 Day Date 63575887067MB
Watch stops shortly after any movement
Automatic, or "self-winding" watches get their power from movement of your wrist throughout the day. Unless you're quite active the amount of movement is just about enough to keep it running till the next day. However, if you let the watch run down completely as you did when you were away, there is no reserve power left. The solution is simple: just manually wind the watch and you'll be good to go. To manually wind the watch unscrew the crown as if you were going to set the watch but do not pull it out as would for setting. Wind the watch about 40-50 turns and it will run fine if you wear it every day.
Apr 10, 2010 | Rolex Mens Airking Watch
I have 4 seiko watches that no longer work. Most unreliable watch
mcdevito75 here, hello Diane, I'm afraid your jeweler is correct, and so are you. It is adviseable to pull the stem out to save the battery BUT, only if your not going to wear your watch for a long time, not just over night, here"s the problem!! the quartz mechanism and most of the works are plastic, and plastic while fairly flexable when new, gets hard over time, your pulling the stem to stop the watch everyday or even once a week most likely broke the switch in the mechanism that starts the watch, if so your only option is to replace the movement if you can get one. Pull the stem to stop your watch only if your not going to wear your watch for say 2 weeks toa month.
Feb 06, 2010 | Seiko Ladies Two Tone SUJ614 Wrist Watch
Juts got the watch, wound it, worked then stoped, wound dead
These watches are self winding (mechanical spring), so need to be worn (or gently oscillated) to wind them up.
The catalogue for this watch says it should run for 72 hours when fully wound.
Depending on when the watch was made, it could be that it needs a clean.
Try wearing it for a few days to see if it keeps going.
Feb 02, 2010 | Rolex Daytona 116520 Wrist Watch
Breitling navitimer watch
breitling navitimer, keeps perfect time on the desk, but when ion the wrist it runs fast, as much as one hour in 24 hrs
Aug 03, 2008 | Breitling Hercules 246/GRY/PROF
Restarting my Citizen Promaster Eco Divers 200 Watch
Since it's eco-drive you can just wear it for a few hours and it should self-wind. The problem is that when it sits still for more than a few days it winds down. It gets its power from the natural movement of your wrist as you walk around.
Once it starts ticking again you'll just have to set the time correctly.
Dec 18, 2007 | Citizen Eco-Drive BL006056H Wrist Watch
New watch
Just wear it for a few hours. It draws power from the natural motion of your wrist as you move around like normal. It should start up in a few hours and you'll just need to reset the time.
Dec 18, 2007 | Fossil AM3425 Wrist Watch
Watches Logo
19 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
