Question about Pool & Spa
My spaform hot tub tripped the electric a couple of times and now there is no power in the tub. By power I mean there is nothing on the digital display ??
Nothing
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Check fuses inside front panel sounds like a shorted heater element
Posted on Dec 13, 2014
  • 366 Answers
SOURCE: my spaform hot tub will not reach its temp ..we
if the heater tests out good, you most likely have a problem with the water temperature sensor. Make sure that the temp readout matches the actual water temp.. Sometimes the heater will think that the water is up to temp because the temp sensor is feeding the circuit board bad info. Check sensors, replace as necessary.
Posted on Sep 16, 2010
  • 990 Answers
SOURCE: My electric went out for 24 hours. I hooked up my
You should start with checking all your breakers to be sure the breaker did not pop just half of your breaker. This is something you should do with all your breakers. When you do this you should shut down all your 220v breakers so you don't get bleed back through the system. Other than that you need to look for resets on the tub. The heater is a good place to start and don't forget the gfci's on the tub or in the bath or laundry room.
Posted on Dec 16, 2009
Coastsider
  • 331 Answers
SOURCE: My hot tub keeps tripping the breaker and will
Check for a water leak in the electrical areas of your spa... specifically look closely around the heater terminals, look for wet and corroded connections... If this spa is wired to a plug-in outlet, look at the GFCI plug assembly as well... You can also try disconnecting the blower, pump, heater, etc, from the control pack (one at a time) to determine which item is causing the tripping.
Posted on Apr 14, 2010
uspartscente
  • 717 Answers
SOURCE: in econ mode my 1998 spaform hot tub does not
in the economy mode it will only maintain a temperature so that it will not freeze. Economy mode is mostly for vacation time or for winter if you are not going to be using the hot tub for an extended period of time.
Put it into the standard mode and you will be able to have a HOT tub and will function as it should
US Parts Center
Posted on Aug 23, 2011
  • 368 Answers
SOURCE: i have a freeflow legend hot tub. the gfi was
It sounds like there may be a short in it causing the breaker to trip. I would disconnect the wires from the new element, tape them up and test for the problem again. If it still trips it is not related to the heater element. If it still trips it is not related to the heater element and therefore additional diagnostics need to be used to find out what is is wrong.
Posted on Sep 06, 2011
Hot tub pump will not start back up after cleaning hot tub
When you say the pump won't start back up, do you mean the electrical side of things and there is just no power going to the pump. Or are you saying that the pump is on but not pumping water.
I am going to think you mean the pump is on but not moving water. This is common after you clean and drain your hot tub. You have what is referred to as an airlock in your hot tub line. It is easy to remove the airlock by simply opening one of the unions near the pump. This will allow the air to release and water flow to begin again.
Make sure also that you have cleaned the hot tub filters, if they are dirty and reduce water flow that could shutdown your hot tub pump as well.
If it is the electrical side of things make sure your GFCI has not tripped and maybe you just need to reset this. If it is anything further on the electrical side make sure you involve a professional.
  • open a union to release any airlocks.
  • clean your hot tub filters.
  • check to make sure your GFCI is not tripped.
Hot Tub Repair 101 What is an E6 or Error 6 Code Mean
You may have to change your hot tub filters as well and can find an assortment of filters here. The filters should be changed yearly, and cleaned monthly.
Hot Tub Filters
Jan 30, 2016 | Pool & Spa
I have a spaform hot tub which is flasing Lf Ecny what does this mean
the fault is "low flow" and its in economy mode , this is a minimal mode that is without heat , just recirculates water to prevent a freeze up
you'll need to investigate the cause of low flow alarm , start with the filter , clean/replace it
Dec 22, 2014 | Pool & Spa
Spaform hot tub manual
check the timer or may need to reset the cycle on it..(reprogram the controller)
Jan 09, 2014 | Pool & Spa
My hot tub is not coming on at all and is giving me a Pr code. What can I do?
please follow this steps and fix it. God bless you
If the unit won't start, make sure power is on at the electrical panel or the electrical panel . Then test the pump and the motor. Check for and repair broken wires or loose or corroded terminals. If necessary, have the pump switch control tested and serviced professionally.
If the jets do not work, clear a blocked water intake of hair and other particles (see below) or replace a broken jet (see below).
If the water in your spa or hot tub is too hot or too cold, check to see if the high-limit reset switch has been tripped and, if needed, reset it. Adjust the thermostat setting and have the thermostat serviced if the problem persists. If necessary, test and replace a faulty heating elements
Nov 26, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
In econ mode my 1998 spaform hot tub does not appear to heat but it is ok in standard mode.
US Parts Center
Aug 22, 2011 | Pool & Spa
The circut board was replaced everything powers up lights jets the digital display all program functions to program filtering cycle.while running operation seems normal.after aprox.from start of system to...
Do you have a model and serial number so i can spec components and a diagram?
The reset is a GFCI electrical or a high limit temperature switch?
If its a GFCI you have a leak or a short or the pump is drawing to many amps likely due to something in the impeller or plumbing restricting flow. Potentially its a shaft seal issue.
How hot is the tub when it trips? Try running it cold and see if it trips. If it doesnt and its still cold its the pump. If its hot and you set it to cold its a stuck relay or contactor or triac and therefore tripping a high limit switch.
If this is a hot tub/spa the pressure switch may be an issue. It shuts down the heat typically and keeps the pumps running.
If a reset switch of any type is tripped to many times it will continue to trip at a lower and lower value.
Just some tips, hope they help. Get back to me with some info.
Jan 20, 2011 | Home
My hot tub still trips the breaker,and i replaced
Check the heater. The heater is the most likely cause of tripping electric.
If you're not sure what you're doing, please contact someone who does. Electricity isn't something that should be played around with especially when in close proximity to water.
Regards,
Ian.
http://hottub.synthasite.com
May 12, 2010 | Balboa Instruments Duplex Digital Panel 2...
Pool & Spa Logo
166 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
