Question about Samsung Falcon iDCS 28D 28-Button Keyset with LCD - Dark Gray
How do I program my speed dial
I need to be able to call other phones in the office to ask questions to my coworkers
  • Samsung Master
  • 3,382 Answers
It is in the manual which you can get at:
www.customtelsys.com/downloads/pdf/user.../iDCS_Keyset_User_Guide.pdf
Posted on Dec 06, 2014
What Is A Co-Working Space?
A Coworking space is part of the sharing economy. Coworking Space is generally a phrase used to describe a business or organization that is dedicated to the full Coworking concept.Co-Work Gurugram provides the best Coworking Space in Gurgaon with full of luxury amenities like Cleaning Staff, Meeting Rooms, High-Speed Internet, Printer Scanner, Microwave Oven, Air Purifier, CCTV camera and surveillance and much more.
Oct 05, 2015 | Retail Supplies
The screen on my phone shows "VRS-AL" which does not allow anyone in the office to page me. How do I remove it?
on the phone press speaker dial 713 and hang uo.
if this does not work we need to know what kind of phone system. IPK IPK 2?
Sep 19, 2014 | NEC Dterm DTP 16D-1 Corded Phone
EXECUTONE 64800 PHONE, HOW TO PROGRAM STATION SPEED DIAL # 'S
from the phone press program key, than 01 for speed dial 1 and then the phone number you need to program in under speed dial 1, after done, press program key. to dial out press outside line key, than program 01 and it will dial out to that numeber. you have 30 speed dials per phone.
Jan 09, 2014 | Executone 64 Corded Phone
How do I set my speed dial numbers?
Which ones? System speed is programmed from station 10 or 11 and goes in the 6xx's, depending on your version of software. The start is FEATURE 00 FEAT 6xx and dial the number You can continue programming more numbers by pressing FEAT 6xx or Feat 00 to exit.
Personal speed dial numbers are programmed similarly, except they are in locations 80-99 on each phone and can be programmed from the phone if it's a system phone.
Auto Dial buttons use blank buttons on your set. Feature 00 pressing the button and dialing the outside number store those. Again, Feature another button will let you program another button, or Feature 00 ends programming.
Carl
Jul 12, 2011 | Lucent PARTNER18 Corded Phone
Hi I have a panasonic KX-T433 phone system which I am trying to put in speed dial numbers, we have to dial 9 to dial out does any one know how to do this using a 9 in front?
You have neither a 7730 (the category you asked in) or a 7433 phone sytem. If your phone is really a 7433, you have a TD phone system. Which "speed dial numbers" are you trying to program? System speed dials, are stored in system program 001 and consist of a 3 digit number (may be 2) with a "9" in front and the number as you would dial it from the keypad. Personal speed dial numbers depend on the button you're programming it onto. If it's a button with a light, you dial "2" in front of it. If not, you don't. So, Program 99, button, and either 29 + number STORE or 9+number STORE programs a personal speed dial.
There are other programs to store under the tone pad keys. Those features are covered in your User's manual for the TD system.
Carl
Jul 06, 2011 | Panasonic KX-T7730 Corded Phone
Hello. I have a M7310 Nortel office phone. All of a sudden, the Speed Dial button will not work. In checking the phone, all the speed dial numbers are still programed in the phone, but again the speed dial...
What? They are either programmed or not programmed. If the button is blank, I'm voting for NOT programmed.
If your system is old enough, it's probably lost the backup battery. Ugly things, like pulse dial and only 2 lines are what usually happens, along with losing all of the button mapping but your 2 lines and the default programs of LNR, CONF, etc.
If it's just one phone, there's no magic recall. You'll just have to reprogram it. Same with the system if you've lost everything, but I"d call a repair tech first to fix the battery on the software cartridge.
Carl
Apr 14, 2011 | NorStar Meridian M7310 Phone
Our office has Samsung KPDCS-12B LCD phones. How to we store and delete numbers please ?
to program the directory on a 12 button handse;
Press the TSFR key
Enter 200
Enter code 1234
=/- key to enable
Speaker key
Your next command will be the MMC required.
To program the system speed dial directory
Enter 705 - Speed dial 12th Button down to toggle between
Enter 706 - Speed Name the 2 MMC
Feb 23, 2011 | Samsung Phone PDCSLCD12B
Changing all speed dial numbers
Speed dials reside in programming memory 001. You can change them from the maintenance console software, or an extension, usually on Jack #1, operator, or the manager's phone.
From the phone, (ext 101) press PROGRAM and dial **1234. If the display says SYS PGM then dial 001 and start with your first speed dial number (3 digit, 001-999). By stepping through the ENTER key, you will be able to find the existing numbers. A trunk access code must be the first part of a speed dial number. You probably see it as the first digit "9" in front of all your numbers.
Carl
Apr 10, 2010 | Panasonic KX-T7630 Corded Phone
INSTRUCTIONS NEEDED ON HOW TO SET UP SPEED DIAL NUMBERS FOR WHOLE OFFICE SYSTEM
Speed dial numbers 001 -255 (01- 70 on older versions) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program(40-70) .
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Jan 08, 2010 | NorStar T7316E Corded Phone
Speed Dialing
There are actually many ways to program them, and dialing them can be different depending on the system involved.
You can have speed numbers on each extension (up to 10) and system wide (up to 1000). In addition, you can have telephone numbers associated with buttons on the phone allowing one-touch dialing.
How it is done depends on which system you have and how it was programmed by your installer.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Mar 04, 2008 | Panasonic KX-T7633 Corded Phone
Open Questions:
See all Samsung Falcon iDCS 28D 28-Button Keyset with LCD Questions
Samsung Falcon iDCS 28D 28-Button Keyset with LCD - Dark Gray Logo
125 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
