Question about Tools & Hardware - Others
How do I white wash paint
How do I white wash over paint?
  • 14,585 Answers
You don't white wash painted surfaces, unless they have been white washed ( like wood fences and such). Over painted surfaces, you prime them. Going from dark to light, use Kilz enamel primer. Ventilate the place as the smell/fumes from it will kill you.
Posted on Dec 06, 2014
Remove paint off clothing
Soak with white spirit or cellulose thinners depending on the type of paint. Don't use cellulose thinners on synthetic materials or it will dissolve it. You can also use Nail Varnish remover on cotton material. Basically, you are finding a solvent that is already in the paint to dissolve it, and then use washing up liquid to wash the lot out.
See the link
Remove paint off clothing Google Search
Dec 26, 2017 | Dryers
Methods how to do white washing on pine wood?
First use a stain blocking primer such as Killz. If it is an item that is outside use a good exterior paint two coats. Inside items use interior paint two coats. Don't use exterior paint inside cause it can contain pesticides that can cause harm to you. Pine will seep sap for a few years so you may need to repaint sooner than usual.
Oct 25, 2016 | Washing Machines
How to white wash pine wood
Prime the raw wood with a stain blocking primer such as Killz. The use a high quality paint for the finish coat. Use two coats for a longer lasting finish. Be sure to us exterior paint only for exterior jobs. It contains pesticides that if used inside can make you ill.
Oct 25, 2016 | Saws
Can you use ultra white paint as a primer on a wall before painting it?
Not recommended, especially if the ultra white paint is anything but "flat." Primer is designed specifically to adhere to other paints. Look into KILZ primer (if it is available where you are), as I have found it to provide excellent coverage for color changes.
May 08, 2015 | Tools & Hardware - Others
How can I deep-clean or spruce up the white Dangari resin arm chairs?
Try using Zep shower cleaner..Wet the chairs, spray it on and let it sit for ten minutes and wash it off with a pressure washer. Paint is not going to stick for very long on resin.
May 19, 2014 | Evolutif Dangari Resin Outdoor Dining Arm...
Without a repaint, how can I get the crud and dull surface back to shiny?
use a scratch removing polish polishes and shines have to do small area at a time ,but brings paint up nicely
Feb 03, 2011 | Ford E-150 Cars & Trucks
Painter has left small line of white vinyl matt emulsion (from ceiling -no masking tape used ) along the top left hand edge of the new stainless steel cooker hood - out of eye line but visible. how can I...
Luckily, vinyl matt emulsion paint is water based and is fairly easy to remove. Use half a wooden garden washing line peg or similar piece of softwood with s mild solution of washing up liquid. The wood will rub the paint off the metalwork and the washing liqid will lubricate without the metalwork so not to damage it.
Hope this helps.
Nov 25, 2010 | Microwave Ovens
After wasing dark cloth, there a lint on them, how
i think the paint inside the washing machine started to peel,and maybe that's the cause of white lint.
http://www.washingmachineadvisor.com/1400-spin-washing-machine
Feb 05, 2010 | Washing Machines
Maytag neptune dyer
Hi there. Actually, you could find a white dryer and spray paint it. I have done this and the appliance paints are amazing.
May 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Black finish
Depending on how deep a good cutting compound/polish should do the trick...be careful the paint might be quite thin
Oct 09, 2007 | Frigidaire GLTF2940ES Front Load Washer
Tools & Hardware - Others Logo
130 people viewed this question
Top Tools & Hardware - Others Experts
John Trevino
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
